Question about HP PSC 1510 All-In-One InkJet Printer
The printer will only print the page showing how to get the best quality? what is wrong?
All Office
  • 58 Answers
SOURCE: Printing off page
Paper tray guides?
Posted on Jun 25, 2007
  • 52 Answers
SOURCE: Normal print results in a blank page
If you try and print a test page form the printer it will be light also. If this is the case you have a cloged cartridge. You can try to clean the cartridge, or replace it.
Posted on Mar 06, 2009
gwbm
  • 353 Answers
SOURCE: EPSON BX300F prints a page and then shows Printer Error.
Try uninstalling your printer, rebooting the computer, then re-installing your printer. If this does not work, it will require the printer top cover to be removed for further investigation. Either take the printer to a technician to investigate, or if you want to have a go yourself, post a new comment to this effect and I will provide information on how to proceed.
Posted on Mar 22, 2009
SOURCE: hp 2600n will not accept print jobs
I have two problems. Either it won't accept a print job or when it is printing it stops when it is going through the job intermittently. Like for an hour it won't continue then all of a sudden it prints one page then a half hour later another page etc. It is so frustrating.
Posted on Mar 27, 2009
  • 217 Answers
SOURCE: HP 4600 printer shows all cartridges OK and the
Try a new cartridge. If this doesn't solve the problem then check the lens cover of the yellow printhead. It should open when you close the front cover. You can check it by taking out all the cartridges and than close the frontcover slowly. Watch the lenscovers and check if they are opening when you close the front cover. Good luck, Gerrit Jan
Posted on Oct 30, 2009
The printer takes a long time to print.
Buy a faster printer.
And, no, I'm not being a smart-aleck
HP rates this printer at up to 32 pages per minute -- in fast draft mode black ink only... But even their ratings show it takes over a minute per page when doing quality printing in color.
And those speed ratings are all "after first page" -- ALL printers take longer for the first page due to the time it takes for the computer to set up the page and process the information.
As the specs suggest, you can get faster printing in black-only instead of color and by choosing fast draft mode instead of quality or normal mode.
There is very little that could be wrong with the printer that would make it print slower than usual -- generally any problem would make it not print at all or cause it to print incorrectly. Generally speaking whatever speed you see is simply the speed of the printer itself based on the settings you have selected, the software you are using, and the speed of your computer.
You can refer to the information on the HP website. It is just possible that replacing the printer driver MIGHT help but other than that there simply isn't much you can do about the speed of this (or any) printer unless you want to choose a lower quality print setting.
HP Photosmart C5250 All in One Printer Product Information
Mar 08, 2014 | HEWLETT-PACKARD photosmart C5250...
Printer full of ink, but will pring pages either blank of with smeared ink.
Follow these steps to check the print settings for your print job.
  1. In the software program you are trying to print from, click File and then click Print . The Print dialog box opens.
  2. Select your product, and then click Properties . The printer Properties dialog box opens.
  3. Click the Printing shortcuts tab.
  4. Under Printing shortcuts , click the type of job you are trying to print.
  5. Review the following options, and then make any necessary changes.
    • Paper size : Make sure that the selected option matches your paper size.
    • Paper type : If one of the options matches your paper type exactly, select that option.
    • Print quality : If you are not satisfied with your printed page quality, or want more densely printed prints, increase the print quality. To print more quickly, or for lighter prints, decrease the print quality.
  6. Click the Features tab.
  7. Check the Print in Grayscale setting
    • If you are trying to print in color, select Color Options , and then make sure that Print in Grayscale is not selected.
    • If you are printing a black and white image, select Print in Grayscale to fix streaking in black areas.
  8. Click OK , and then click OK again to start the print job.
Make sure the printer is loaded with unused white paper.
Open HP Solution Center , then click Settings , then Printer Toolbox .
Select the Services tab.
Click Print PQ (print quality) Diagnostic Page .
Select the Services tab, then click A- Click Align Printheads or
B- Click Clean Printheads .
C- Click Calibrate Linefeed .
If, after repeated printhead cleaning, the Print Quality Diagnostic page shows white lines across the color blocks in Test Pattern 2 (but no white lines in the gray blocks in Test Pattern 3), one or both of the printheads will have to be replaced. The Print Quality Diagnostic page shows which printhead should be replaced.
Try using the HP Scan Diagnostic Utility in Windows - HP Customer Care (United States - English)
Nov 16, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Printing blank pages on Lexmark C510 printer. Throws a 34 Short Paper error first, prints out a blank page. I have replaced the black toner, but problem continues. Demo page printed colors successfully but...
For 34 Short Paper error, reseat the tray guides and make sure it is set properly. Also, set the correct settings in the computer. For blank pages, always double-check the paper settings and again the settings in the computer. For not printing black, print the Print Quality page and see what color is not printed or not showing. If Print Quality shows black, try printing any document from any application in the computer. Check if you still have the problem. If problem is not resolved, leave a comment so I can get back to this.
