Question about Denon S-101 System
Mecha err I am getting a mecha err on the front panel. I have also noticed that the fan is not running either. Please help
Im getting error PF when trying to start my whirlpool carbio. Also getting error code f25 what does this mean?
There is or should be a booklet on the inside of the machine between the tub and on the front panel. Tells you what the err codes mean. First thing to check on these machines is the drive belt pulley located on the bottom of the machine. I went through a lot of headache and confusion trying to run diagnostic modes and watching how to videos to get my machine to start going through the cycles until the end. The lid lock keeps coming on and off so you think it's that and try fixing it to no avail. And on and on trying to find the err code in diagnostic. I finally gave up and when I was loading it on to the truck to take it to the scrap yard I notice the drive belt has come off and cut completely through the guard. Causes problems the err codes don't catch. The belt pulley comes loose causing this. Start there. Trust me on this one.
Jan 01, 2017 | Whirlpool Washing Machines
I have a Sony kdf-e55a20. Ran diagnostic check. Showed lamp err. Lamp cover and low b err. Would the lamp and cover err. Cause low b err. Please help me!
Did something get spilt in it or you may have a bad connection in the lamp area.check all connections and if lamp stays on when key isn't in ignition and keeps running it will over time kill the battery
Jan 01, 2015 | Televison & Video
Mecha trouble problem cutter pos
- in my case I received the error "mecha trouble cutter pos"
I removed both side panels and the panel directly in front of the cutter
this gave me access to the cutter assembly where I found that the cable that runs the cutter had fallen off of the pulleys.
I was able to get the cable back onto the pulleys and now the printer works perfectly
Feb 20, 2012 | Sony UPDR150 Thermal Photo Printer
I'm getting a "Mecha Trouble
checking the gear by taking off both side panels and the panel directly in front of the cutter helped me - in my case I received the error "mecha trouble cutter pos"
problem was, the cable that runs the cutter had fallen off of the pulleys and after a bit of fussing, I was able to get the cable back in place and a working printer.
Sep 15, 2011 | Sony UPDR150 Thermal Photo Printer
The dryer beeps when not running. It will start the cycle but then wii beep and stop. It seems to be running but every few seconds it flashes ERR. What can I do?
Open the front access panel or the lid and find the technician diagnostic sheet. Run ir through the diagnostic test and get an error code the sheet will tell you what to do. If you have anymore questions please comment me back.
Jul 30, 2011 | Dryers
417.44092500 front load washer I get a LOC err,
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 30, 2009 | Kenmore 46462 Front Load Washer
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Mecha Error 12 on Kodak Photo 6800 printer
I had a 6850 with the Mecha error 12. No listing in the service guide for this error. I took the front of the printer off and observed that the cut head was not moving far enough to the left to trigger the sensor. I realized that a screw of unkown origin had fallen down behind the cut head and was preventing it from triggering the left sensor. It took a curved pick tool and a pair of tweezers to get it out. I don't recommend taking the cut assembly apart as the alignment is pretty crucial.
Hope this helps some poor sole from the hours of fustration that it gave me.
Randy
Apr 15, 2009 | Kodak 6800 Thermal Photo Printer
Frigidaire ATFB7000ES0 ERR PAU 3 beeps
An E-45 code is a control board issue & needs to be replaced
Dec 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Zanussi zwf1237w washing machine
I had the same problem my 3 yr old had been playing with the buttons and the whole thing just locked up and displayed ERR no amount of unplugging turning off would fix it.
Till ...........
  • Take off the top
  • Unscrew front panel and remove,
  • Then remove circuit board from panel,
  • Desolder the square battery,
  • Leave to stand around 15 Min's, (would recomend longer to be sure)
  • Re-solder Battery refit circuit board and refit panel.
This discharges the program memory chip and resets to default.
Hope this helps it's not so hard as it sounds just take care with the battery. DON'T put to much heat on it use a screwdriver on the small connections to act as a heatsink.
Nov 22, 2008 | Zanussi ZWF1430W Front Load Washer
Denon S-101 System Logo
48 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
