Question about Kohler Home
Shower stall in master bath of a 15 yr old home. the shower started having water problems after about 1 year, leaking water onto the drywall next to the stall. we have tried everything-recalking, sealing the grout, checking plumbing to see if it was leaking. about 5 years ago, we took the whole shower down to the studs and started over-we retiled, grouted, sealed, and calked. water problems again with wetness on the drywall. we pulled out the calk to recalk again, the shower has not been used for 3 days, and water is still seeping out between the tile and shower pan. who should we call to fix this problem?
  • 2,100 Answers
Did you use plastic pipe? What about the shower head? Does it have a rubber o-ring in it? Pull the pipe out of the wall at the shower head and peek inside for the o-ring. If it is there, just snug up the pipe, do not over tighten. We were ready with crow bars in hand to destroy a brand new shower we just finished, because we thought we had w broken pipe, Then the owner says he torqued up the shower head as tight as he could and I read where it had to be just finger tight. One more place to check is the faucet itself, take off the trim ring and look in there for drips. It could be filling up the wall cavity and stay wet for days. I would take apart the drywall on the other side before busting up the tile again. Check it out.
Posted on Jun 08, 2010
Can you please give me the e mail address to contact Niagara as you suggest in your answer to my question as I can't find one but assume there is one as you recommended it. Thanks.
Hello Irene
You need to make this request in the original post under Tom's reply to you. You will see the word COMMENT, click on that and Tom will get a notification that you require further help. Fixya gets 9 million posts a year so the chances of someone seeing it as slim to none.
I am thinking one of these links will help you though.
Meynell Niagara (Niagara) shower spares and parts ' Meynell Niagara ...
https://www.showerspares.com/meynell_shower_spares/.../meynell_niagara_niagara/
  1. Cached
  2. Similar
Buy Meynell Niagara shower spares online. All shower spare parts for the Meynell Niagara in stock with same day despatch from the UK's #1 shower spares ...
Meynell Niagara 2 (Niagara 2) shower spares and parts ' Meynell ...
https://www.showerspares.com/...shower_spares/...all/meynell_niagara_2_niagara_2/
  1. Cached
... Niagara 2 shower spares online. All shower spare parts for the Meynell Niagara 2 in stock with same day despatch from the UK's #1 shower spares retailer.
Glass Inc,Niagara Falls,Glass,Showers Stalls,Shower Doors,Home
www.glassinc.ca/
  1. Cached
  2. Similar
Niagara Falls, Ontario, frameless shower enclosures, frameless shower doors, shower stalls, mirror, backsplashes, back painted glass, St. Catharines, Home.
Shower doors, bath screens - Niagara System Ltd.
www.niagara-wellness.com/productcategory/shower.../shower-doors-bath-screens/
  1. Cached
  2. Similar
Home/Shower enclosures/Shower doors, bath screens. Showing all 6 results. Default sorting, Sort by popularity, Sort by average rating, Sort by newness, Sort by ...
Here is the link to your post.
My Niagara bifold shower door fixtures are broken Is the Niagara company...
Oct 30, 2016 | Computers & Internet
What is causing air in my cold water line and how do I fix it?
try running all the water in the whole house at once. all toilets. outside faucets, washing machine, ect...
assuming you have no leaks.
Aug 25, 2014 | Home
Should i use the same drywall in the bathroom as in the rest of the house?
I recommend using MR (Moisture Resistant) drywall for the bathroom, and possibly for the basement if there are moisture issues. It is not much more expensive, and it can save you a big headache later
Jan 16, 2013 | Drywall
Why does water suddenly go cold during shower? It only happens in master bath... guest bath shower does not cause same problem. I have to go outside and unplug and plug back in heater to get it to start...
Try running the hot water in the sink while you have the shower. If the water in the shower stays hot, then the problem is not enough flow through the water heater to keep the heater running. I am guessing that the master bath is further away from the water heater than the guest bath. If not I would check the shower nozzle in the master bath to see if it is clogged a bit or if it is a water saver nozzle because this will slow down the water volume and then cause the water heater to shut off the heat.
