Question about Plumbing
Cracked housing on a 1 1/2 hp water ace pump.Model #r15l, are new housings available and if so were?
    President:
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Water Ace sells direct to the public. Call them at (800) 942-3343 for parts.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 24, 2010
  • Mar Panelo
    Mar Panelo Apr 25, 2014
    I just called that number and its not worth the money you have to pay including the shipping, more than the value of the whole pump itself. Isntead, they suggested to go to Tru-Value or Ace hardware stores.
  • Mar Panelo
    The part # to be exact is 26182D 020 - cast iron front volute.
Cracked water pump
You should be able to replace the housing if you contact the manufacturer.
Mar 12, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Need parts
you can try ace hardware, but i think these are throw away items. 1/6 hp is very small, probably less expensive to just replace it.
Nov 06, 2013 | ACE Submersible Utility Pump 1/6 HP 115 V...
I have a Flotec 1/2 hp jet pump. Is it posible to get just the pump housing. Mine froze cracked the housing?
Use Google and put in Flotec parts.
I did that and several parts dealers came up.
Pick one and put in your model number.
I'm sure you can find a housing, the pump that I looked at had one available.
Gary
Jan 29, 2011 | Flotec 1/2hp Cyclone Pump
Pump Housing is cracked. Can I replace the pump housing only?
To the best of my knowledge the housing is available seperatly but it is not cost effective in my estimation. I would try to use a epoxy type glue such as pro-poxy 20 or J.B weld and try to repair it. Hope this helps you and thanks.
Jan 02, 2011 | Simer ACE5S ACE5S Pump Well 1/2HP Ace 5S
Pump housing is cracked and lealing. Is there any
the pump housing is available through your local pool dealer. It is broken down into 3 sections the pump, housing and Pod.
The Pool Tech
Jul 01, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
What is the correct method to install water pump
Hello. Make sure the metal surfaces are all perfectly clean and sanded smooth with emery cloth. make sure the gaskets fit well. if not trim them. Finally if all else fails use some gasket cement to insure a leak proof water pump. This gasket cement is a common item available at most hardware and auto parts stores. Joe
May 07, 2010 | John Deere Tractor 50, 60, 70, ITJD10
Water is leaking from the base of the Badger 1. Appears to be coming out of the reset switch. Can i repair this?
There's only one repairable thing on a garbage dispostal, and that is where the pipe (drain) comes out. If it is leaking from there, it can be fixed. If not, it means the housing is cracked and you need a new one. PS don't turn the disposal on since it's leaking from the electrical connection!
Feb 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My pump is leaking from the housing, not at a joint, but from the middle, like the housing cracked, but it only leaks when it turns on.
My roof is the same way ... only leaks when it is raining. Can't fix it in the rain and can't find it in the sun.
For best results, replace the pump. You may find the parts from the manufacturer. As you replace the part, you will discover there is stuff inside that will not only revolt you, it will make replacing the cracked casting more difficult.
If it is a small crack, you might be able to patch it with a procuct called MarineTex available at Ace Hardware, or other fine store in your area. If you live in an area where boating is a big past time, look at the Marina for this product.
Oh, BTW, I might have called it the wrong name, it is a two part exply boat repair kit product. Expect to pay $20.00 for a small supply.
Thanks for your interest in FixYa.com
Jan 14, 2010 | Grundfos MQ3-45 1 HP Pressure Booster...
Water flows out the flange where the motor
dont no were you are,but did it freeze,loose,gasket trouble,is the centre housing cracked?
Dec 08, 2009 | Pentair Pinnacle 1 1/2 - Hp In Ground Pool...
Model 2305 pump. Housing is cracked. Can I buy
since the pumps cost is only about $40 i doubt that they make after market housings for it and i could not find any
Sep 25, 2009 | Simer 1/6 Hp Submersible Utility Pump
Plumbing Logo
738 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
