Question about Samsung LNT4669 TV
A 1 year old Samsung LNT4669 Television. It started out taking about 1-2 min. to start up. The last time I trided to turn it on it took almost 6 hrs. While it is trying to start it clicks, sounds like a relay opening & closing, It also has a red light in the front that blinks.
    Guru:
  • 416 Answers
This is a common failure. There are tons of resources for DIY repairs to correct this. I have a tutorial in my Tips & Tricks to fix this. Have a look if you like, best wishes.
Posted on Apr 24, 2010
"I have a 13 year old 10 SEER Achiever RUUD UPKA-049JAZ heat pump when you turn the AC on the ouside unit makes surging sound about every 3 min after about 45 min the ac will kick on."
sounds like compressor is going bad .. first try a hard start kit.. have staved off replacing compressor many times.. may last a long time may last 1 day
also check charge
May 20, 2014 | Ruud Heating & Cooling
Hi I have a 22 hp briggs in a husqvarna rider. Started running a little rough at season end last year. This year it started, but ran only about 2-3 min, then would not start at all, put in new plugs (old...
This a common problem after they have set up over the winter. Water has probably condensated in your gas tank and now it is in the gas line. The tank should be drained of old gas and the gas line to the carb should be removed from the tank and blown out with compressed air to remove all old gas/ water. Attach the gas line back to the tank and refill the tank with new fuel. This should take care of the problem. To avoid this next time, just fill your gas tank to the top at the end of the season and leave it full through the winter.
Mar 28, 2011 | Briggs & Stratton Briggs Stratton Intek V...
MY 2002 FORD T-BIRD WAS IN STORAGE FOR 6 MONTHS WITH A BATTERY TENDER. IT WON'T START, JUST CRANKS.THIS HAPPENED LAST YEAR. IT FINALLY STARTED AFTER ABOUT 1000 ATTEMPTS. LAST YEAR WE HAD NOT USED A BATTERY...
I've got an old corvette that I store also. I basically disconnect the battery and when I'm ready I charge it for 3 hrs, then start the car. Usually get close to 6 and a half years out of a battery. Five ain't so bad.
May 10, 2010 | 2003 Ford Thunderbird
Samsung HL-S5086W Television. 3 yr old. Never serviced. Last evening the TV started turning off by itself. It would turn back on easily and run for a few minutes. I unplugged a new Wii game that was...
Dont worry, the problem is coincidental to you installing the Wii. You need a new lamp.
What you are seeing is the lamp ballast/power supply attempting to start and restart your lamp. The resistance of your lamp to it's power source has increased to the point that it is shutting down, but has not blown out yet. You can find these at justlamps.com
Good luck
Jan 04, 2010 | Samsung HL-S5086W 50" HDTV
Toshiba lcd series 6, 18 month old tv will not
consult manual for troubleshooting it could be that lamp in tv takes long time to cool down or that it is bad they usually last about 2-3 years depends on how you use your tv
Dec 31, 2009 | Toshiba Toahiba Satellite A70 A75 M35...
White dots on samsung dlp
HI, these are the signs of a failing light engine. you will need to replace this engine soon. these distortions will worsen over time.
Jul 19, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
My samsung monitor syncmaster 743nx is not turning on..plss help me...tnx
How to troubleshoot a Samsung SyncMaster 743NX LCD Monitor? My Samsung SyncMaster 743NX monitor turns on slowly. I mean,last week when I started up my pc,it took 5-10 mins before my monitor displayed anything. I know the pc is already turned on because I've already heard the Windows Vista start up tune play. The problem is now getting worse as it now takes 20-30 mins before my monitor displays anything. Please help.
Mar 11, 2009 | Computers & Internet
Honda 2750i Powerwasher
I had the same problem 3 years old, maybe used 10 times - removed the air filter and the washer started fine. The air filter looked fine - I have not tried to replace it or figure out the root cause. I was just happy to get it running again :)
Aug 09, 2008 | Karcher 2500 PSI Pressure Washer
TV doesn,t turn on
the power regulater for your system have a short take it to a tech to have him fix it orelse you might cause further damage.
Feb 17, 2007 | RCA P46812BL 46" Rear Projection...
Samsung LNT4669 TV Logo
452 people viewed this question
Henry  Thomas
Henry Thomas
