Question about Prima C2012 TV
I have nine outlets in the back of the tv. i can plug a dvd but i can't plug a vcr. i can only use one or the other. when i plug a vcr it gives a black and white picture with no sound.
    Novelist:
  • 145 Answers
You may need your remote to switch between the two inputs to use one or the other.
Posted on Apr 27, 2010
Does it matter if it is a old tv, one that has a vcr, can I still connect?
Yes, you should be able to connect using a coaxial cable, connect the cable to the TV using the Coax (IN) input on the back of the TV.
Jun 16, 2010 | Memorex MVD2042 DVD Player
How to takeout the stuckup video casette form sony vcr and repairing the auto casette take-in take-out system
remove the vcr´s cover and manually turn the motor´s pulley that charge the cassette, if you do not know which is the motor, put atention which motor is turning while you plug the vcr at outlet. Do not forget give points.
Apr 17, 2010 | Sony RDR-VX525 DVD Recorder/VCR
Black and white and no sound!
You are trying to copy or record a copy protected video or your VCR has internal copy prevention turned on. If you wish to copy tapes or dvd's, use a PC based system. You can also pull the raw video information off the VCR if you know where to connect to on the video board of the VCR. I cannot tell you how to to this as I have no idea which VCR you are using however, google the brand and model of your VCR, find a schematic and you should be able to pick the raw video feed into the video decoder chip and use that. Use shielded cables and NEVER undertake any work inside anything when it is plugged into the power outlet, disconnect it first by removing the plug from the outlet (never rely on the switch either).
Dec 12, 2009 | KWorld DVD MAKER USB 2.0 (660448660114)
I HAVE A ZENITH TELEVISION AND I CANNOT HOOK MY DVD/VCR COMBO TO IT. THERE IS NO PLACE TO PUT THE CABLE. MY TELEVISION HAS THE ANTENNA/CABLE PLUG AND THE YELLOW,WHITE,AND RED OUTLETS ON.
your TV has composit video in but your DVD/VCR only has Component video and Svideo outputs ..those are not compatable with your tv .. if you look more closely you might find an SVideo input on your tv .. its flat and not as easy to see as the normal jacks .. if your tv does have SVideo then all you need is an SVideo cable (plus the two sound cables) ... i could check on what you have if you give the TV model number .. othwise you have to have something to convert your SVideo to composit video .. there is a cable that does that .. you can check with radio shack .. if they do have such a cable then one end would plug into the svideo of the dvd/vcr . the other end would plug into the yellow jack on your tv .. hook up sound and it should work ok ..
here is such a cable on the internet ..
http://www.cablestogo.com/product.asp?cat_id=2012&sku=27964#tab=review
or google "svideo to composite" to see lots of options
Nov 22, 2009 | Sylvania DV220SL8 DVD Player/VCR
How do you hook up the dvd player to the tv with a vcr hooked up to the tv
Leave the cable box powered on but disconnected from the TV or VCR. All other components should be disconnected and unplugged, giving clear and easy access to all connections. If components sit in an entertainment unit, make sure all A/V cables can reach the RF modulator and the cable from the modulator can easily reach the television.
  • Step 2 Hookup the first coaxial cable from cable box output, usually labeled "TV," "TV out" or "Out to TV" to the cable "In" on the VCR. Connect the second coaxial cable from the VCR's out to "TV" to the coaxial input on the RF Modulator.
  • Step 3 Connect the third coax cable from the coaxial cable "Out" jack on the RF Modulator to the coax cable "Input" on the television.
  • Step 4 Take one A/V cable, connect the red (right audio channel,) white (left audio channel) and yellow (video) from DVD player's "Output," to the corresponding DVD "inputs" on the RF Modulator. Place components as desired but still disconnected from power. Plug in all power cables including the RF Modulator's into the surge protected outlet strip.
  • Step 5 Make sure the Channel select switch usually found on the back of the VCR and the Channel select switch on the RF Modulator are both set to Channel 3. This channel is used on the television to view your components.
  • Step 6 Turn on the power strip and turn on the TV. Cable reception should come on as usual. Set the TV to Channel 3 and turn on the VCR. With VCR on test it by playing a video tape. The RF Modulator should sense the signal and automatically switch to "VCR."
  • Step 7 Switch off the VCR and with the television still on channel 3, turn on the DVD player. As the RF Modulator senses the DVD player signal and switches to DVD, its welcome screen should be seen on the television. Play a DVD to test and once you're done with the DVD turn it off and the cable should come back on.
  • Jul 15, 2009 | Televison & Video
    Hooking up a d.v.d player to a vcr/tv combo?
    RCA plugs (the yellow, red, and white outlets you speak of) consist of a video plug (yellow) and stereo plugs for audio (red and white). Just match the colors from the DVD RCA colors to the RCA hook-ups on the TV (ex. Yellow the Yellow, White to White).
    You don't need to worry about the red one, it just makes the DVD player play stereo audio. Instead, you'll have mono, which is fine, and most modern players can detect mono and switch it for you so don't worry about changing settings and what not (unless you're missing sound on one side.)
    Sep 13, 2008 | Optical Coating Model 108 VHS VCR
    Trying to Install
    Do you have the red, white and yellow hookups on the back of your TV????? If you don't then you need to get an RF Modulator. You can buy one at Walmart. Older TVs don't have the red, white and yellow hookups. You hook up the RF modulator with a short cable to the cable outlet on your TV. Then you plug in your DVD player to the RF modulator. You also plug your cable for the TV into the RF modulator. It really is very simple. Directions are included with the RF modulator. You will need a short piece of cable also.
    Feb 04, 2008 | Panasonic DVD-RV41 DVD Player
    Having problems connecting dvd vcr combo to tv
    Hey Pat. Red Yellow White Plugs into back of MVD4544. Red Yellow and white plugs into back of TV. If you have an older TV that has only coax cable outlet, go to Radio Shack or Best Buy and get an RF Modulator. You may need to get another set of Red Yellow White Plugs if you have a cable box. The front connections are Video 2, if placed on the back they are Video 1. When you first turn the DVD/VCR player on, be sure to select the appropriate setting. If you figure out how to timer record on this please let me know. No where in the 52 page book is there any info and their website is a joke. Good Luck.
    Sep 14, 2007 | Televison & Video
    RE; Remote control TV/AV button doesn't work LXI series
    Hi, Based on your post/description: 1. the TV is stuck to A/V; 2. you have two video sources - VHS & DVD (assuming both are external and both have A/V outputs with the VCR also with inputs); 3. you want to use either VHS & DVD, one at a time. You can do it the old fashion way, remove yellow, red, white RCA connectors from DVD and plug them at the outputs of the VHS when you want to use the VCR; or Connect the A/V outputs of the DVD to the inputs of the VCR, connect the outputs of the VCR to the A/V inputs of the LXI TV. Hopes this give you an idea. Post back how things are or should you need further information. Good luck and kind regards.
    Aug 23, 2007 | Rio Go Video DDV9475 Dual Deck VCR
    Question on suggested solution
    didnt see your last question but you can reset by plugging out from mains,leave unplugged for about 30secs before plugging back in?
    May 13, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
    Prima C2012 TV Logo
    29 people viewed this question
    Top Prima Televison & Video Experts
    romy sibug
    romy sibug
    Jerry Greenberg
    Jerry Greenberg
    Are you a Prima Televison and Video Expert? Answer questions, earn points and help others
