Question about Canon PIXMA MP460 All-In-One InkJet Printer
Placement of the ink is confussing
The area for the ink seem wrong. We placed in the in slips and it is loose
Harley drive belt wont stay tight after adjustment
Hi Djpiccir, sounds like your axle nut is bottoming on the axle shoulder due to wrong washers or placement of washers. For more information on your problem please visit the website below and good luck. http://www.stcharlesharleydavidson.com/OEMpartfinder.htm#/Harley-Davidson%C2%AE/FLHTCU_FC_ELECTRA_GLIDE_ULTRA_CLASSIC_(EFI)_(2007)/REAR_WHEEL/99456-07B%5CFC/99456-07B%5CREAR%7C~WHEEL%5CFC
Apr 21, 2012 | 2007 Harley Davidson FLHTCU Ultra Classic...
When it is cool my car gets about 25 miles to the gallon. When it is hot and the AC is on it gets 33 miles to the gallon. I have changed out the thermostat. What esle could be wrong? Thank you...
Thanks for choosing FixYa and welcome. You should loose fuel milage when the A/C is on because you use more gas. Is it the other way around? Sorry for the confussion.
Jun 05, 2011 | 2001 Ford Focus
I changed the battery to my armitron now watch and can't get the back on. any suggestions?
A replacement battery has be the compartible brand serial number to the watch may be new howevr least capable of displaying an functionality. Second, the new battery should not have been mixed up with the old in the process of performing the changes else the wrong one was returned into the watch. Reinspect the old and new batteries. Third, the battery has to be firmly placed into the socket area before current supply runs through the watch, perform an shuffle around within the socket to acquire is the new battery placement was least in firm grip at placement. Refering to the watch user guide on the placement of batteries to the watch is useful. Finally, consult with technician when necessary.
Jan 13, 2011 | Watches
I cleaned the belt area and removed all of the strings and fuzz. However, I am still smelling rubber burning from the vacuum.
This can be caused by a loose or worn belt that is continually slipping on the brush. It simply needs replaced with the correct belt.
It can also be caused by the belt being caught on something by the shaft. In this case, the power head needs to be taken apart to check for improper placement of belt.
The vacuum motor could also be overheating, which would more than likely be caused by a plugged hose. Disconnect hose from power head and vacuum, then try to roll a marble or small ball through it. Also, check the vacuum's hose port for a plug. Another area to check is the tube in the power head. Clear if needed before continueing operation.
Aug 22, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Installing a new color cartridge
Hi mariek2006,
Cannon printers usally the ink is housed underneath the top portion of the printer. To open the top, reach down under the buttons or display area,, and left up, a blue plastic piece will slide out and lock the top into place. Once that up, look inside and the ink cartridge will eventually slide over to the left side of the printer. Look left towards the silver bar and you'll see two plastic holders for the ink. Take the ink cartridge out, by pushing down on the top edge of the cartridge, then out. To replace them, remember to remove the protective seal on the ink cartridge and put the ink cartridge in by holding the ink cartridge at an angle that has the copper control slip pointing upwards. Make sure you put it in below the top ridge of the plastic holders. Then once you slip the cartridge into the holder at the upwards angle, pull up again on the cartridge to snap it into place. That's it your ink cartridge are reset with new ink.
Good Luck
and don't forget to leave a rating based on my solution.
P.S.
Don't forget to push the blue bar that is holding the top up in, and the top will slowly lower itself into place. Mark
Aug 31, 2009 | Canon Office Equipment & Supplies
Where do i change the ink on my canon mp830 pixma?
Hello paulphipps1,
That printer the ink is housed underneath the top portion of the printer. To open the top, reach down under the buttons or display area,, and left up, a blue plastic piece will slide out and lock the top into place. Once that up, look inside and the ink cartridges will eventually slide over to the left side of the printer. Look left towards the silver bar and you'll see two plastic holders for the ink. Take the ink cartridge out, by pushing down on the top edge of the cartridge, then out. To replace them, remember to remove the protective seal on the ink cartridge and put the ink cartridge in by holding the ink cartridge at an angle that has the copper control slip pointing upwards. Make sure you put it in below the top ridge of the plastic holders. Then once you slip the cartridge into the holder at the upwards angle, pull up again on the cartridge to snap it into place. That's it your cartridges are reset with new ink.
Good Luck
Mark
Apr 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Color
Recheck the placement of the ink cartridges. The black ink cartridge is larger; the cyan, magenta, yellow cartridges are all the same size.
When the ink cartridges were replaced, two or more may have been inadvertently switched or an extra yellow cartridge placed in.
Aug 04, 2008 | Canon BubbleJet i560 InkJet Printer
Help my CD's are slipping
i had the same problem earlier today. get a flash light with the printer lid up on the right corner should be a chuck of ink there remove that with a q tip and get some rubbering alcohol dip with q tip and clean the surrounding area you probably gonna need like 10 q-tips theres actually a sensor some where around there but i never seem to find it but most likely the run off ink is blocking the sensor from doing its job. once your done turn off the printer and unplug usb and power
Mar 17, 2008 | MicroBoards PF-2 InkJet Printer
Brother MFC 210C NOT Not Printing Color Properly
If the cartridges were in the wrong slots, it shouldn't take very long for it to clear up. What I don't understand is how it even ran with them in the wrong slots, but that's not the point.
Having corrected that problem, Have you run many prints after that? You may just have some remnant ink not completly out.
If thats not it, remove the cartridges, unplug the machine and very lightly dampen a lint free cloth with some alcohol and clean all the contacts in the machine and one the cartridges.
Then again run all the set up modes and see if that helps.
You should in no way have ruined the printer my having the inks in the wrong place.
One other thing you can try, And I do this to ink jet printers but hesitate to mention, but it does work.
Unplug the machine and remove the cartridges. Place some paper towels under the print head where the cartridges and slowly trickle some soapy cleaner, Like Fantastic into that area, then flush it out with some rubbing alcohol. Dry the area gently as best you can, and let the printer sit an hour or so to let any slight amount of liquid remaining to evaporate. Those inks can build up and clog that area causing lots of problems.
Feb 25, 2008 | Brother MFC 210C All-In-One InkJet Printer
Red is printing pink.
have u used this printer quite a bit....? if so the following may be the problem and I just did run across this recently in a printer we had in the shop....I recently read in one of my technical magazines that there may be a design flaw in the placement of the laser scanners and the openings that protect them....it seems that excess toner dust can readily get in to scanner area and specifically inside the scanner assembly and accumalate on the scanner glass and lens. Just cleaning through the opening in the back of the printer will not eliminate the issue. Machine will have to be disassembled, scanner removed and opened and the glass/lens cleaned with a q-tip....the placement of the fan (behind cartridges, lower right) seems to speed this process up and it usually becomes first notable with the magenta cartridge, seeing as it is at the bottom of the printer closest to the fan. Hope this helps..
Inkworks
Oct 04, 2007 | HP Color LaserJet 2600n Printer
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
13 people viewed this question
old marine
old marine
