Question about Radio Communications
Looking for tips /advise on installing a FL-100 filter in a IC-706MKII
First time filter installation on a used IC-706MKII. Can anyone comment on the proper steps to follow and the things to be careful about to install this filter. Filter appears to have (4) solder connection legs on it form the appearance. Or does it plug in? I am not sure by looking at it. I have not opened the radio up yet.
  • Gymd Mar 23, 2008
    most helpful and very quick response from Benimur. Thank you very much
    Brigadier General:
  • 6,966 Answers
To my understanding, most optional/add-on IF filters are plug-in. For the Icom IC706MkII, it would have to be on the top circuit board. Top cover is held by 3 screws on top and 1 at each sides. After you have physical connected the filter, you need to inform the system the specific filter connected on powerup. This could be done in the "Initial Set-up Mode".
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 23, 2008
  • Louie  Role
    Louie Role Mar 24, 2008
    Glad to be of assistance and appreciate the rating.
    Regards from DU land.
My spray gun keeps stopping and then I reverse tip and it works then stops then I reverse tip and leaking
It's probably the paint-I had a problem with certain brands. I started putting a cheesecloth type filter around the uptake to help filter larger particles and it works a lot better.
Jan 31, 2015 | Air Tools & Compressors
Insinkerator has stainless steel tank but does not have anode rod to protect against depleted tank wall.
Leaking tank means broken weld, and you must replace tank.
Copy following link for tips installing under counter heater
Add comment as needed and fixya will send me email to reply with more detail as needed
Jul 15, 2013 | Emerson InSinkErator W-152 Point-Of-Use...
My Oly FL-36R sometimes does not turn on. I've tried new batteries and it has a mind of it's own. Help.
Hi. I read somewhere on dpreview that you're not supposed to take out the batteries even if you're not using the flash. The tip is to install the batteries about 8-12 hours BEFORE you want to use the flash to charge the capacitor, or something like that...
Aug 07, 2011 | Olympus FL-36R TTL Flash
Comment puis-je changer l'heure
  1. Alllume ton GPS.
  2. Tape quelque part sur l'écran. Des icônes apparaissent.
  3. Cherche celle en dessous de laquelle est écrit 'Change preferences'. L'icône en question représente une clef plate (de mécanicien) .
  4. Tape l'icône pour changer la configuration.
  5. Utilise la flèche qui pointe à droite. Continue jusqu'à ce tu parviennes à la page où il y a l'icone d'une horloge (réveil-matin).
  6. Tape cette icône.
  7. On te demandera de choisir entre la représentation de 24 h (18) ou 6 pm. ou 6. Choisis ta représentation horaire.
  8. Dès que tu appuies sur Done, l'écran change et on te demande de régler l'heure.
  9. Tu as des flèches vers le haut et des flèches vers le bas. Deux flèches pour changer l'heure et 4 flèches pour changer les minutes.
  10. Tu peux même synchroniser l'horloge sur les sattelites en appuyant sur sync.
Jul 19, 2010 | Tomtom ONE GPS Receiver
Need the timing marks for 2001 hyundai tiburon
1.5L And 1.6L Engines
Fig. Proper pulley alignment for timing belt installation at TDC-Hyundai 1.5L DOHC engines
Fig. Proper pulley alignment for timing belt installation at TDC-Hyundai 1.5L SOHC engines
1.5L Engines
Fig. Proper pulley alignment for timing belt installation at TDC-Hyundai 1.5L SOHC engines, 1.6L similar
1.8L (VIN M) And 2.0L (VIN F) Engines
Fig. Proper alignment of the timing belt alignment marks for belt removal and installation-Hyundai 1.8L and 2.0L (VIN F) engines
2.0L (VIN P) Engines
Fig. Oil pump and crankshaft inner timing belt sprocket alignment marks-Hyundai 2.0L (VIN P) engines
Fig. Timing belt sprocket alignment mark locations and positioning for belt removal and installation-Hyundai 2.0L (VIN P) engines
3.0L (VIN G)
Fig. Installation of the timing belt-3.0L (VIN G) engine
Fig. Timing belt sprocket alignment mark positioning for belt removal and installation-Hyundai 3.0L engine
Hope this helped (remember comment and rated this post).
Apr 13, 2010 | 2001 Hyundai Tiburon
K&N Air filter
I payed 50$ for mine and the mileage affect shouldnt be any differant but it will run better.
Nov 10, 2008 | 2007 Bajaj Bajaj Avenger
PT 47WX42F Panasonic Projection TV
yes it did fix my problem but you need a tech to look at it. if your in canada i can recomend a dealer
Oct 03, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Computer will not recognize Sansa e250 MP3 Player
You need to first update your firmware with a windows based computer (one update at a time in order). This will solve a ton of issues. Finally change the "USB Mode" to "MSC" with in the settings menu and you can enjoy your player
Jan 15, 2008 | SanDisk Sansa E280 MP3 Player
Radio Communications Logo
97 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