Feb 24, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
When i move shower valve to hot, the water pressure drops. There is more cold water than hot. I have changed my moen valve before and this still happens. Good water any where else in the house including...
probably have a kink on how water line feeding valve..if possible to cut drywall bhind tub valve and inspect pipe at bottom plate...moen faucets are equipped w/ anti scald device, pressure balanced (newer models) and this could cause cold water to overwhelm hot water...
Nov 20, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Can i use the timer for a water headter to trun on and off
Paragon 8145-20 is a 240V defrost timer
It is probably not best choice for water heater timer
Timer initiates defrost cycles each 4 hours.
A water heater timer should have more scheduling options.
-For example estimates show average run-time for water heater is 3 hours per day, depending on incoming water temperature, thermostat setting, and number of gallons used.
-To save money using water heater timer, you have to schedule times carefully so water heater runs less than 3 hours per day.
-Now your average electric water heater heats about 20 gallons per hour.
-Average shower uses 4-9 gallons hot water, so water heater needs to run 15-30 minutes (15 summer, 30 winter)
-Average bath uses 12-15 gallons hot water so water heater runs 45-60 minutes
-But lets say you run water heater for 1 hour and make 20 gallons of hot water. Then you take a shower, expecting hot water to remain in tank.
-Here's the problem ... cold water entered the tank to replace the shower water ... and the new cold water is cooling the rest of the tank.
-So a timer means scheduling hot water to match shower and bath events. For example taking shower and bath in immediate succession.
-Or set the timer for each individual hot water event ... for example set timer for 1/2 hour for shower, and later timer turns on 1 hour for bath, or 1-1/2 hr for 2 baths, etc
-> The flexible programming described above is not a characteristic of defrost timers.
I suggest Intermatic WH-31 240V or Intermatic T-104 240V or GE 15207. These are mechanical repeat-24 hour timers with manual override where each day has same schedule.
Digital programmable timers like Intermatic EH40 offer 7-day, 40 event programming. Weekends and weekdays can be different.
To see several box-type timers:
http://waterheatertimer.org/Boxtype.html
Sep 29, 2010 | Paragon 8145-20 Defrost Timer
We have a home that is 3 years old. We never used the 3rd bathroom shower until today. We have a Moen single knobe shower/bath valve. To get water from the faucet you pull the knob out. To adjust the...
Remove handle to gain acess to the temperature limit stop. Remove handle and pull out handle adapter kit and next there is a dail that can be adjusted to control the water to balance the temp. It could have been installed wrong, pay attention to where it is now and pull it back to it disengages out of the stem and move it counter clockwise a little and reinstall. Put handle on and test water for correct movement.
Go to link below for a part's diagram if needed.
TO ORDER PARTS CALL: 1-800-465-6130
www.moen.com
Aug 15, 2010 | Moen & Posi-Temp Single Handle Shower Or...
When I turn the water on for a bath only water
the water deverter that makes water come out the shower head is probably in need of repair. or replaced.
Dec 04, 2009 | Moen & One Handle Tub & Shower Faucet
Water leaks from shower head while bath faucet is running
sometimes there are orings or gaskets that get tore in assembly one of those may be bad,or if it is around the threds you might try wraping teflon tape around the thred once or twice.hope this helps
Jun 14, 2009 | Water Pik WATERPIK SHOWER HEAD COMBO PACK...
Leak in the shower is leaking water through the ceiling
SInce it is wet both under and behind the shower I would rule out the drain floor pan and drain system and think it most likely to be the pipe leaking from the mixing faucets to the shower head. Find studs directly behind shower faucet, n each side. Locate the center of the studs and put vertical lines up and down on the center line of the two studs closes to but outside the shower  faucet on each side. Approximate 6 inches or so  up and down for the height of the shower faucet (Valve, not head) Put Horizontal lines across between the two line at both the top and the bottom/ You now have a square.Using a Razor knife(Sometimes called a box knife, stanley 99a for example) cut into the lines of the square back and forth as deep as you can. Cut an x  acrossthe square corner to corner again as deep as you can . Lightly hit the center of the x until the drywall caves in . Cut the remaining drywall out for the square. Now while  the shower is running you will be able to see whee the leak is. Use pipe seal after disassembling the loose fiting or repair the leak iun what ever manner is necessary. Replace and repair the hole made in the drywall  with another piece of drywall, tape and joint cement. .
Feb 27, 2009 | Home
Home Logo
215 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
