Question about Zojirushi BBCC-X20 Home Bakery Supreme Bread Maker
Pre-Heating My Zo is just a couple of years old. The unit will no longer pre-heat--so the unit does not start the kneading/baking cycles. The paddles are working (when I select the cake cycle). Also, I cannot find a local repair shop (Orlando FL). Thank you.
  • 368 Answers
Hi Kathywbb,
I'd go to Zojirushi's Support page at (TinyURL'd for brevity)
http://tinyurl.com/3jmx4g
There's a Service & Support link at the top of the page - locations of service centers and the like.
You can also call Zojirushi Customer Service Department - -
800-733-6270, M-F, 8:00 a.m. to 5:00 p.m. PST.
Also here's a TinyURL for the manual download page, just so you have it.
http://tinyurl.com/z39gu
If these don't pan-out (no pun intended, I think), the next place I'd start hunting is eBay.
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 04, 2009
It seems my plain fan convection oven takes significantly longer to pre-heat to 350 degrees when in convection bake.
I would check the oven sensor it may be defective
Oven comes on and off intermittently or heats very little:
If the timer feature is activating and you have not touched the timer button at all, this would have to be a failed Electronic Oven Control. The timer button is either shorting at times or closing on its own from heat or moisture. The Electronic Oven Control would need to be replaced to repair the problem.
Or Why does it take the oven so long to bake?
When the food is taking way too long to bake, it's probably a weak bake ignitor. Replacing the ignitor usually fixes this problem, but you probably want to verify that the ignitor is the problem before replacing it.
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
Before testing the heating element, unplug the appliance or shut off the power at thefuseboxorbreaker panelto avoid an electrical shock hazard.
When a burner does not heat at all, or only heats up to a lower than expected temperature, the problem is likely to be with the heating element, the temperature control switch, or the wiring. If it only heats at the highest temperature, the problem is with the control or an electrical short, not the burner. If the burner works only intermittently, the problem is likely in the wiring or connectors. To test the heating element, try the following steps.
First, disconnect the heating element from the stovetop. In most cases, this is done by lifting up the burner on the side opposite of the terminals (the part of the burner that disappears under the stovetop). Remove the decorative ring.
Inspect the style of connection. If the burner element has visible blades that fit into the receptacle block, pinch the block with one hand, and pull the heating element free with your other hand. If the terminal block clamps over the element, the housing must be removed and the burner wires disconnected. Unsnap the metal piece or remove the screw that secures the receptacle block and then disconnect the element.
Inspect the heating element. If you find bubbles, warping, or damage to the insulation sheath, the burner must be replaced. If the terminals are dirty or corroded, this can cause poor temperature control, intermittent problems or complete failure to heat. Clean the terminals with steel wool or very fine sand paper to restore good conductivity.
Test theresistanceof the heating element using amulti meter. Set the multi meter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading is typically somewhere between 20 and 120 ohms. The exact reading differs by manufacturer and mode. If the meter reads infinite resistance or the other extreme of the scale, zero resistance, then the element is damaged and should be replaced. If the measured resistance differs significantly from the expected range, the element is probably bad, but if possible, determine from the manufacturer what the actual resistance should be.
To test for a grounded or shorted element, touch one probe to the surface of the burner and the other probe to each terminal in turn. If you get continuity at any time, the heating element is defective and should be replaced.
Apr 07, 2015 | Kenmore Ovens
Oven Pre-heats too high
Your oven sensor has gone bad and telling the control board/thermostat to keep heating. Find the model number on the range and go to a parts distributor like repairclinic.com or apdepot.com and order you sensor. This is an easy repair.
Apr 23, 2012 | Dacor ER36D Dual Fuel Range
I dont no how to pre heat the oven
To pre-heat an oven is to simply turn it on to the desired temperature and wait 5 to 10 minutes. If you have a timer then set the timer for the desired time you want to pre-heat then begin baking as usual.
There is no magic to pre-heating an oven and everyone that bakes has a different opinion.
Sep 23, 2010 | Ovens
Lately, every time I bake bread (using same recipe that always worked well in the past) I end up with a loaf that is collapsed in the middle with top half either missing or looking half baked. The machine...
It could be that the belt is worn and not kneading the dough properly. Either that or the paddle is sticking (see if you can spin it by hand), or the heating element is not getting hot enough. Hank
Jan 18, 2010 | Kitchen Appliances - Others
GE Gas Range Over Won't Heat
Hello, Yes this is going to be the bake igniter. If you remove the lower panel in the oven you will see the bake igniter. It may still be working when you switch on the oven but it is not getting up to the correct temp in order to ignite the gas. Replace the igniter and you will be all set. If you have any other questions please feel free to comment. Good Luck! Mike
Oct 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore gas stove not coming out of pre- heat model 66575842001
This sounds like a flame sensor problem. No signal from sensor will shut down gas valve. Check flame sensor position in flame/or replace
Sep 02, 2009 | Kitchen Ranges
Oven takes FOREVER to pre-heat
You probably have a bad heating element. Trip the breaker and make sure that all power is removed from the stove/oven. Remove the element, and test it for continuity. If it tests open, obtain a replacement from an appliance parts supply house. If it tests good, you should suspect either a bad switch or thermostat.
Regards, --W/D--
Jul 20, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Running time of dishwasher
he cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing See "The cycle doesn't complete" section.
The cycle doesn't complete If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Mar 14, 2009 | Bosch Dishwashers
Blades stuck inside bread
Unfortunately trying to stick the paddles in the pan just tends to leave half the loaf in the bottom with them. The best method i have found is to cut the crust around the outside of the paddles, carefully avoiding the bit where the actual paddle blade is, then you insert a rod into the centre of the paddle and tilt it towards the blade. They normally come free pretty easily. Another method you can use if you are around the machine when it is making bread, is to remove the paddles at the end of the mixing/kneading cycle, just before the baking cycle starts. Most machines have a small pause allowing you to do this - sometimes with a "beep" or screen message to tell you that you can do this. Sorry i couldn't find the exact info for your model, it will vary for different baking programs also. If you check the cycle to determine at which stage it starts actually baking, then you can do this quite safely so long as you are careful of the machine heating up while you are removing the paddles - usually you would have around 20 minutes at least to remove the paddles before baking. Hope this helps :)
Apr 11, 2007 | Black & Decker B2000 Bread Maker
Zojirushi BBCC-X20 Home Bakery Supreme Bread Maker Logo
162 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
