Question about Hitachi Performa CP-RS55 Multimedia Projector
Hitachi CP R555 Multimedia LCD Projector
Hi i have a Hitachi CP R555 Multimedia LCD Projector i have chance the lamp but i need the reset settings can u pls help me
  • Anonymous Mar 31, 2014
    Turned projector on and it has a huge circular spot on the screen, lamp?
  • 563 Answers
Hi there
In your Menu options there is a subfolder where it either reads lamp or lamp timer.
Scroll down to it and hold down you right or left arrow key on the Projector for a couple of seconds.
Posted on Mar 26, 2008
How do I change a bulb in a Hitachi CP-S210 Multimedia LCD projector?
There will be a panel that holds the lamp module in, usually on the base of the unit. Once removed the lamp is usually held in with two screws mounted on the body of the lam. Once replaced, ensure the lamp is correctly fitted and the panel then switch on and reset the lamp life in the settings menu.
Good luck, hope I was of help to you
Aug 04, 2011 | Hitachi CP-S210 Multimedia Projector
Lamp turns-on and off
lamp ballast and/or power supply is going. the ballast has to boost the charge up to 140 vdc, and after it's up to it full strength, it drops down to 40vdc to maintain. if the ballast can't get up to the proper voltage, it shuts down. or the lamp itself will not hold the voltage, and therefore needs replacing.
Aug 10, 2009 | Hitachi Performa CP-RS55 Multimedia...
Hitachi projectors cp rx60 cp r555 same remote control?
Specifically i don't know. What i do know is mfg's use the same codes, whether they map them to the same functions across a series of remotes can't say for sure. Experiance tells me it will be just fine...
Jun 10, 2009 | Hitachi CP-S335 Multimedia Projector
I need to reset the lamp hours on an Hitachi CP X380 projector
hold rown reset on panel for about 3 seconds, wait for display, press reset again and select 0.
Mar 24, 2009 | Office Equipment & Supplies
Hitachi cp-rs55 not working,tic.tic.... noise coming from project
make sure you reset the lamp timer. Manual has the steps. Hitachi Performa CP RS55 3 LCD Projector
if the timer is reset, try cleaning the color wheel. Optoma HD20 Projector Cleaning this video is for an optoma but the color wheel is cleaned the same way in most DLP projectors. Dirty or dusty color wheel sensors cause the projector to shut down and act like its the lamp.
Feb 02, 2018 | Hitachi Performa CP-RS55 Multimedia...
Lcd projector beeps every minute
Hi Jenrowe
Try resetting the lamp and filter timer , if this still occurs reset the whole mashine.
Apr 24, 2008 | Hitachi CP-X275 Multimedia Projector
Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Apr 22, 2008 | Hitachi CP-S335 Multimedia Projector
Reset
Hi there
Check if both your filter timer and lamp timer is reset.
If it is then there is a Mainboard fault and it will need repair or replacement.
Feb 26, 2008 | Office Equipment & Supplies
Hitachi CP-X250 LCD Projector
clean filter and reset the filter timer by advanced options filter timer and hold reset till menu shows then arrow up and it will zero out.
Oct 19, 2007 | Hitachi CP-X250 Multimedia Projector
Hitachi Performa CP-RS55 Multimedia Projector Logo
1,231 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
