Question about Kenmore Dishwashers
I have a kenmore elite dishwasher that stop working.No lights will come on.I have tried the reset by pushing the buttons but nothing happens.Any ideas?
    President:
  • 949 Answers
The most likely failure that causes this would be the thermal fuse that is located in the console.
It is a temperature controlled device that can trip if there is a lot of heat in the control area.
If you want to tackle the repair it is not too difficult and requires a basic understanding of electricity and an ohmmeter.
I would need your model number that is on the tag just inside the door to give you detailed instructions but basically the fuse is attached to the control board just behind the button panel. The fuse does not look like a regular fuse and it has 2 wires going to it.
Posted on Apr 25, 2010
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: I have a kenmore elite dishwasher that no lights
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Kenmore Elite Model 665 dishwasher won't start. The lights on the panel come on but nothing happens.
If you hit any 3 buttons in sequence your unit will go into diagnostics and tell you what the error code is
May 10, 2014 | Dishwashers
I am trying to start a cyle and everytime i push the cycle button it does not light up and the quick rinse button comes on and flashes nothing works at all if i push heavy wash it comes on and nothing...
You haven't told me how many times the light flashes, but I will take a guess that this is an error code associated with the water entering the machine being too cool. I believe the machine expects the water to enter at 110 degrees F (43 Degrees C).
To clear the error, press "Heated Dry" then release, then press "Normal Wash" then release and repeat this sequence until all the lights on the machine go solid green. Once this happens, hit ""Cancel" and the machine will reset.
The fix for the root of the problem is to increase the temperature of the incoming water in future (Turn up your water heater temperature a little)
Jul 05, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Dishwasher has power, push wash cycle light binks but does nothing, no filll
See if you have a reset button or a reset procedure. Sounds like an electrical problem.
Check your manual for troubleshooting procedures.
Thanks Marty Mouse the housewife
Jun 05, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
DIshwasher stopped during wash and won't run or drain.
Sounds like a drain motor startup capacitor, or stuck pump. Try disconnecting power and turn the water pump manually. Some disassembly required. Then after a few good hand spins replug and try again.
Mar 05, 2010 | Kenmore 24 in. 17022 Built-in Dishwasher
Four hour delay light flashing
I have a kenmore elite dishwasher and the 6hour delay light is flashing and no other buttons work when I push them.. whats wrong?
Apr 11, 2009 | Kenmore Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Kenmore elite dishwasher
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Normal Light Blinking - Dishwasher not working
I HAD THIS SAME PROBLEM. TRY PUSHING THIS SEQUENCE OF BUTTONS: HEATED DRY, NORMAL, HEATED DRY, NORMAL. THIS RESET MY PANEL AND IT IS WORKING NORMALLY NOW. I FOUND THIS SUGGESTION ON ANOTHER SITE.
Sep 14, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
174 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
