Question about Sharp R-1480 Microwave Oven
Microwave turns on when i open door and stays on with door open
DO NOT OPERATE AT ALL ! POWERFUL / DANGEROUS MICROWAVE ENERGY WILL BE BEAMING OUT ALL OVER THE PLACE !! DISCONNECT FROM MAINS, AND PUT WARNING SIGN ON IT BEFORE GETTING A PROFFESIONAL TO CHECK IT.
Posted on May 14, 2010
3 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave stays on when I open the door then turns off when I c
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Jan 03, 2009
  • 8909 Answers
SOURCE: Bosch HMT93660EU microwave oven. Light stays
Check door interlock switches and moisture on the control panel causing errors.
Posted on Feb 04, 2011
Samsung microwave turns on when open door
The switch assembly is somehow staying "closed" satisfying the interlock and enabling it to run.
Disassemble the unit, beware specially of the high voltage capacitor, if you aren't comfortable or competent, buy a new microwave. If you are mechanically inclined, disassemble the unit until the switch assembly is accessible; it will have the door latch attached to it.
The switch is either broken or something? exogenous is keeping it closed. It may have come loose due to the door slamming?.
It's a simple fix. I am certainl you will be successful.
May 04, 2017 | Samsung Microwave Ovens
Fan & Light stays on???
On a few new model microwave ovens, this is a "feature"! It's purpose is to cool the microwave parts down, and to remind you that your food is cooked. Once you open the door, the fan will shut off and stay off when you close the door again. But if not, or if you microwave oven didn't use to do this, then you have a bad door switch.
Sep 08, 2014 | Microwave Ovens
After closing door micro wave turn table continues to turn and light stays on after you open door and take out food.
The problem is most likely caused by a defective door switch, and should be rectified for safety reasons.
Apr 05, 2011 | Whirlpool WMH1162XVS Microwave Oven
Sharp microwave door will not shut and the oven light stays on continuously.
The door has a switch , probably two, that engage and disengage when opening or closing. ( a failsafe so it switches off ) when you open the door, this is the problem also like a fridge the light should go off when door is shut, it may just be stuck but Dont mess with it , clean it if its got food stuff , a mild detergent round door etc , otherwise just change microwave ,
pete
Nov 10, 2010 | Microwave Ovens
Sometimes plate does not turn and microwave stays on despite opening door
The door switches must be replaced as one or more are faulty and could cause a hazard.
Oct 20, 2010 | Bosch HMT9656GB Microwave Oven
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Sharp R-1480 Microwave Oven Logo
264 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
