Question about Linksys Wireless-G WRT54G Router
About bandwidth limiting
i have a problem our wireless networking.
Some of the users are abusing the bandwidth
making it difficult for others to surf the internet. Is there any way to set
limits to each user so that nobody ends up using too much of the internet.
my router type:
Linksys wireless -G Broadband router WRT54GL family.
firmware version (v.4.30.13)
how can i fixed that bandwidth abusing problem. could you help me please?
Kindly Regards.
    Guru:
  • 163 Answers
For limiting the bandwidth see my tips and tricks...............
Posted on Apr 24, 2010
Skype keeps losing connection
One reason Skype looses connection is because the network is too overloaded, slow or it goes down (crash). Sometimes, the network carrier reduces/limits your bandwidth if/when it detects you (or the other person on Skype) are using too much bandwidth (i.e. using and sending too much data across the network) ... e.g. by viewing movie / TV ... (for an extended period). The reduction / limitation makes it slower for info/data to get to your computer ... e.g. while you're using Skype ... and may cause Skype to believe there is a network failure ... and hence it "looses connection".
Try using a high speed network (from a network carrier) that does not limit your bandwidth (from high usage). Or try just doing the audio (which requires less bandwidth than audio and video) ... to see if it looses connections as frequently. { are you also using the latest version of Skype ? }
Oct 26, 2013 | Apple MacBookAir A1370 -23884
Tip
Recover the 20% bandwidth reserved for Windows Update
If you are using Windows XP Professional or Windows 2000 you can get this 20% back quite easily if you use XP Home its a bit more difficult to say the least
Navigate to the Limit reservable bandwidth in the Local Computer Policy in the Network Administartive Templates
Double click on Limit Reservable bandwidth. It will say it is not configured, but the truth is under the ‘Explain’ tab i.e.”By default,the Packet Scheduler limits the system to 20 percent of the bandwidth of a connection, but you can use this setting to override the default.”
So the trick is to ENABLE it then set it to ZERO. This will allow the system to reserve nothing, rather than the default 20% set by Microsoft for Updating.
If you want to enable this function in Windows XP Home then you need to follow THIS tip first to install the GPEditor.
on Apr 07, 2010 | Microsoft Windows XP Professional
How to adjust or can increase internet speed
If you are using Windows XP Professional then it is possible to squeeze an extra 20% out of your internet connection. By default Windows XP Pro holds back 20% of your Internet speed for various services like windows update and spyware checks.
If you want to tap into this locked speed then make the following changes: • Go to Start-> Run-> and type gpedit.msc • Expand the Administrative Templates branch • Expand the Network tab • Highlight QoS Packet Scheduler • Click on Limit Reservable Bandwidth and check the 'enabled' box • Then Change the Bandwidth limit % to 0 % Once you've done this click apply and restart your PC. After rebooting you will amaze a noticeable improvement in your net speed. goodluck....
Feb 22, 2011 | Computers & Internet
WHEN I'M WATCHING A VIDEO ON YOUTUBE THE VIDEO OFTEN STOPS OR FREEZES AND A WHITE SPINNER ICON SHAPED LIKE CIRCLES OR BALLS APPEARS. WHAT IS THE SOLUTION TO THIS PROBLEM?
Thanks for visiting FixYa!
When the video freezes and the little icon starts to spin, this is called 'Buffering.' It's normal for some phones due to network limitations.
Video's from You Tube and other streaming media send information to your phone in 'packets.' And sometimes, the phone is limited in its bandwidth. (The speed that the phone can download streaming media.) from your cellular service provider. This happens especially if there are several users, using a cell phone tower at the same time. Or, if your cellular company places network limitations on all its customer's use of streaming media.
Your network provider sets the bandwidth for not only your phone but all phones on their network.
And, they have been allowing less and less bandwidth in the past year. To get more bandwidth you only have one option.
Option 1) If you're lucky enough to be in one of the new 4G areas, purchase a new 4G phone. This will almost double your bandwidth and speed. And, video's can play without having to buffer the Data.
Feb 19, 2011 | YouTube Computers & Internet
We installed these units in a school they should support 64 users they will not . is there a setting in the unit to that you can change to get the 64 users?
It should but not simultaneously - the bandwidth of your Internet Service Provider is usually what limits the Internet access of all users - determine from you ISP your bandwidth limitations.
Jan 29, 2011 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
My network is slow while copying/transferring file over the LAN, we have Linksys Switch 224G4P and Linksys Switches 2024 which are stacked. Is this a problem
It is difficult to have havy network traffic and not show anything. The stacking should not be a factor, it is the actual file movement that is causing this, and there may not be a way around it. One possibility is to limit the bandwidth of the file transfer, but that just makes IT take longer....
It is difficult to repair around factual reality.
Jan 23, 2011 | Linksys SRW224G4P 24-Port Ethernet Switch
I just bought a belkin play 802.11n wireless adapter, its only running around 50-100kb's my belkin router is fully capable to be running at way way higher speeds,,,please help me,, its a brand new...
What internet package do you have with your provider? Are there other people or computers using the network? Is there a bandwidth limit on you MAC address?? These are common reasons that it's so low.
Nov 02, 2010 | Belkin Play Wireless USB Adapter (F7D4101)
The internet speed is slow.. connection is in & out
Here's another one.. to take the 20% bandwidth Windows is stealing from you. You'll love it! This guide teaches you to counter one of the main problems any Internet User may face - Slow Internet Speed! As simple it sounds, its as simple to increase it!
addthis_url = location.href; addthis_title = document.title; addthis_pub = 't1ma';
1) Go to Start>Run. Type in “gpedit.msc” (Without the quotes, duh!). (This opens a “Group Policy” window. If you're like me, you wont be interested in what it actually is, but what it can actually do for you.. Right? Anyways..)
2) Follow this path: Local Computer Policy>Computer Configuration>Administrative Templates>Network>QoS Packet Scheduler>Limit Reservable Bandwidth>. If it's disabled or not configured, change the settings like the one below: bandwith.jpg
Like the above screenshot indicates, select "Enabled" and set the Bandwitdth limit to 0%.
Why did we do that? Simple, like I said before, Windows is silently eating 20% of your bandwidth. I emphasize on the word “silently” - The explain TAB of the above window proves it. This is what it says:
Determines the percentage of connection bandwidth that the system can reserve. This value limits the combined bandwidth reservations of all programs running on the system.
By default, the Packet Scheduler limits the system to 20 percent of the bandwidth of a connection, but you can use this setting to override the default.
If you enable this setting, you can use the "Bandwidth limit" box to adjust the amount of bandwidth the system can reserve.
If you disable this setting or do not configure it, the system uses the default value of 20 percent of the connection.
Important: If a bandwidth limit is set for a particular network adapter in the registry, this setting is ignored when configuring that network adapter.
Warm regards,
Anirban Mazumdar
Nov 05, 2009 | Computers & Internet
Internetrouter speed not equal
Although the router shouldn't allocate bandwidth like that, remember also that your broadband has limited bandwidth as well. What I mean is your DSL or cable modem only has a limited about of bandwidth coming in from the "outside world" to your router, which then distributes it internally. That said, that doesn't sound like much of a load, depending on what type of broadband you have. Have you checked for: a) FW updates for your router? b) driver updates for your network cards? Additionally, are you sayding from the statement "I used wires on this wireless router" that both systems were using hard-wired connections rather than wi-fi?
Apr 15, 2007 | D-Link AirPlus DI-524 Wireless Router
Linksys Wireless-G WRT54G Router Logo
333 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
