Question about Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher
Whirlpool gold quiet master runs but does not clean
It makes a very loud sound as if it is struggling to run
    President:
  • 949 Answers
It could be that it is not getting enough water or the pump is restricted.
Start a cycle and let it run for a few minutes. Carefully open the door and see how high the water is. It should be about 1/2" below the heater element in the bottom.
If this level is okay you may want to try and clean out the sump area, here is a link to directions on that.
Let me know it this helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Posted on Apr 25, 2010
My 6 year old Whirlpool dishwasher is loud
This is a bad wash pump. Looking at about $175 for just the sump assembly. You could do it yourself, but unit would need to be uninstalled.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
My whirlpool gold dishwasher makes a loud humming sound the entire loooong time it runs
possibly a bad bearing in the pump motor assembly,, most had a five yr parts warranty of out of warranty the parts usually run 100-300 dollars
Feb 03, 2010 | GE Washing Machines
Water remains in Whirpool Gold Quiet Partner dishwasher
sounds like an issue with the drain pump, disconnecting the drain hose fromm the trap and run the unit, pointing the disconnected drain hose into a bucket. You should get a fairly strong stream of water until most of the unit has drained, if not you either have a blockage or ,with the grinding sound, a bad pump.
Mar 11, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool gold Quiet Partner III is really loud.
now you'll be able too hear under the tub if motor bearing was the noise.put a long tool to the motor and close to you ear,see if that gives you a clue[i don't want you to give up on it if its not the motor]if was to buy that motor wholesale it would be around 50 bucks or so ,retail about 100 or so.so if replacing depends on the shape of the rest of the unit.[i have sold and installed many]new dishwasher on sale 300$ or so,plus your time to install.but if new its a forsure thing.so depends how much motor,how sure you are wiill solve problem,what shape unit in.hope that helps. God bless ,tom
Jan 10, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Wet dishes
Hello
The heat dry button must be lit up or you are using air dry instead!
ican
Please leave a rating before you leave
Dec 10, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher Logo
122 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
