Question about Kicker ZR600 Car Audio Amplifier
Speakers pop or rumble when stereo is turned on
Kicker zr600 amp looks fine inside, and when powered up all fuses and voltage sensors show ok. But when i install the crossover module, i get a rumbling sound and heavy pops from the speakers. If i pull the RCA wires off, the rumbling stops, but if i attach an RCA to the White (L) input, i get some sound, BUT if i touch or plug in the Red (R) input the speakers pop and begin to rumble again. Signal RCA's were tested on another amp and no problems... is something shorting or grounding out on my R input?
  • 291 Answers
AMP HAS PROBLEM.. SOUNDS AS THOUGH THE LINE INPUT AMPS HAVE PROBLEMS IN AMP ALSO ONE THING TO CHECK WOULD BE TO DISCONNECT SPEAKERS AND HOOK UP RCA'S.. CHECK THE SPEAKER OUT PUTS WITH A DC VOLT METER TO SEE IF YOU HAVE DC VOLTAGE ON THEM IF SO YOU HAVE SOME SHORTED OUTPUTS
Posted on Apr 24, 2010
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 21 Answers
Check continuity between the rca shields and the non-bridging output. if you have none, check for voltage there, you may see under 1vac, and that may change with you touching the metal. if you are not getting excessive, then put a jumper from the rca output shield and non-bridging channel. if you then have clean audio ouput, there is a small fuse hiding on the inside of the board, that needs to be replaced by someone experienced. there are several things you need to know about assembly and dis-assembly of these amps. also, this fuse will blow if the speaker outputs short, or touch metal, in your car, or the case, so check over your wiring.
Posted on Mar 10, 2012
My one kickers car speaker won't turn on, i replaced the old speakers and put these new kickers 6" speakers. One speakers works but other one doesn't?
try bridging them , first check wires from amp to box or boxes connectors , then check wires inside the box or boxes , then check fuses on amp !
Sep 18, 2013 | Kicker Car Audio & Video
All three of my fuses blow everytime i install them in my amp
It has to be getting to much power. What system is hooked up to it? What are you sending through the amp? Power wise
Feb 12, 2011 | Kicker ZR600 Car Audio Amplifier
What type of "Gauge" wires should I be using for the Kicker ZR600 AMP (Power cable, ground, Speaker wire)?
The lower the gauge, the thicker the wire.
You want multi-strand, not solid. This has better conductivity and less resistance over distance.
10 to 8 gauge will be able to handle anything that particular amp needs.
Remember an in-line fuse on the power cable as close to the battery as possible.
The speaker wire doesn't really need to be anything special
Sound good? Pun intended
Best regards
Mike
Apr 05, 2010 | Kicker ZR600 Car Audio Amplifier
I HAVE A KICKER CAR AMP ZR600 AND ITS NOT PUTTING OUT ANY SOUND AND IVE TIRED EVERYTHING
TRY CHECKING UR CONNECTION AT THE BATT. AND AT UR FUSEABLE LINK AND EVEN UR GROUND WIRE
Feb 21, 2010 | Kicker ZR600 Car Audio Amplifier
How many watts are in the kicker comp zr600 amp? i was told that it was a 1000 watt amp. i just want to make sure that it is a 1000 watt amp and not a 600 watt amp. i am powering two 15'' kicker comp subs...
  • Amplifier Type: Dual Channel
  • Bridgable: Bridgable
  • RMS Power at 4 Ohms: 150 W x 2
  • RMS Power at 2 Ohms: 300 W x 2
heres a link to a stats page for the zr600>
http://www4.shopping.com/xPO-Kicker-ZR600#keyFeaturesArea
Feb 05, 2010 | Kicker ZR600 Car Audio Amplifier
Kicker zr600 smokin havent even bumped yet today
Well it seems to me that the pictures of this amp show green ATC fuses which would be 30 amp fuses. What is your inline fuse from the battery? 40 amp fuses for the amp is too much current for the amps powersupply. If there was a short in the powersupply the max ammount of current that it could draw would be larger than designed to handle therefore damaging the amp.
Jan 02, 2010 | Kicker ZR600 Car Audio Amplifier
I have a kicker ZR600 was shorted i dont have any idea how fixed my problem the 6 power ic's was toasted
mmmmm toast is correct, you may be lucky, examine the unit, it may have a fuse that actually took the short and simply replace it, if this was bypassed then the internal banks will be fried {toast}. The cost of repairs will exceed a replacement cost, I wish you Good luck
Nov 20, 2009 | Kicker ZR600 Car Audio Amplifier
Help please
Check your power cable, for bad connections.
Make sure voltage dont drop below 10.8v.
Nov 30, 2007 | Kicker IX404 Car Audio Amplifier
ZR600 problem
Does it blow the fuse before the remote voltage is applied or does it only blow after remote voltage is applied?
May 25, 2007 | Kicker ZR600 Car Audio Amplifier
Kicker ZR600 Car Audio Amplifier Logo
431 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
