Question about Konica Minolta DiMAGE G500 Digital Camera
Dimage G600 won't read memory card
When I turn on my camera, the screen displays "no card." The card itself is fine, as I can put it into any other camera and all my pictures are there. And if I take a card out of another camera and put it into the G600, I get the same message. So I know it's the camera and not the card. I have tried cleaning the contacts, but that doesn't seem to work. Could this be a software issue? Or is my camera kaput?
SOURCE:
  • 255 Answers
SOURCE: Camera won't turn on
Turn the camera off. Take out the card. Take out the battery. Put in the card. Put in the battery. Turn the camera on.
Posted on Sep 13, 2005
SOURCE: dimage z1
I have the same issue and am trying to fix it myself. The suggested solution seems to be reformatting, but making sure that you use FAT format and not FAT32 which is selected by default. I will try this myself later Aodh.
Posted on Jul 11, 2007
  • 59 Answers
SOURCE: "No Card" showing in screen
Check the lock slider on the memory card. it will be on the side. if that fails connect your mem card to a pc and format it.
Posted on Apr 04, 2009
SOURCE: Konica Minolta Dimage Z2 camera will not read any SD card
I havw a konica minolta maxxum 5 d camera the card does not read what can I do
Posted on Jul 11, 2009
SOURCE: Konica Minolta Z2 SDHC reading card
Spare yourself the trouble. I had researched it (I thought) and got one, and stuck it in. The screen read: "Unable to use," It continued to read this, even after I formatted the card, so I ended up giving it to my brother, who has a Kodak camera. Sorry!
Posted on Aug 13, 2009
Shutter-release button doesn't work
The manual only can give two reasons why the camera would not take pictures.
One, there is no memory card placed.
Two, the memory card is full.
You are sure you have placed a working empty memory card.
If you did save all the pictures on the memory card to a computer, try formatting the card in the camera.
When you are pressing the shutter release button half, does the camera say it is focused correct? light bottom corner of the display.
Your camera has a setting to take pictures with a remote control. Did you put the camera in that setting? Read page 76 of the manual.
success
Jan 16, 2014 | Konica Minolta DiMAGE A200 Digital Camera
replace batteries and check again
Jul 03, 2012 | Konica Minolta DiMAGE G600 Digital Camera
Memory card with pic is in my camera but I can't bring them on the screen. it reads: unable to display. how can I see what's on the memo. card? Thanks.
Open them up on your computer.
If the files names have been altered they are no longer readable by the camera.
You can either down load them or pick up a flash reader to to see them.
Feb 28, 2010 | Konica Minolta DiMAGE X50 Digital Camera
I cannot get my konica minolta dimage g600 to accept sd card
Hi
the following memory types are supported byt your camera
SD (Secure Digital) Memory Card / MultiMediaCard (MMC) / Memory Stick / Memory Stick Pro
Do you have a card reader on your computer? We could format the card on the computer and then see if it works with the camera.
Can you tell me the size of the sdcard?
To format the card on your computer plug it into the reader, open my computer and find the card from there, ones you have found the right one from my computer right click and select format, Try formating the memory card to fat 12 or 16 and then when the format is complete insert it into your camera again.
(turn off the camera, insert the card, turn the camera on)
If the memory card still doesn't work plug it to the computer again and this time format it to fat32.
If this ia new sd card with alot of storage do you have a smaller card that already works on the camera?
Apr 13, 2009 | Konica Cameras
Apr 04, 2009 | Konica Minolta DiMAGE G400 Digital Camera
Z3 will not accept a 2g card
The Dimage Z3 accept SD cards up to 1GB (Minolta says 512 Mb, and sold it with 16Mb). This camera is 4MP , and uses less memory on card, therefore a 512MB card will be enough for it.
SanDisk Flash memory card - 512 MB SD Memory ...
from $13 - 20 stores
PNY Flash memory card - 512 MB SD Memory Card ...
from $3 - 2 stores
SanDisk SD Industrial Flash memory card - 512 ... from $14
Here 1 Gb, try at your risk, but they normally work:
1GB micro SD memory card for Konica Minolta ...
£6.90 - www.mobile-laden.co.uk
1GB Flash Memory Upgrade Card for Konica ... £3.44 - Memory Express
Here review: Steves Digicams - Minolta DiMAGE Z3 -
Mar 31, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
Error code S0042, DIMAGE G600
The S0042 error code relates to a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. Let me know if it worked!
Feb 14, 2008 | Konica Minolta DiMAGE G600 Digital Camera
Formatting problems
Try formatting the card on a computer than again on the camera. If you don't have success formatting the card with a computer than it is a pretty sure thing that there may be something wrong with the card.
Jan 18, 2008 | Konica Minolta DiMAGE 2300 Digital Camera
DiMage Z6 turns off when trying to view pictures
I posted this on another section:
My Z6 worked flawlessly for over a year, then suddenly started shutting off for no reason. Tried new batteries, etc. The problem turned out to be the memory card. My advice, buy a GOOD card instead of a new camera! Keep in mind, flash cards DO have a "life" to them - meaning they can only be used / erased so many times before they will cause errors (so don't buy a used card off of ebay - no matter HOW good the deal seems). If your shutdown problem started with a "unable to read card" warning, then its the card. The camera is actually "protecting" itself by shutting down. Good luck!
Nov 25, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Sep 13, 2005 | Konica Minolta DiMAGE Z1 Digital Camera
Konica Minolta DiMAGE G500 Digital Camera Logo
119 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Ekse
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
