Question about Lenovo 3000 Y410 Notebook
Optical drive not detecting DVD's
My Optical drive is not able to detect DVD's but it is detecting CD's.
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 135 Answers
Remove Upper and Lower Filters in the System Registry
Posted on Apr 24, 2010
Restore dvd
Check the CD/DVD drives status in Device Manager.
  1. Click the Start button. In the Start Search dialog box, type dev, then click Device Manager.
  2. Locate the lDE ATA/ATAPI controllers. Click on the entry to expand the list and make sure there is not a down arrow in front of a device. If a device has a down arrow in front of it, right-click on the device, then click Enable.
  3. Make sure there is not an exclamation mark (yellow splat) on the device. If a device has an exclamation mark, right-click on the device, uninstall and reinstall the driver.
  4. Locate the CD/DVD-ROM drives. Click on the entry to expand the list and make sure there is not a down arrow in front of a drive. If a drive has a down arrow in front of it, right-click on the device, then click Enable.
  5. Make sure there is not an exclamation mark (yellow splat) on the device. If a device has an exclamation mark, right-click on the device, uninstall and reinstall the driver.
  6. Optical drive not detected
  7. Check BIOS setup to verify if drive is detected outside of Windows.
    1. Press the F2 key repeatedly as the computer starts.
    2. Locate the page where drives are displayed. This varies between different motherboards. Please reference your User's Guide for specific model information.
    3. Desktop computers: Refer to the Drive Configuration page (or similarly named page), or the Standard CMOS features page to identify all Optical drives that have been detected. BIOS Setup will present a table which matches drive ports (drive connectors on the motherboard) to drives detected at a given port. Example pages are linked. Reference the Product pages for the specific model.
      Notebook computers: Refer to the Main page of the BIOS to identify optical drives that have been detected. BIOS setup matches a Drive Port name to a drive detected at that port. Drive Port names (left side) vary per the following examples:
      > IDE Primary/Master: [HL-DT-ST DVDRAM GSA-T20N-] Left-Bay PATA: PHILLIPS CD-RW/DVD-ROM-(PM) Optical Drive: Optiarc DVD RW AD-7560A -(PM) DVD and CD drive names (right side) will include "CD" or "DVD" in the name.
    4. Inspect and reseat cables. Use proper Electrostatic Discharge procedures.
      1. Turn off computer and unplug power cord.
      2. Disconnect everything except the monitor and keyboard.
      3. Place computer on a stable work area with case cover facing up.
      4. Remove cover.
      5. Find internal drives.
      6. Inspect and reseat any cables to drives not detected. Click here for additional information about drives, motherboard connectors, and drive cables.
        • Check for broken connectors on drive, motherboard, and drive cables.
        • Check for bent or broken pins on drive, motherboard, and drive cables.
        • Check cable orientation.
        • If available, try a different cable. If drive works with new cable, the original cable is probably defective.
Dec 17, 2013 | Gateway MT6707 Notebook PC
Tip
If Cannot Boot to Media From Optical Drive
· Confirmed the CD is bootable and has been pressed commercially.
· Verified that the drive is detected by the BIOS.
· The drive is seen by BIOS.
· All onscreen instructions are being followed.
· Verified the boot sequence is configured correctly.
· Reset System Setup (BIOS) defaults and cleared NVRAM on your Dell Dimension system.
· Flashed the BIOS to the most current version available.
· Reseated the CD drive cables.
· Swapped with a known good drive.
· There is no drive available to swap.
· Replaced the optical drive.
Thanks and Regard
Dilip Bagdi
Technical Associate
on May 10, 2008 | Compaq (200356-001)...
My dvd drive doesnt work in my laptop
Clean the optical head of the DVD drive and try a DVD. If the DVD spins but does not detect, try with a data CD, if there is no reading then the chances are that the optical head is faulty.
If the DVD reads but does not play then the signal procesing section can be faulty. You might need to change the DVD assembly if the unit is out of warranty.
May 18, 2011 | Computers & Internet
My DVDRW doesn't detect any type of disk even all drivers are work fine
may be your dvd-rw optical head was broken that caused your dvd-rw can not read the cd or dvd
Mar 22, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
I have acer aspire 4520 laptop, now the laptop bios did not show any dvd-rw. but when i am not used that laptop two -three days then i show dvdrw detect automaticlly. but then use dvdrw with in one hour...
-it is possible that you the optical drive is loose. That can be resolved by re-seating the drive itself.
-first, shut the laptop down, unplug the AC adapter if it is plugged-in then remove thte battery pack of the laptop.
-you need some small philips head screw driver to unscrew just one screw that holds the optical drive located at the bottom of the laptop. You may need to consult the user's manual of the laptop.
Feb 17, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
.i have got a preserio
CD/DVD issue
> is it an internal cd/dvd drive or external cd/dvd drive
> INTERNAL DRIVE
> ask for lights or glowing (optical drive lights)
> check whether the cd/dvd is getting detected
> For that click on my computers
> c- Drive and d- drive and also cd-dvd need to be detected (but in this case you will not find cd-dvd drive)
> Now follow the LOGIC FLOW
> Now need to do SYSTEM RESTORE (start> all programs> accessories > system restore)
> After the system restore
> switch off the laptop
> Now try and get in to the BIOS
> need to do BIOS default and BIOS update
> Now un-install and re-install the drivers (CD/DVD drivers)
> Start search > type Regedit
> Now try to locate H-KEY-LOCAL-MACHINE
> There would be a positive symbol (+) beside this
> Just need to click on that (+) symbol
> locate a folder which says SYSTEM
> Beside the SYSTEM there would be a (+) symbol
> Now locate CURRENT CONTROL SET option
> Now there would be (+) symbol beside the CURRENT CONTROL SET
> Now locate folder CONTROL
> There would be a (+) symbol beside the CONTROL
> Now click on the (+) symbol
> Now to locate CLASS
> Now try to locate an ALPHA NUMERIC NUMBER ends with --- 965
> Now click on the ALPHA NUMERIC NUMBER which ends with ----965
> Now look at the right side partition of the screen you can see a EDIT MENU
> Now try and locate the UPPER FILTERS OR LOWER FILTERS
> right click and DELETE THE FILTERS
> If you find both then DELETE BOTH
> Now just RESTART the laptop
> Now check in laptop whether the cd/dvd drivers are detected using the MY COMPUTER
> If it is detecting now try playing the CD/DVD
> If still NOT ABLE TO PLAY
> Reseat the CD/DVD tray
> After RESEATING the cd/dvd tray if not able to play
> Now PERFORM THE RECOVERY
Dec 07, 2010 | HP Compaq nx6110 PC Laptop
Unable to detect cd/dvd writer
check the status of your optical drive on the bios whether it is detecting or not
Sep 04, 2008 | HP Compaq Presario V6000T Notebook
DDW-081 CD\DVD Recorder can't read CD
It is possible for your optical drive to read only DVDs and not CD. This is most likely a fault with your drive and may need a repair or replacement.
Aug 24, 2008 | Computers & Internet
Cant instal as have no installaltion cd
i have to down load pictures from lg 195 set through computer whcih driver i have to intall
Aug 20, 2008 | LG GCC-4522B (0048231293594) CD-RW/DVD-ROM...
Lenovo 3000 Y410 Notebook Logo
71 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
