Question about Sony BRAVIA KDL-52W3000 52 in. LCD Television
Get "double vision" after about 20 minutes of operation. Sometimes this goes away and it works fine again, but most times it doesn't. Repairman says its the panel and needs to be replaces, but that part costs more than my entire TV did new 2 years ago! I'm not so sure that's the problem? Sony customer service is NO HELP!
    Guru:
  • 416 Answers
Your service repairman is correct. The TCON (Timing Contol) board on the LCD panel is malfunctioning. This TCON board is not available by itself, only with the panel. Unfortunately, you don't have many options here. Best wishes.
Posted on Apr 24, 2010
Can staring at a screen damage your eyes? Anyone know what kind of distance I should keep away from the screen?
I have heard that it's healthy to observe the 20/20/20 rule when it comes to protecting eyes from screen damage.
Every time you have been looking at the screen for 20 minutes, you should look away at something that is about 20 feet away and keep looking for around 20 seconds. Then you can return to the screen.
Feb 13, 2013 | Health & Beauty
95 eagle vision esi slips out of gear at stops
there is a limp mode but I doubt if that is the problem
It indicates that the torque converter clutch servo/solenoid is faulty
run the fault codes to confirm if that is it or a faulty TCM
check wiring around the transmission
Apr 19, 2017 | 1995 Eagle Vision
We recently moved the tv and now when we turn it on it has double vision. It kinda looks like a 3d movie. What could be the issue? Is it worth fixing?
If tv picture was fine before moved then check dry/ cold solder joints/ connections on convergence output ICs and nearby circuit area.
Local tv repairman will resolder loose/ dry solder connections to solve double vision picture problem.
TV worth fixing if picture is good.
Thanks.
Feb 18, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
Yukon Ranger 5 x 42 night vision goggles just stopped working, I put in new batteries, but when I press the ON button the on light, which is red, just flashes maybe 10 times and then all goes black. ???
Hello, let do this. IR illuminator has a montary switch, that is when you push it comes on, and when you release it the IR goes off and it has a red LED to indicate the IR illuminator is being activated.
When you turn you binocular on there will be a green LED activated. This switch is DTSA---double throw sing activated. That is, one throw of the switch it turns on the binocular, the throw will turn off the binocular.
Also within the control panel there is timing circuit to keep the IR illumniator on for ten second the shuts off. Make sure you have the right switches etc. Let me know, then we can brain storm on this matter. stewbison
Jan 29, 2011 | Yukon 28041 Binocular
LCD displays 4 white lines and has double vision
I saw your tv pictures at above mentioned website link.
It is LCD Panel (screen) problem, call Sony and ask for warranty cover to replace lcd panel.
Thanks.
Jul 18, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
Our D52W198 was mfgr'd. Aug 2004. Sometimes it
A television shutting itself off may mean a few things:
  • Bad lamp (most likely the cause)
  • Overheating
  • Bad power supply
  • Bad ballast
To properly diagnose your television, i'll have to know more about the symptoms. You can start by moving the television away from any walls. This will give it better ventilation and cooler operation
Mar 26, 2010 | RCA D52W19 52" Rear Projection Television
I'm getting an error message "E27" on my bosch vision machine but can't fine it in the manual
I had to call the repairman. He said it was an overheated solenoid in the door lock. The "repair" is to let the washer cool for about 10 minutes (unplug it), then try again. If you're still getting the code, you'll probably need to call a repairman like I did. Though once he put it into diagnostic mode the code "cleared" and it works again. The final fix is to replace the lock.
Mar 23, 2010 | Bosch Washing Machines
When initially turned on the picture jumps around for several minutes
"Fonzie-ing it" ? It's terrible that I understood what that meant. lol
Sounds like the tuner has a bad solder joint. You may need a Repairman.
Geno
Jan 24, 2008 | Toshiba 52HMX84 52" Rear Projection...
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
Sony BRAVIA KDL-52W3000 52 in. LCD Television Logo
298 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
