Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Governor spring position 120000 series
Need diagram as to where to attach governor spring on 120000 quantum
4 Suggested Answers
SOURCE: need pictures of governor springs and governor
model # 12f702-1824e1 mower( that uses weedeater string) had a spring come off the carberator and I don't know where to put it back on.
Posted on Apr 19, 2009
cmcduncand
  • 714 Answers
SOURCE: Is there a diagram showing where to attach bnoth
Did a quick search for you.
GOTO:
http://psst.home.sprynet.com/9.jpeg
Hope this helps your problem.
r/
David
Posted on Jan 23, 2010
  • 10 Answers
SOURCE: pic/diagram of 10hp briggs & stratton governor,model 205412
on the governor arm itself,,,,there are a bunch of little holes drilled into the arm ,,,one end of the spring goes into usually the third hole from the shaft that the arm is hooked to,,another words the third hole away from the shaft,,,,then the other end of the spring goes to a stationary point to create a stationary base to the end of the spring for constant pressure..usually there is a deal sticking up for the spring to allow maximum movement of the spring without it touching anything.,,,hope it works,,,trial and error in this case is the best thing ,,hook it up WITHOUT stretching it too far,,if you stretch the spring to far then you WILL have to replace the spring!! be carefull on stretching it.
Posted on Dec 23, 2011
Need a throttle linkage diagram for a briggs & stratton engine model 9S502 type 0620-B1
David, This is what I found in google search for B&S carb. linkage diagram, you can also do a search because there are lots more.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Linkage Spring replacement on Briggs Stratton Quattro 4 HP Murray Lawn...
Repairing Lawnmowers For Profit Part 61 Governor Spring Help
briggs and stratton governor linkage diagrams Google Search
briggs and stratton carburetor linkage diagrams Google Search
Jun 10, 2016 | Briggs & Stratton Garden
TC'' On 2-cycle Husky rototiller Engine Family: WTPX.049EA. Neighbor took off carb spring and need diagram to see how to re-attach it.
Hi type in Google search. husky rotiller engine carby linkage photo. There r some photo's on carby linkage & springs. Good luck
Apr 05, 2016 | Garden
I have an intek 55 ohv engine as fitted to my self propelled mower but there are no id numbers on the motor apart from the sticker that says intek 55
If I remember correctly they are hard to see as are under the engine cover on the metal piece over the muffler. It be 120000 series. The governor spring depends on the model and type numbers of the engine.
Feb 16, 2015 | Garden
How to set up the governor on a Kohler K141 petrol engine on Howard rotovator
if it is a petrol engine then the governor arm will hold the carby open when stopped
as the engine starts the governor moves the arm to close the carby off to idle. the speed setting is by a spring attached to the throttle level and a point on the governor lever
Feb 13, 2015 | Cars & Trucks
Where does the governor spring on tecumseh hsk 8312b engine connect to?
Usually it would attach to the moving end of the cable where it joins the engine block
Nov 03, 2014 | Garden
Briggs free workshop manual
PartsTreeRepairClinic may get you one or they may have a video
Aug 20, 2014 | Briggs & Stratton Garden
Can I change a 10hp generator motor with an automatic throttle to a manual throttle?
Yes, you will be able to control the throttle. Look for a lever that pulls on the governor spring. On some generators, the governor spring attaches to an arm with adjustment screw and locknut or metal tab that bends into position. All that you need do is to pull on the governor spring to increase rpm. The governor spring pulls on the governor arm that is attached to the fly weight governor inside the engine. The fly weight is turned by the cam gear in most cases and the force that it produces is constantly trying to close the throttle. The governor spring provides the counter force to open the throttle. Without the governor, the engine can over rev. Good luck with your project.
Nov 18, 2011 | Briggs & Stratton Electrical Supplies
Hello, I am using the Craftsman 675 Brigs & Station 190 cc lawnmower, and I'm trying to turn up the throttle. It apparently does not have a throttle adjuster, and I was wondering if there is any way...
After researching the engine application, I see that this 675 is NOT an OHV engine. It appears it is the L (flathead) engine with the standard features. The 775-875 Platinum series mowers have OHV engine applications. That being said, many mowers have the carburetors with the governed throttles set to run at the the OEM mandated maximum speed. Some (like the Briggs Quantum series engines) have the throttle plate still attatched. You would need to bend it back up and install an aftermarket throttle cable assembley (like Murray makes). You would connect the carburetor end of the throttle cable to the hole in the plate assembly that has the governor spring attatched. Some even remove the governor entirely (internal governor has to stay in) and connect a throttle cable on the plate controlling the butterfly in the carb. Your unit may have this feature with the plate having a few different holes in it in which you could install the end of an add on throttle cable.
Apr 09, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
I need the linkage diagram for a 20 hp briggs and statton model 407777-0167
Besides the service manual you can view parts diagrams at a dealer like www.arcolawn.com. You can purchase the service manual at a dealer and it will show you how to hook it up.
The throttle linkage hooks up to the throttle shaft closest to the engine. the governor spring attaches the governor arm to the throttle linkage.
The choke cable attaches to the shaft farthest from the engine. I hope this helps.
PS your engine has two factory service bulletins on it.
Joe
Feb 15, 2011 | Briggs & Stratton Briggs Stratton Intek V...
It runs wide open all the time im wondering where idler arm setting is at
It sounds like the govenor spring has become disconnected or the clamp on the governor shaft has become loose and allowed the linkage to get out of adjustment. If problem has occurred suddenly it could mean the governor gear assembly inside the engine has broken and means the engine will need to be dismantrel to replace the governor gear assembly.
Check throttle linkage to see if spring is attached at both ends, one end on the throttle linkage and the other at the fixed point on the engine or to the end of the speed control lever. With engine stopped the spring should hold the throttle wide open and hand pressure on the linkage shoud be all that is needed to move throttle shaft closed to the idle position with no binding in the movement of the linkage.
If spring is OK and while engine is running, linkage should be able to be be moved to bring engine back to idle. If porblem has occurred gradually, then linkage will need re-adjusting. Loosen adjusting clamp on governor shaft, then holding linkage in wide open throttle position rotate shaft as far as it will go in the opposite direction to that requred to close throttle to idle . Re-tighten clamp.
Dec 11, 2010 | Coleman Powermate Premium Plus 6250W...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
620 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
