Question about Asante FriendlyNET FR1104-G Wireless Router
Lost wireless signal - Asante FR 1104-G to iBook G4
My router has suddenly stopped sending a wireless signal to my laptop.  I have tried unplugging it and then plugging it back in, but nothing works.  The green wireless light is on, although I had to power it up a couple of times to get it on.  It has worked fine for over 2 years.
Bob
Can my apple ibook g4 work without an airport extreme card
If you mean 'work as a computer' then the answer is yes.If you mean 'work on the internet' the answer is yesIf you mean 'work wirelessly on the internet' then the answer is no.
You can use an ethernet cable to connect to your Router and that will give you the internet.
Feb 18, 2012 | Apple iBook 12 iBook G4 1.33GHz,...
My Asante FR1004 is not consistent in the wireless signal. When the laptop is plugged directly into the wired ethernet ports the problem does not seem to exist. I use a Macintosh PowerBook Pro and have had...
Most of the problems we see with wireless access points and routers, are other devices nearby on the same wireless channel.
Log into the FR1004 and try changing the channel to another one a few numbers apart. i.e. if it's set to 6 then try 11 or 1. Depending on your country, you may be restricted to certain channels.
Also check if you have a DECT phone station near, and move it away if possible.
Mar 10, 2010 | Asante (FR1004AL) Wireless Router
Mac ibook g4 connect to an existing wireless network?
Usual problems are making sure that you select the correct security options at both ends and then DHCP problems. I would disable DHCP on the mac and select your own IP address above the existing ones to start with
Oct 11, 2009 | D-Link DIR-625 (790069292637) Wireless...
Ibook g3
First of all, you need an Airport card for the iBook G3, chech for example this link; http://popular.ebay.com/ns/Computers-Networking/Original-Airport-Card.html (you should buy one like this: 9deeeda.jpg
, there is a G4 card too, but your iBook doesn't support this one).
Next, install it;
Then, buy a wireless router that uses 802.11b/g or 802.11b. This is very important because your airport card doesn't support 802.11g, and install it, but don't protect your network with a WAP password, your iBook doesn't support this, but use WEP.
Then start your iBook, and click on the Airport icon in the right corner, select your network, type in the password and it will work!
Jul 01, 2009 | Apple iBook G3 Mac Notebook
Laser writer select 360 to Mac OS X 10.4.11 via AsanteTalk
You should phone the Asante tech support people in San Jose, CA, who will talk you through the fix for free. I lost my printer-MacPro connection, the other day, and everything works fine now, thanks to their advice.
I'm running 10.5.x and no WiFi so the fix may not be the same, but it was just a matter of sort of re-booting the Asante box. Here was my fix, if that helps:
1. Delete that printer from your list of printers in System Preferences.
2. Make sure your computer, printer, and Asante box are all hooked up together and turned on.
3. Click + under the list of printers in System Preferences.
4. Click AppleTalk icon in top row of dialogue box that appears.
5. After a moment, click Bluetooth icon instead.
6. After a moment, unplug the power cord from your Asante box (but not from the electrical outlet).
7. After a moment, re-plug the power cord into your Asante box and, as soon as possible after the "TX" light comes on, click the AppleTalk icon again.
8. Within a few moments, your printer's name should appear. Highlight its name, then make sure all the information about it that appears is correct, then click "Add."
9. Everything should communicate beautifully. I had no further problems.
Dec 21, 2008 | AsanteTalk - Ethernet to LocalTalk Adapter...
Wireless printing
To initialise an Epson R300 and Draytek router I have to turn:
Router off
Printer off
Printer on
Router on
This may work with your setup
May 14, 2008 | Epson Stylus Photo R300 InkJet Printer
SMC 11n Router: wireless set-up
Hi there!
Do you know how to check the wireless IP address at your iBook?
May 04, 2008 | Computers & Internet
No signal from router after closing laptop
Is it definately the router that's your problem, because most laptops are able to turn off the wireless connection especially when powered by battery alone to conserve power, so check the settings in your laptops wireless adapters properties.
Jan 28, 2007 | NetGear DG834G Router
Asante FriendlyNET FR1104-G Wireless Router Logo
Top Asante Computers & Internet Experts
Ekse
Marvin
Marvin
Are you an Asante Computer and Internet Expert? Answer questions, earn points and help others
