Question about Frigidaire GLMV169D Microwave Oven
I just bought a frig.GLMV169DSC /display model
It did not come with manual, the part that attaches to the wall is already attached to the micro. I don't see how to take it off to attach to the wall. please help.
2 Suggested Answers
jmgldsmth
  • 1889 Answers
SOURCE: nothing works
Check the ceramic fuse it is easy to spot under the top of the machine cover
Posted on May 28, 2009
Why is my microwave not heating model Frigidaire GLMV169dsc microwave not heating
Hello friend, thank you for your inquiry!
Sounds like there could be a potential problem with your magnetron, capacitor, or control panel inside of your Frigidaire microwave and that is why it is not heating. I would recommend seeking assistance from a professional for additional assistance towards a proper diagnose of your appliance. -Matt
Sep 22, 2014 | Microwave Ovens
Schematics for kitchenaid model kemc307
see the information attached for fix it. Merry Christmas
Dec 16, 2013 | KitchenAid Microwave Ovens
How do I change the door hooks on a panasonic micro?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
A Panasonic service manual covering some models is here.
Sep 14, 2011 | Panasonic NN-P295SF Microwave Oven
How do you mount this model
There are two bolts through the bottom of the upper cabinet that attach to the top of the microwave. These support the front of the microwave. There is a wall plate attached to the wall studs that supports the back. If removing the microwave, take care when removing the front support bolts, as the microwave will fall if not supported when these are removed. There are instructions available at www.sears.com under parts direct. Your model number will be a longer number than you have here it will look like this 000.00000.
Mar 10, 2010 | Kenmore 62702 Microwave Oven
OK I have a Sharp Micro R-1600 that made a loud bang and now won't heat anything. everything seems to work including fan, led display, timer, clock, carousel etc. It turns on bit makes a much louder sound...
Having the repair people come and have a look at the oven. They may be able to fix it while in place and may not need to be removed from the wall.
Feb 04, 2010 | Sharp Microwave Ovens
How do we get an jvm59 GE Microwave oven out? The cabinet above appears to be covering the screws.
Sometimes older microwave ovens are built into the walls and are attached to the studs and mountings already in the house with cabinets built around them. Try taking off the paneling of your cabinets a little at a time until you can see how the microwave is attached. With any luck, it's held in by brackets underneath the cabinets and not attached to the studs in the walls.
Dec 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I bought a used over the range microwave oven( kenmore) I would like to know how to install it knowing there is an opening to the roof. thank you
Most Kenmore microhoods use a 3" by 10" exhaust duct. Check for correct demensions. Make sure that the existing vent is this size or that you have room to adapt to this size. There should be a damper mounted to the top of the micro which will attach to the vent duct work. You will need an outlet in the cabinet above the micohood. This should be on a circuit of it's own. The microhood should have a wall plate for the back wall. I'm going to assume there are no templates available. Hold the wall plate against the back of the micro to determine the height placement in the opening. Most install centered under and against the cabinet above. Not all do, so this will confirm. Mount the wall plate to the existing wall studs with at least 1/4" by 2-1/2" lag bolts. Bore an 1-1/4" hole in the right rear corner of the cabinet above, about 2" out from the back of the cabinet and 2" in from the side, this is not a critical measurement, it is to pass the electric cord into the upper cabinet. There are two screws that support the front of the hood. I believe they are 1/4" by 3-1/2" long. If not included, check for size. The hardwae will have them, get flat washers to fit both also. Measure from the back of the micro to the mounting holes in the top of the micro, include the wall plate in this measurement, they'll be about 10" out from the back and about 1-1/2" in from the edge, near the front, but check that measurement, they vary. Drill 3/8" holes in the bottom of the cabinet at these locations. If doing this alone, best that you move the range out. It's nice to have a helper at lifting time. With the plate on the wall and the holes in the bottom of the cabinet, your ready. Put the 1/4" screws and someting to drive them in the upper cabinet, so they'll be available. Lift the micro into the opening with the front tilted downward, hook the back of it into the bottom of the wall plate, push the cord into the upper cabinet, tilt the front of the micro up until you can start the front support screws. Start both, don't let go of the micro until you are sure that both screws are started and will support the front weight. Once you're sure, tighten both screws all the way and connect the vent. Steel tape is best for sealing up any leaks. Power up the outlet, plug in the microhood and put in the popcorn. Get a good movie and enjoy in your accomplishment. Congrats. PS: Make sure the roof vent opens when the hood is turned on, I have seen them stuck shut from grease build-up.
Oct 22, 2009 | Microwave Ovens
Broken micro wave handle
On most brands, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
To find Danby parts, refer to your owner's manual or contact the dealer from whom you bought the oven for Danby's contact information.
Oct 11, 2009 | Danby Microwave Ovens
Cannot remove face on Micro/Covec Oven to replace broken handle
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Feb 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp Microwave R-1480 ~ Removing
You need to remove the grill above the door to find two more screws that go straight to the back wall plate. They will be on the left and right side. There are chrome or a gold color. That is the only other way that they mount to the wall.
Good Luck
Nov 17, 2008 | Sharp R-1480 Microwave Oven
Frigidaire GLMV169D Microwave Oven Logo
44 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
