Question about Vizio VW42LF 42 in. LCD HDTV
I HAVE A VIZIO 42' LCD TV WITH A 8' BLACK BAR RUNNING VERTICALY THROUGH THE SCREEN. COULD IT BE THE CONTROLER BOARD
    Guru:
  • 416 Answers
You panel has a TCON (timing control) board which feeds the panel connector (1 or 2) inside the LCD panel, the picture information is then broken down inside the panel assembly via a connection board. You have 2 options: Replace the panel or toss out the TV. If you are going to toss out the TV, you may as well make a project out of it and attempt to fix it... what's the worst that can happen? You break it? It's already broken. So here's what I would do. Take the TV apart (photograph as you go if you are worried that you will forget what goes where). Remove the LCD panel and place it in a clean area. I would clear the kitchen table, cover the table with a soft blanket and then place a bed sheet on top of that to keep the dust and fuzzies to a minimum. Place the LCD on your work area and patiently and carefully take it apart. When you get to the connector board inside the panel, disconnect the panel connection directly above the black bar (should be a hinge style connector, a tab will flip upward to release the ribbon cable) and then reinstall the connector. You need to be careful here, these cables can tear if you get too forceful with them. After you reinstall the cable, go ahead and reassemble the panel and then the TV. If this doesn't fix it, you are back to option 1... replace the panel or the entire TV. Option 1 is more often the TV as the panel cost is close to or more than the TV. Here's an illustration I made for you to give you an idea of what the connection board is doing:
Then signal comes in on the red connector from the TCON then goes out to the panel on the yellow connectors. This is just an illustration, your TV may be a bit different, but the principle is the same. I hope this was helpful, best wishes.
Posted on Apr 24, 2010
Testimonial: "I ALREADY DID WHAT YOU SAID AND EVERY THING IS THE SAME, THATS WHY I WAS WANDERING IF THE CONTROL BOAD COULD BE BAD"
  • Adam Halfhill
    Adam Halfhill Apr 25, 2010
    Not not the TCON, it's the panel. If you can't fix it by seating the connector above the black bar, your panel needs replaced.
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
How do i fix a vizio 42" tv with a black screen, no sound
THE MAIN BOARD AV BOARD HAS WENT OUT JUT HAPPENED TO ME TODAY
Feb 28, 2013 | Vizio Razor M421nv 42" 1080p Hd Led Lcd...
Vizio M420nv LCD TV Black Screen
lightning can do extensive damage to electronics equipment especially flat panel TV's. I would really recommend a professional diagnosis instead of board swapping. You could have several boards that are damaged!
Feb 13, 2013 | Vizio m420nv 42 in. LCD HDTV
I have audio but a black screen. Can you help?
Ur LCD inverter board is dead.Replaced this board will get ur picture back.It usally a long board.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for replacement.
Feb 15, 2010 | Vizio VO42L 42 in. LCD TV
Vizio VX32L HDTV10A
I had the same problem with my 32" Vizio lcd tv, I took it to a repair shop and they said it might be the motherboard but they didn't seem too sure about. I am considering ordering the motherboard and trying to fix it myself hope this helps.
Nov 29, 2009 | Vizio VW32L 32 in. LCD HDTV
Vizio 42" LCD screen is red where is should be black. It's only 3 months old!
It maybe a video board or LCD screen control problem. Best to use the warranty at this point. You shouldn't have to pay a dime for the TV breaking down this early.
Here's a link to help you get started on your warranty:
http://www.vizio.com/support/
Sep 09, 2009 | Vizio GV42L 42 in. LCD Television
The picture on my Vizio 42" flat screen suddenly shifted to a whitish pale color with ghostly looking images that look like negative film.
This is the fix for the Main board repair :
Locate IC 32 small 8 pin surface mount near top of Main Board and remove. Short pin 2 to pin 5. (pin 5 through 8 are together and pin 2 and 4 are together)
You will need a good TV Tech to do this for you.
Aug 04, 2009 | Vizio VO42L 42 in. LCD TV
No Screen or sound
there are two possibilities to this problem. First and cheapest way is to replace the main board. Second, replace the inverter board. This is the boards that are mounted vertically on both sides of the TV.
Jun 18, 2009 | Vizio VU42L 42 in. LCD TV
Vizio 42" lcd powers up with sound only - no picture
It sounds to me that the unit has a faulty inverter board which could be due to an overheated/bulged capacitor. I would send in a claim on it to the factory if it is still under warranty.
May 28, 2009 | Vizio VU42L 42 in. LCD TV
Vizio VW42LF 42 in. LCD HDTV Logo
656 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
