Question about Dell Computers & Internet
The Pioneer DVD+-RW DR-K17Y ATA Device in my Dell Inspiron E1705 has stopped working. The drawer won't open (without the help of an unbent paper clip) and the disc does not spin up. Application software requiring a CD (or DVD) in the drive think the drive is empty whether is is or not. There are no error messages appearing or any other indication that anything is wrong. After cleaning the registry and the files of unnecessary clutter (Uniblue software) and updating drivers yesterday it began to work but stopped again this morning. I have since repeated yesterday's procedures plus uninstalled and reinstalled the DVD driver. Nothing seems to work. I have also run several diagnostic tests and all say that the drive and its drivers are working fine. But they are not. Thanks for your help, Mark B
  • kyue2 Apr 26, 2010
    Thanks for your response and help. While struggling to get to the BIO pages (the instructions flashed by on the screen so fast I didn't have time to either read or activate them) the drive began to work again. But it didn't last. After following your instructions, short of ordering a new drive, and finding no problems, I downloaded and installed a new driver. That seems to have worked. However, I would like to keep our dialog open for a few more days in case it fails again. I think the problem is digital rather than physical and wonder if there may be other things to explore. -Mark
  • Dell Master
  • 13,433 Answers
Hello
Lets start by checking if the drive is detected by bios. turn off the computer and enter setup / bios / cmos when asked.
one of the bios pages should show you the hard drive, and the cdrom drive that is connected to the computer, if it does not show up there, either the drive is bad or the motherboard of your laptop is no longer functioning on that part.
If it does show up there but the tray will not open and a disk wont spin, - you can't start up from a cd even if you set the boot up order to start from Cd and then put in a restore cd or similar windows insallation disk, if that does not start up. then the drive is faulty. And the fix, most likely to replace the drive.
instructions on how to remove and replace the drive on your dell are documented here
http://support.dell.com/support/edocs/systems/ins9400/en/sm/opdrive.htm#wp999869
before replacing the drive you can try removing it from the laptop, start up without the drive, then turn off the machine, reinstall the drive and boot up again. Remember to unplug and remove the battery when installing or adding parts.
you can get a pretty good deal on any computer parts from http://www.newegg.com/ , you can also try www.ebay.com
Make sure the type of the new drive is simline / fits into a laptop, and that the connector / interface is the same.
Posted on Apr 24, 2010
  • Ekse Apr 26, 2010
    Sure thing. Let me know if im needed.
Stuck CD/DVD drive. Won't open
There is a hole on the front of the drive. Push an unbent paper clip into ththe hole and it should release the drawer.
Jul 04, 2012 | Acer Aspire X1300 (PV.SCC0X.002) PC...
My burner will not burn cd's anymore. It still plays cd's fine as well as play and burn dvd's fine. I see no errors in hardware setup. It is a nec dvd +- RW ND 6650A that came with my Dell Inspiron E1705.
The CD Burner / Player / DVD Burner are all different heads. If the Dell Inspiron E1705 is an older model it is most likely you have reached the end of it's usable life for the CD burner part. If it is new the CD burner is most likely defective and hopefully warrantied. Otherwise these CD/DVD units can be replaced relatively inexpensively (as compared to buying a new laptop).
Feb 01, 2011 | NEC ND-6650A DVD RW Dual Layer Burner
The Pioneer dvd+-rw DR-K17Y ata Device in my Dell Inspiron E1705 has stopped working. The drawer won't open (without the help of an unbent paper clip) and the disc does not spin up. Application software...
This sounds as a hardware problem, maybe a gear or a servo engine. Its a common problem since the mechanism is small and mostly plastic. If you have the chance use a live cd or live usb to see if it is not a windows problem. In my opinion the best solution is to replace the drive.
May 10, 2010 | Computers & Internet
PIONEER DVDRW DVR-K17B ATA Device Issue in HP Pavilion DV9500 Lap
you may need to clean the lens of drive with a wet tissu paper, otherwise the drive might gone out of order, need replacement.
Feb 10, 2009 | Pioneer DVR-107D DVD±RW Burner
DVR K17LF Insert a disc
Hi, according to what I understand the unit works for some situations especially but you cannot visualize the content, in this case the problem that you one presents shows off to be Cd-DVD's unit that this trumping, if the equipment this one even in guarantee, you must come to an CAS or Center of Authorized Service, in order that they diagnose and replace the unit
Dec 27, 2008 | Toshiba Satellite A205-S4617 Notebook
Download driver software for PIONEER DVD-RW DVR-K17LF ATA Device
manually download it from the pc makers website drivers section and point the driver setup to the folder.
Nov 09, 2008 | HP Pavilion dv6000z Notebook
Pioneeer DVDRW-K17B ATA Device
hello
i'm having HP PAVILLION DV6000 and OS is VISTA HOME PREMIUM .My problem is that my system does'nt show any dvd drive in MY COMPUTER. I am having PIONEER DVDRW DVR-K17B ATA Device .device manager show a yellow icon and tells that it needs driver. It was working properly before.
thank u in advance
Oct 30, 2008 | Pioneer DVR-107D DVD±RW Burner
it's look like you have problem with dvd isnot showing in windows explorer / dvd driver.
Try this step from microsoft http://support.microsoft.com/KB/314060
basicly just update (delete some key) the windows registry and restart. ussually this work ok.
Jul 31, 2008 | Toshiba Satellite P105-S9722 Notebook
I wish to download the Software drivers for Pioneer DVD RW
May 24, 2008 | Computers & Internet
DVD driver fault - Pioneer DVD-RW DVR-212 ATA.. maybe NERO 8 fault?
Code 10 means the driver cannot load usually due to being incompatible with the OS type.
May 29, 2017 | Computers & Internet
Computers & Internet Logo
99 people viewed this question
Alun Cox
