Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Our Kenmore 665 was leaving white flecks on dishes and glasses
Our Kenmore 665 was leaving a film on the glasses and so we ran a vinegar rinse. that cleared up the film a little on the next wash. however, we are still getting little white flecks on the glasses. When I rub the flecks with moisture, they dissolve so I assume it is soap. How can I get rid of these flecks? We have added the special rinse solution.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Apr 24, 2010
The dishwasher is working, but there is a soap like film left behind on the dishes, glasses and silverware. It's a Kenmore dishwasher.
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Hope this helps... Please post back if more information is required.
Daniel
Jan 07, 2011 | Kenmore Dishwashers
New Kenmore 13743. Many of the glasses come out with a white film on them. Called the local Kenmore (Marshall at 1-800-469-4663) repairman on the advice of my salesperson. He said that he has frequent...
Have you tried cleaning a single glasses with vinegar. Take a glass, soak it in vinegar for a couple hours, wipe it dry and see if the film goes away. If it does you know vinegar will work to help. I use vinegar with every wash now cause the film builds up quickly. If the film doesn't go away then it is likely that the glasses are getting etched by a corrosive detergent.
Dec 17, 2010 | Kenmore 13743 Staimless Steel Built-in...
I have washed and rewashed my dishes with no soap and my glasses have a horrible white film and any of my plastics now have white film almost as if the soap is not rinsing off. I have resorted to hand...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
l'l
Sep 25, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Getting a white film on all dishes and inside dishwasher.
You need to use a rinse agent and be sure the water temperature is between 120 and 140 degrees.
To determine if this film is removable, soak a glass in white vinegar 5-15 mins.If it doesn't come off, it is etching. Otherwise it is probably caused by the wrong amount of detergent or hard water.
You cant remove etching, but you can prevent it in the future by making sure the water temp is no more than 140 degrees,& do not pre-rinse dishes.
For both problems, if you have very hard water-over 12 grains- and adjusting the detergent amount don't work, you may consider getting a water softner
Sep 18, 2010 | Kenmore Dishwashers
White film especially on ziploc containers and utensils. Glasses come out spotted and clear glass dishes are streaked with a white film
Hi
Daniel
Aug 07, 2010 | Dishwashers
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
May 10, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
My Frigidaire dishwasher is leaving soap, a lot of soap, on dishes under where the dispenser dispenses. It just started hapening. Also, it has always left a light film on the clear glasses.
I scrubbed the screens with a brush and added two cups of white vinegar to the bottom of the washer, then ran it. Cleaned up nicely. I most likely will add a cup of vinegar once a week.
Sep 13, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
6 month old GE dishwasher now leaves heavy film on dishes...
As far as using the vinegar, this should be complete when there is NOTHING in the dishwasher. The idea is to remove the build up inside, not clean the dishes. Make sure to use only White Vinegar. Also, changes in the water of any kind can cause a build-up. Try using a little less detergeant and rinse.
Dec 29, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
