Question about ASUS P5QL-E Motherboard, LGA775, Intel P43 + ICH10R, Dual DDR2, PCIe x16, SATAII, RAID, eSATA, Gigab
I have a problem i was trying to clean my pc insidde and i took of my cpu and i have bended my socket pins help how can i fix this the pins are on my motherboard socket not on my cpu i have ASUS Asus P5QL-E Motherboard, LGA775, Intel P43 + ICH10R, Dual DDR2, PCIe x16, SATAII, RAID, eSATA, Gigab HELP PLEASE
    Sergeant:
    Champion:
  • 242 Answers
Has to be replaced nothing you can do to fix bent pins on a cpu socket.
Posted on Apr 24, 2010
Displays momentarily and asks for CPU fan connection. I have changed 4 fans and still get the same error message and the display goes off.
You're sure you have the cpu fan connected to the correct socket? sounds like it's not connected, or is connected to a different socket. Does the fan turn?
Apr 22, 2015 | Computers & Internet
Bent CPU Socket Pins on a P8z77v Deluxe
Get a pair of needle nose pliers and bend them back.
Hope this hellps
Randy
Aug 31, 2012 | ASUS P8Z77-V Deluxe - motherboard - ATX -...
Is ABIT SG-71 a Pentium 4 motherboard and what are the specs, the does and donts
The ABIT SG-71 is an Intel Socket 478 that could take a Pentium 4 or Celeron CPU (533/400MHz) designed for the 478 socket. It could support up to 2 GB of DDR 333 memory.
This motherboard may not be worth putting in a new CPU; it is over 10 year old technology. It's very old and slow compared to even two year old CPU and motherboard options.
(if you do want to replace the CPU, remove the old hardware. Use extreme care not to bend any pins on the CPU. Add new thermal paste to the top of the CPU and then put on the heatsink. Connect the CPU fan to the CPU fan header.)
May 05, 2012 | ASUS Computers & Internet
Which one is better nd more cheaper,between a pinless nd a pinned processor?? #Urgent please!!
Neither type is better or worse than the other if you're talking about performance (speed). AMD processors have traditionally always been pinned because their socket types require them to be. Intel also used pinned processors as well but since the Core2 and Pentium D lines came out a few years ago, they have ditched the pinned design for something in my opinion that is easier to install. Instead of pins they now have a more flat design with what appear to be receptor-like squares that don't actually physically plug into the cpu socket on the motherboard. With the AMD processors you have to be careful not to bend the pins otherwise it will damage the cpu and in the worst case scenario render it inoperable. Sometimes you can bend the pins back into place.
But in the end, performance-wise they're all the same, you just have to be careful when handling them.
Feb 20, 2011 | Intel Computers & Internet
During power up the power indicator is lighted up but no video and no hard disk activity and stays that way
first remove your smps connector to the motherboard short the pin green and black and see wether the smps fan is working if working connect the connector remove the power supply of the hard disk otherwise it may damage the hard disk now remove the cpu fan and the processor from the socket clean the CPU fan and the processor and fix the processor to the socket apply a thin layer of heat sink solvent and fix the CPU fan firmly on the socket now remove your memory and wipe it clean with a dry cloth and fix it to the memory slot and switch on the computer
Nov 30, 2010 | Toshiba Satellite L305D-S5881 Notebook
CPU pins are bent
Wait if there just bent you can very gentily bend them back with your fingernails. the gentil put it in the Mother board socket slowly if you do it right you can use the socket to re align the pins. make sure you align up the gold arrow on the processor the the arrow on near the corner of the socket. If you have a little of patience you'll be all right. I've done that too along time ago.
Apr 04, 2010 | EliteGroup ECS G31T-M Motherboard - Quad...
How to install CPU- Intel Pentium Dual Core E5200 into a asus barebone system P4-P5N9300pc please?
This particular CPU is not on the list of processors supported by this board. See "CPU Support List" tab:
ASUS P4-P5N9300 Spec
How to install Socket LGA 775 CPUs:
Lift up the cpu slot load plate (which covers the pins and also locks the cpu in place) and install the processor slowly, vertically and carefully into the socket without bending any of the tiny pins in the motherboard socket. Lock the load plate.
The advent of the LGA 775 form factor moved the tiny pins from the CPU to the motherboard socket. Great for Intel, not so great for motherboard manufacturers. Now bent pins are the responsibility of the board makers. Customers with bent pin problems are no longer contacting Intel.
Sep 23, 2009 | ASUS Computers & Internet
Problem with VAIO PCV-RS320
The broken pins are definately the problem. Any CPU needs all the pins to work properly. This problem is solved by replacing the cpu.
Aug 11, 2009 | Sony VAIO PCV-RS412 PC Desktop
Bent CPU Pins
Never use a credit card as the magnitic strip may damage the cpu.
These cpu's are fare too easy to damage. You would be better off replacing the cpu and not removing it if you are un-aware of the outcome.
Cpu's can be picked up almost anywhere, cheap.
Oct 12, 2007 | Gateway Media Center 610X PC Desktop
ASUS P5QL-E Motherboard, LGA775, Intel P43 + ICH10R, Dual DDR2, PCIe x16, SATAII, RAID, eSATA, Gigab Logo
190 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
