Question about Haier HLH406BB 40 in. LCD HDTV
I just reconnected my haier television to the cable box and now the picture is in black and white not in color
  • Haier Master
  • 8,457 Answers
U are using a AV RCA cable for the connections?Ur AV RCA cable connections all matches up like RED to RED,YELLOW to YELLOW and WHITE TO WHITE?Tried another AV RCA cable?Might even tries a HDMI cable for the connections?U tried all these still getting the same result no colors,just black and white.Than ur Tuner board is defective,must be replaced to solved this problems.
Posted on May 14, 2010
Lost color on Sony Wega KDF-42E2000 A1212387A now only B & White
Likely component video cable inputs bad/loose or cable/sat box problem.
Oct 04, 2014 | Sony Televison & Video
THERE IS NO COLOR. PICTURE LOOKS LIKE A BLACK AND
Try connecting any other devices to the TV and check whether the issue persists, this is to confirm the issue. You can also try changing the cable to connect the devices to the TV. Try resetting the TV to the factory settings. If the issue still persists, try power resetting the TV.
Turn Off the Tv and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation.
If the issue persists, then the TV may require service.
Jul 26, 2010 | Toshiba 42H81 42" Rear Projection...
I need to know where to plug in my connectors for my cable box. I have two red ones and one blue one I can't find the right holes to plug them in. I have a green one and white one fixed so I have a black...
This would be 5 pins, red-white is for audio and rest of 3 pins red-green-blue for video signal, it calls component video.
Find out red-green-blue jacks at back of TV that would be label as Y, Yr, Yb
Plug each pin in same color to get color picture.
Jan 08, 2010 | Proscan 32LA30Q Television
Picture black & white menu color #26mf231d/37
I have the same problem too. Need a fix. This tv isnt that old and is not used that much. does not seem to be the cables or cable box. the menu has color to it but the channel picture is in black and white, flickers a bit, and seems to be in a very large pixle form. it this able to be fixed? Please Help.
Nov 10, 2009 | Philips Magnavox 27MS343S 27" TV
Color Adjustment Problems - Reception in Black and White
satelliteand cable TV is only comes in black and white.
this a HTML type plug or a coaxial
select menu and source
very weird... should default to colour
if no luck try plugging in a desk top digital box tune using that
TH-42PX20 TH-50PX20 Operating Instructions High Definition Plasma ...
ftp://ftp.panasonic.com/television/om/th-42px20_en_om.pdf
Apr 24, 2017 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Black and white picture
you have the cables hooked up the wrong way
Nov 09, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Color change
It sounds as though you may either have a bad video chip or a tuner problem. To make for certain you don't have a cable problem, disconnect the cable from the set and reconnect it. ( a looses or bad cable line could also cause the picture to turn to b&w). I hope this helps in some manner. nfortunataly, with a problem like yours, there are many possibilities that could be a factor.
Ed
NC Electronics
Mills, Wyoming
Feb 18, 2008 | Insignia IS-LCDTV32 32 in. Television
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Color fading to black and red "nightvision" picture
We have a 60" panasonic rear projection television and the color fades in and out. What do you think is the problem the tv is only two years old and is now starting to apear in black and white sometimes. What can be the problem?
Oct 03, 2007 | BenQ PDP-46W1 46 in. HD-Ready Plasma...
Haier HLH406BB 40 in. LCD HDTV Logo
342 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