Apr 09, 2010 | Lexmark C510 Laser Printer
How do I balance colour on the printer for photo printing?
Have the photo printer run a test/alignment page.
Make sure you are not running out of one color.
Anytime the image runs heavy on one color typically means another color is empty or low and not blending properly.
You can also check the settings to see if it is printing in Draft/Normal/Best Mode. Depends on the settings and application used to control this. Best uses more ink and of course provides the best image. Photo quality paper if you want the best looking pictures. Printing on standard bond will cause some bleeding and saturate the paper. (Looks feels wet) This will give the image a slight blurring dull look.
Depends on the quality of the paper used also.
Hope this helps!
Oct 31, 2009 | Canon PIXMA MP600 all-In-One InkJet...
HOW DO I SPEED UP MY PRINTER ON A MFC BROTHER 240 C
The only speed selection is when you select print quality, draft is fastest, and selecting best will slow the printer down to snail speed.
Oct 02, 2009 | Brother Multi-Function Center MFC-240C...
Blotchy prints
First, make sure your print cartridges are aligned by going to your printer software and printing out an alignment page. Secondly, adjust your printer software/properties to make sure your printing to your best photo quality. Third and most important, make sure you have the right kind of printer paper, which is probably the main reason that your page is blotchy.
Another reason its blotchy would be if the printer was not a good one.
Jan 01, 2009 | Computers & Internet
Streaks though the pages
Step one: Retry the print job The problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality mode If reprinting did not help, try increasing the print quality mode.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected, and then click Properties .
  3. Select the Paper/Quality tab.
  4. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing. NOTE: This step does not apply to color printouts.
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Step four: Clean the printheads If the print quality is still bad, clean the printheads.
  1. Make sure the printer is loaded with unused white paper.
  2. Open HP Solution Center .
  3. Click Settings , Print Settings , and then select Printer Toolbox .
  4. Click the Service Tab .
  5. Click Clean Printhead , and then click Clean .
Step five: Align the printheads If the print quality is still bad, align the printheads.
  2. Open the printer Toolbox , and select the Printer Services tab.
  3. Click Align Printheads . The Align Printheads window opens. Click Align .
  4. The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed If the print quality is still bad, calibrate the linefeed:
  2. Open the printer Toolbox and select the Printer Services tab.
  3. Click Calibrate Advanced Linefeed . The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
  2. Press the Setup button.
  3. Press 1 and * simultaneously.
  4. Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
    • If the Black block has lines – replace the KY printhead.
    • If the Cyan block has lines – replace the MC printhead.
    • If the Magenta block has lines – replace the MC printhead.
    • If the Red block has lines – replace the KY printhead.
    • If the Green block has lines – replace the KY printhead.
Nov 25, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP L7680 Printer Head Problem
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Step two: Increase the print quality mode
In the application you are printing from, click File, and then click Print. Make sure the printer is selected, and then click Properties.
Select the Paper/Quality tab. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
NOTE:- This step does not apply to color printouts.
Make sure the printer is selected and click Properties.
Click the Color tab, and select Print Grayscale and High Quality.
Open HP Solution Center.
Click Settings, Print Settings, and then select Printer Toolbox.
Click the Service Tab.
Click Clean Printhead, and then click Clean.
Open the printer Toolbox, and select the Printer Services tab.
Click Align Printheads. The Align Printheads window opens. Click Align.
Click Calibrate Advanced Linefeed. The Advanced Linefeed Calibration window opens. Click OK .
If the Cyan block has lines – replace the MC Printhead.
If the Magenta block has lines – replace the MC Printhead.
Nov 08, 2008 | HP Officejet 5610 All-In-One InkJet...
Fading cartridge problems
That printer is pretty old. Are you selecting "Best" quality when you print or is it possible that some documents are being printed in Quick Print mode (which puts less ink on the page)? If you're doing the same thing on each print job but the print quality changes, there's definitely a problem. If you're printing from web pages, the print quality may be a factor of the design of the pages. If you print two pages of a multi-page document and quality declines, you should be able to get help through Lexmark's technical support.
Apr 09, 2008 | Lexmark P6350 All-In-One InkJet Printer
Setting HP OfficeJet 4315 print preferences on a MAC OS X
Whenever you send a file to print from a program a small window shows up. If it shows only
Printer: Drop down menu ARROW Presets: Drop down menu Some buttons at the bottom
then click on the ARROW pointing down for more options. That will show more info, including a drop down menu that will allow you to change page settings, printing settings, etc. For example, if you want to change the printing quality, select "Paper Type/Quality" from that drop down menu and new options will show up allowing you to change the settings of the printer.
Jan 10, 2008 | HP OfficeJet 4315 All-In-One InkJet...
HP PSC 1510 All-In-One InkJet Printer Logo
13 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
