No picture but all the menu screens come on and look normal sometimes the picture will come on for a short period of time. and then shut off
  • Rommel Cana
    Rommel Cana May 11, 2010
    what model and make ?
  • 438 Answers
If the TV dose not detect a viable video signal it will mute the sound and blank the video there is a preset minimum level that enables the audio and video, insure that the video source is of good quality and the cable you are using is good, if it is than you may have a problem in the video processing circuits of your TV, the good menu screens indicate this may be the fault,,, Good luck
Posted on Apr 27, 2010
No image shows when I take picture
Usually the photo is displayed for a short period of time. Try the setup in the menu. There should be an option for previewing recent pictures.
Jun 20, 2012 | Fuji FinePix S2 Pro Digital Camera
Picture turns green ,usually within 10 minutes of turning it on.It will sometimes go back to normal color but generally returns to green.This happened when the set was much newer and Sony replaced all...
Green Tube maybe trying to short out or you can try adjusting screen drive to the Green Tube by turning control down a notch, Sony had a bad run on these with alot of Bad Tubes.
Dec 08, 2009 | Sony KP-57HW40 57" Rear Projection...
TV screen Flashes blue and then shuts off.
When it flashes blue, are the flashes bright blue lines going across the screen with the picture in the background, if so, It sounds like the Blue tube or blue driver circuit is breaking down after a short period of time. If this is the case, the uPC that controls the set is detecting a large current drain on and is shutting the set off for protection, An engineers expert eye is required I`m afraid. Ian.
Jul 24, 2009 | Sony KP-65WS500 65" Rear Projection...
Touchscreen wont cut off when car is turned off.
It is normal for the screen to stay on for a short period of time after you turn off the engine and leave the car. It should shut off after a minute or so.
Feb 13, 2009 | 2006 Land Rover Range Rover
KP-53S65 Blue Ghosting
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 11, 2008 | Sony KP-53S65 53" Rear Projection...
Intermittant white line with subsequent shut down
You have a vert ic problem very common tv problem.
POSSIABLE SOLUTIONS
1 COLD SOLDER JOINTS ON IC REPAIR COST IS 95.00
2 REPLACEMENT IC 120.00
CALL LOCAL TV SHOP AND ASK FOR PRICES ON A VERTICALE IC REPLACEMT. THANKS DOCTOR VIDEO
May 17, 2008 | Hitachi 36UX59B 36" TV
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
No picture
You have an intermittant vertical sweep circuit! It could be the vertical out put IC solder connections on the printed circuit board, or maybe the IC itself has poor connections between the IC and the contact legs that mount the IC, or another componet in the vertical sweep circuit. If you know how to solder and unsolder, work on printed circuit boards, then you shoul have no problem replacing the vertical sweep circuit. Good Luck
Oct 09, 2006 | Panasonic CT-25G6 25" TV
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
