Question about IBM ThinkPad A21m 2628 Notebook
Hi have an IBM A21 it will not power up, when pressing the start button the green battery lamp goes off and there is a small flash in the hardisk lamp, and I can here a small "click" the green battery lamp is back in a tent of a sec. Have mesured the battery and it seemes ok.
If it's not your battery, then it's possible that your motherboard has died (if it was the HD you would at least get the BIOS screen before it stopped). I suggest you take it in to a qualified repair center & ask them to give you an estimate of the repair cost. The A21 is an older model & you may likely be better off investing in a new laptop than fixing the old. Make sure you keep the hard-drive though as you will likely want to get your data from it!
Posted on Apr 24, 2010
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
IBM server x3400 not starting
This is a Planner issue (Mother Board) . Open side cover and investigate capacitor status . Probably some capacitors are bulged . Check it and replace if necessary .
Good Luck
May 16, 2012 | IBM x3400 Server
Could you please advise how to reset lamp timer on a fujitsu LPF 4800 when I turn it on the green light goes to red and the lamp light indicator goes to red too and blinks
hi
You can reset the lamb timer as follows.
While pressing the MODE button, press the POWER button three times.
all the monitors flashes for a few second , The lamp timer is initialized to[ 0 hours] .
ok
Dec 15, 2010 | Fujitsu LPF 4800 Multimedia Projector
When i try to turn my camera on it flashes a small red light and then it won't turn on, how do i fix this?
The Red indicator flashing in the Camera may be the Access Lamp or the Power Lamp. The Access Lamp is located below the Control buttons and the Power Lamp near to the power button. If the Access Lamp is flashing, it indicates that the Camera is accessing the Memory. Do not remove the Memory Stick or Batter while the Access Lamp is lit.
If the Power Lamp is flashing, it indicates that the Camera is turned on. If the Lamp is lit in Red it shows that the Battery is not having enough charge. Insert new batteries or charged Nickel-Metal Hydride batteries to resolve the issue.
You may also try power resetting the Camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally. If the issue persists, service may be required.
Thanks
Oct 21, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
System won't boot - show's green battery icon only
Contact with notebook repairing engineer. Might be coz of some short circuit, BIOS corruption or any malfunction of the hardware.
Regards;
Hassan
Jul 07, 2009 | IBM ThinkPad T42 Notebook
IBM thinkpad A21 won't start up
1# remove the battery from the thinkpad and ac adapter.
2# hold the power button for 40 seconds.
3# plug in the ac adapter and turn on the botton.
4# see it for works what trying to do to thinkpad is recyle the power .
give it a try and see if it work if it doesnt let me know
Nass
Apr 14, 2009 | IBM ThinkPad T21 Notebook
Sony KDF-46E2000 - Screen Goes Blank
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
Won't start up
Please check this thread, it may be one possible answer to your problem-
http://www.fixya.com/support/t944088-ibm_thinkpad_a22m_2628_power_problem
Aug 17, 2008 | IBM ThinkPad A21m 2628 Notebook
IBM T21 doesn't start
try to start it with the battery out by pluging it straight, the battery is dead and its causing problems
Mar 13, 2008 | IBM ThinkPad T21 2647 Notebook
My T22 unable to start
Hi Yamato,
It is possible that the battery has been so depleted that it gobbles up all the power from the charger/adapter and leaves nothing for the laptop to use. Perhaps what you can do are:
1. try and charge the battery at least overnight with the laptop off;
2. use the adapter/charger only and remove the battery from the laptop.
Hope this be of help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 10, 2008 | IBM ThinkPad T22 2647 Notebook
IBM ThinkPad A21m 2628 Notebook Logo
203 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
