Question about Dryers
Dryer tubs makes a whop whop sound when cycling. belt looks ok
    Habit-Forming:
  • 143 Answers
Drum roller need to be replace
Posted on Apr 25, 2010
How to repair squeaking sound when in operation
it most commonly has to do with the inner wheels needing to be replaced. either the tub wheels or belt wheel.
May 19, 2014 | Maytag Bravos MEDB200VQ 29" Electric Dryer...
Dryer hummes when you turn it on but does not rotate
This don't sound good most likely the motor is bad . OK first unplug the dryer take the belt off the motor now plug the dryer back in hit the start switch does the motor turn NOW??? If not its the motor. IF the motor does turn??? could be a weak motor OR Bad bearing in the Back of the tub.
Rotate the TUB by Hand UNPLUG THE DRYER FIRST. IF the tub Rotate freely I would say you
Have a bad Motor But if the tub is very hard to turn now your looking at a bad Bearing
GOOD LUCK HOPE THIS HELPS
Nov 21, 2010 | LG DLE5977 Electric Dryer
Dryer smells like something is burning and making a slight humming sound
check tub bearings and/or rollers or for anything that could impede the turning of the tub. Sounds like something is stopping the tub enough
to make the drive motor turn on the belt causing it to burn and smell.
If you fix the problem with the tub be sure and change the belt
Leo Ponder
imufo2@sbcglobal.net
Jul 28, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Making loud noise in the spin cycle and now does not spin at all
Sounds like the tub bearing is gone. Get it checked out though. It could be the pump bearing, a cheaper fix. Or as bad as the tub bearing, a motor bearing.
Feb 26, 2010 | Maytag Washing Machines
Gas dryer drum does not spin
defective motor,,replace,,,onthejob
Jan 11, 2009 | Dryers
Knocking sounds
Ususally knocking is a sign that the rubber belt which spins the dryer tub is old and has hardened. If the knocking sound gets quieter after you have run the dryer for 30 minutes or so, then the belt is the problem. As the dryer turns, it heats up the rubber belt and makes the belt more pliable. This quiets the knock. I have seen dryers work fine for years, knocking the whole time. Have the belt replaced if the sound bothers you.
Sep 07, 2007 | Maytag Atlantis MDG6400AW Gas Dryer
Noisy dryer
Don't turn the tub to much this may make the belt run off track . If the machine makes a rumble at the beginning and at the end or when u stop the machine and restart it it is probably the blower wheel,it is made of plastic ans wears out on the motor shaft.
Apr 05, 2007 | Maytag LSE7806A Top Load Stacked...
My washer does not wash the clothes or go through the spin cycle.
It sound like a belt problem. Try to move tub manually first, in case it move smoothly -open the front panel, the belt should be between the motor and the drive pulley (lower front). In case it torn or not in its place, you should replace it. In case it doesn't move smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, it should be removed. Good luck !!
Jun 02, 2006 | GE WSM2700D Top Load Stacked Washer /...
Dryers Logo
Top Dryers Experts
