Question about LG Washing Machines
Water is pouring out the front
The water is pouring out the front little rectangular door at the bottom front of the washer
    Habit-Forming:
  • 119 Answers
Check your pump screen. make sure it is tight and free of dirt and other debris. Also, is the plug on the little drain hose intact and there?
Run your hand around the inside of the grey gasket between the door and tub, check for a hole or rip.
Can provide part # with a model #
Posted on Apr 26, 2010
My duet front load washer is licking water in front left side have any idea and how do u take off the bottom front cover
there are three screws under the front of the panel. make sure its not leaking from the door and running that way. if the bellow or door seal is damaged or bent or torn it will leak. please dont forget to rate me thanks
Jun 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water pours out of the front door onto the floor..a lot of water. Only had this for a little over a year.
You may need to replace your pressure switch if the water is filling up to the glass in the door.
Aug 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer poured water from bottom
Check for loose hoses or broken connection underneath washer .Unplug machines first before opening up the bottom
Dec 28, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
The door will not open.
This is usally a door lock problem, or control board(you can pull bottom panel off and reach up by door lock and pull on a little plastic ring to release the door, make sure there is no water that can pour out)
Oct 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing cloth diapers
You could, however do not add above the bottom of the door glass. I do this alot on our machine. also use the extra rinse option.
Sep 22, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity front loading washer
Pull the top off by removing the screws on the back of the top of the washer then the top will push back and left off. From the front reach down on the left side , there is a hose that gos from the bottom of the soap dispenser the gos into the front of the drum, you should be able to pull it out of where it gos into the drum chances are there issomthing stuck in it or there in the drum where the hose gos in. Note you may have to take the screws out of the soap dispenser and push it back a little to get your arm down in there to get ahold of the hose.
Hope this helps....
Brian's Appliance Repair
Sep 03, 2008 | Frigidaire Affinity ATF7000E Front Load...
KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Mar 07, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
The water is not being pumped out of my kenmore front loader washeer machine
Unplug the washer from AC
Open the bottom access panel (3 screws on bottom lip)
open the large filter in center,
be ready for a lot of water, mops and rags ready. water vac is really handy .
Clean all the debris you find in the filter, reach in an spin the little propeller and make sure it spins freely.
pour in a cup of water inside the tub does it drain down freely.
reassemble and test.
front access panel has a switch so it has to be closed back.
Jan 26, 2008 | Kenmore 43142 Front Load Washer
WATER LEAKING FROM FRONT BOTTOM
try onscrewing top panel on machine...when machine agitaes strongly a hose my pop lose up from top.
Jan 22, 2008 | GE WBVH6240F Front Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
