Question about Jenn-Air Cooktops
Jennair gas oven shuts off and does not work . after a short time, it seems to work . We had been occasionally getting a F1C code.. also fan has been running while oven is on. MOdel JGS0750ADW serial #16128007AB
  • 1 more comment
  • ppmull Apr 24, 2010
    when oven is working fan which appears to be in back of unit runs . This did not appear to be doing this previously when oven was used . Oven now shuts down while being used and will not let me turn it back on .
  • ppmull Apr 25, 2010
    i seem to be having trouble removing the top to gain access to the door switch . i removed the nuts that hold the burner tubes in place as well as the wires for the igniters any suggestions to what is holding the top in place . thank you
    can you tell me how to remove the top of the stove to gain access to switch im having trouble and found nothing in manual thanks
    President:
  • 949 Answers
Here is what the F1C code means:
F1-C Oven door switch state not advancing to control. Check connections, harness, and motor
Phil's thoughts:------>
-If the door is not closing properly the control may shut off the operations of the oven. If the door does not make good contact with seal or feels soft the hinges would need replaced
- If the door switch is failing it could fool the control into thinking the door is open. If this is the case the door switch mechanism or the control itself would need replaced.
Posted on Apr 24, 2010
  • 1 more comment
  • Philip Apr 24, 2010
    Thank you for the clarification.
    The fan in the back is a cooling fan operated by temperature. It will typically start when the oven temperature reaches 300 degrees F.
    If this fan is coming on before the oven is hot or on all time the oven is running it is an indication that the control itself has gone bad.
    With the display shutting down and not allowing you to use the oven this would confirm that the control is having trouble.
    The part number for the control is 74007213 and runs about $235.00
  • Philip Apr 25, 2010
    Here is a link to the service manual for this model. Let me know if you can access it, if not I can email the manual to you.
    http://servicematters.com/maytag_library...
    It looks like the removal of the switch is done after the main top is taken off here is what the manual says about that. Unfortunatly I cannot find any good breakdown images that show this procedure and I cannot say that I recall doing one of these recently. I will continue to research.
    Top Burner
    1. Disconnect power before servicing.
    2. Remove screws securing burner to burner lower
    assembly.
    Maintop Assembly
    1. Remove power from unit.
    2. Remove range from installation position, see
    “Removing and Replacing Range” procedure.
    3. Remove burners, see “Top Burner" procedure.
    4. Remove screws from plenum area at front of opening.
    5. Open oven door and remove screws securing
    maintop to oven chassis, located on the bottom of
    control panel and along the outside edges of the
    maintop.
    6. Label and disconnect wiring.
Jennair cooktop gas
I would go online and look for repair parts from e replacement or similar type pages and byuy the valves there.Perhaps this is something left to repairman. Natural gas leak. may cause damage or *****.
Jan 14, 2018 | Cooktops
Jennaire jgw8130adb
lift top and remove non working burner. check for a blockage inside the feed tube. if two are similar try swapping the two and see if the problem moves to a different gas valve.
May 17, 2013 | Cooktops
Whirlpool oven code E2F3, and oven never gets up to the correct temp.
The thermostat in the oven itself needs replacing. Unfortunately, you'll probably need to get a professional in to do this job.
Oct 21, 2012 | Whirlpool Stove / Oven / Range Cooktop -...
After using the grill cartridge for the first time, and then replacing it with the double burner cartridge again, now the fan goes on every time we turn those burners on. This is a grill only feature. ...
There has got to be an interlock that is actuated by inserting the grill into the cooktop. That interlock switch or sensor is probably stuck closed and still is sending the signal to the stove that the grill is being operated, not the burner cartridge. Pull the burners out, insert the grill back into the cooktop a few times feeling for interference or something not seating right. When you find the interlock or sensor, inspect it to see if it is hung up, clean it, adjust it, or tap it lightly. If the switch/sensor is operating properly, reinsert the burners, make sure the fan is turned off, and operate them, checking to see if the fan is now off. If not, there is either a faulty sensor or a fault in the signal line to the control board or in the board itself. But a hung up interlock is what I would be looking for first. Good luck.
Dec 07, 2009 | Jenn-Air JGD8130 Gas Cooktop
GE Profile Gas cooktop stove- buzzer won't stop
Unfortunately you have to wait until it dries out. I have tried hairdryer before but most of the time I have had to leave it off overnight. FYI if you dont shut off at the circuit breaker and the sparking continues it will short out and definitely get worse
Feb 09, 2009 | GE 36 in. Profile JP968 Electric Cooktop
MAGIC CHEF GAS STOVE/OVEN TURNS ON & OFF
your technical support is horrible after being left on hold for so long and being told to pay 10.00 just to ask a question is poor business.
Nov 19, 2008 | Cooktops
Jennair CCG2523 Gas Cooktop
igniters fire continully any time knobs are on, even after burners
are lighted.
Sep 18, 2007 | Jenn-Air 36 in. CCG2523 Gas Cooktop
JENNAIR DOWNDRAFT COOKTOP
bibman: Sounds like the control switch or possible loose wiring. Take the element out and test the slots for voltage. You should get 220 Volts when on high.
DMA Jennair The fan motor is bad and needs to be replaced.
I suggest a new cooktop as THIS IS THE WORST DESIGNED COOKTOP I HAVE EVER USED. Not enough power, very hard to clean,
Aug 20, 2007 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Cooktops Logo
62 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
