Question about Asko D3251HDSS Stainless Steel Built-in Dishwasher
On more than one occasion the pump that gets rid of the water kee
Ps running. I seem to be building up water in the bottom of the machine.
  • Asko Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your problem...
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Apr 27, 2010
Standing water in front loader how to fix
More details about where, when, how (and how much), etc., might be useful.
I'd check easy things like the drain hose, to make sure it's not clogged. But the most likely thing is that the filter cup has gotten clogged or the drain pump is dead.
To check out: Get a wet/dry shop vac. Hook it up to the drain hose to suck the water out of the machine and save a lot of mess.
Remove the bottom front panel. The drain pump on my Duet is front center bottom... easy to get to. There's a plastic handle to unscrew if I recall correctly, which brings out a sort of plastic cup filter. You might find enough change to buy yourself a cup of coffee. Clean it out. If it wasn't really clogged up, the problem is either something stuck in a hose, or a failing/failed pump. Check the hoses first; if it's not them, I'd order a new pump.
May 27, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Will I still get coffee if the pump is broken. The machine is leaking staem and water underneath and I beleive it is the staem valve but a 'dodgy' coffee machine repairman is telling me it is the...
I am an expert espresso certified man. First of all your repair man is wrong. Let me explain. If you are getting steam at all, then your pump is not broken. This is the way it works, you have water in your machine, it goes into a area where it heats the water by heating elements, then as it heats it builds pressure by air and heat. The machine has a water pump in it, that operates by of course electricity, it pumps the water that is heated by the elements through the machine to of course make shots of espresso. The steam part is simular as it goes in a area, the gets hot and produces steam from the water, like a iron would of press kind of method. THE MACHINE will not make coffee or steam if pump is not working. If you turn machine on, and hear it humming or running, when trying to make a cup, then motor is running, if you turn it on and try to make a cup of coffee or steam and hear nothing at all, then pump is not working. If your machine is leaking under machine from from the steam valve, means it would not do that if pump is not working. Sense it is leaking, this tells me it is clogged. Most likely your need your machine cleaned good, that means descaled. Clean hoses, use small needle to poke in end of steam wand to clean out good jet air holes and basket screen. Find your manual, and it should tell you how to properly clean your machine, and even can use can of compressed air, that you can spray in hoses. It appears to be it is clogged, and when the pump or lines are clogged , it will back up like a clogged toilet and flood area around base and underneath. This whole problem is a cleaning problem, do to a clog or build up. I hope this. PS no if you pump is out or clogged, you would not get coffee as it need to the pump to work (unclogged) to push the water through the heads. Thanks Mike
Sep 15, 2011 | Gaggia Titanium Espresso Machine
HI, The machine displays "EFO"... We put the water out as described on your site but it seems the code "EFO" is still in memory (there is no more water inside, but each time we start a new program, the...
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 15, 2010 | AEG Lavamat 88840 Front Load Washer
My clothes have a musty smell after being washed
run a wash load (no clothes) with 2 cups of Clorox brand bleach and use hot water, that should help.
Nov 13, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Top wand does not spin
You may have a water volume problem.
The water fill sequence on most washers is timed. Insufficient water at the bottom of the washer will cause the pump to cavitate.
Ensure water is filling to just under the heating element.
You can fix this by isolating the water and electricity then remove the fill solenoid. Inside the solenoid is a top hat filter screen. This screen captures sedement.
Once the sedement was removed on my washer the wands turned
My machine also had a check valve on the bottom near the back of the machine that was blocked.The valve needs to work freely in order for the pump to build pressure. The check valve can be removed from the top by turning the assembly counter clock wise.
Feb 01, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Can't get rid of E1 error on a Samsung front loader washing mach.
E1 : washing machine has exceeded a check time for fill, heat or empty.
Common causes for this are fill and empty problems, heater fault (or the wiring
to it broken), water pump open circuit (although that would stop the water draining too) Pressure chamber blocked or pressure tubing pipe looped below the pressure bottle, or a sticking eco ball in the sump hose (sludge and grease build up)
This error code is generic and vey common.Since you have tried the remedies.Try getting checked the internal wiring damage by professionals.I hope certainly hope the problem lies there.
Dec 09, 2008 | Washing Machines
Issue with front loader going through spin cycle
you can try removing the lower acess panel(2 screws along the bottom of front) behind the panel youll see the pump assy mounted to the right, disconnect the hoses and check for debris in the hose assy. the machine will not spin if it cant get rid of water, and it cant get rid of water with a clogged hose. very commom.UNPLUG UNIT FIRST PUMP WIRES ALWAYS LIVE!!!!!!!
Nov 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Hi i have a technik dishwasher it has flooded the kitchen, i managed to get all of the water out of the machine but now the pump seems to be running all of the time, someone has told me there is a flood...
drain pump is running all time because there is water in bottom tray. tilt machine back to 45deg and water will flow out. otherwise, take front panel off and mop water out. alll that is required to reset flood switch is to get rid of the water
Jul 20, 2008 | Tecnik Dishwashers
My is70c tumble dryer is leaking water from the main filter at the bottom?
This model is a condenser dryer, at the bottom of the machine if you open up the flap you will see the condenser on the left hand side, the manufacturer recommends that you clean this unit once every month and also empty the reservoir and clean the fluff filter after every use. While this may seem like a lot of hard work there is a very good reason for this. I suspect that your problem is due to a build up of fluff and or gunge in the condenser and bottom of the machine. Remove the condenser and give it a good clean of all fluff, you can run water through it either in the sink or bath as the best way to do this it is very fiddley using just your hands. Next check to see if there is a build up of water in the back the machine where the condenser usually sits, you will have to lie on your stomach and reach into the back of the machine (OBVIOUSLY ENSURE THAT YOU HAVE UNPLUGGED FROM THE MAINS SUPPLY BEFORE YOU DO THIS!) along the floor of the machine you will feel a channel cut into the plastic which runs into the sump at the back of the machine, if you have not cleaned the machine properly this is probably blocked and is the culprit. With this blocked the water is unable to travel to the pump that takes the water from the condenser into the resevoir at the top of the machine, and therefore it stays in the machine and can get thrown about onto the electrics and could cause the machine to cut out and trip your electrics! If this is not blocked check the black rubber pipe leading from the pump to the reservoir is not blocked, failing that perhaps the pump (in the plastic case at the back of the machine) is faulty and will need to be replaced.
Apr 29, 2008 | Whirlpool LER4634J Electric Dryer
Bosch condenser tumble drier.
Maybe the pump is bad. With the power off, remove the power wires from the pump terminals. Then connect the power wires to an electrical tester light or meter. Then turn on power and run the machine in a dry cycle. If you get power, then you know that power is getting to the pump abd the pump is bad.
Feb 11, 2008 | Dryers
Asko D3251HDSS Stainless Steel Built-in Dishwasher Logo
108 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
