Question about Brother HL-2040 Laser Printer
Yellow light for Drum comes on - Brother HL-2040 Laser Printer
    President:
  • 405 Answers
This means drum error, you need to clean the corona wire. To see how to clean the corona wire please click the link below.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000200/000008/faq000208_012.html?reg=us&c=ca&lang=en&prod=hl2040_all&Cat=7
Posted on Apr 24, 2010
Yellow light is blinking?
If the bottom amber colored light is blinking, the imaging drum needs replaced.
If the yellow print cartridge light is blinking, then replace the print cartridge (yellow toner).
Mar 24, 2014 | HP c9705a - Color Laser Jet 2500l Printer
How to replace a R1 drum cartridge on a xerox 7545?
The entire 57 series from Xerox is one of the friendliest units for operators there are on today's market. To replace the drum module you simply need to unlock and drop the tray which is attached to it below the drum unit, then swing the locking arm to the unlock position and remove the old drum. All the drum replacement kits come with an instructional showing you how to remove the shipping material from the new drum and then simply replace drum into the copier and return locking arm and relock the lower tray to bottom of drum frame and shut the door. It's that easy.
ONE THING TO KEEP IN MIND: NEVER, and I mean NEVER touch your fingers or hands to the drum surface. The natural oils in your skin can cause damage to the drum surface. Be very careful when installing the drum to ensure that nothing touches the actual drum surface.
SECOND WARNING: Drums are LIGHT SENSITIVE! NEVER leave a drum exposed to office light or any other light source for more than 5 minutes. If you need to stop your replacement procedure, make sure you cover the drum with a dark black garbage bag or some other source that can completely stop the light from reaching the drum.
Mar 30, 2013 | Xerox WorkCentre 7525 7530 7535 7545 7556...
I have a brother 2140, I have replaced the toner car, the yellow light still comes on and the printer will not print
Remove toner/drum unit, remove toner by itself...remember to shake the toner right-left to loosen the toner before putting back in the unit. To reset the printer before you replace the toner/drum, and with the front door still open, hold the GO-Control button down until all lights are on, then let go, reinstall the toner/drum, & close up front door. Power off & back on and you should be set.
Oct 21, 2009 | Brother HL-2040 Laser Printer
Yellow stains after machine washing
Sounds like rust stains, coming off the inside of the drum, you will need to find the source of the rust. Maybe a loose screw or something metal stuck inside the drum. Carefully run your hand around the inside of the drum and check for rough jagged edges to identify anything that should not be in there.
Aug 21, 2009 | Washing Machines
The 'drum' yellow light is constantly on, and the paper curls as it comes out rather than laying flat.
If you have the book for the printer or even electronic documentation, check the manual for troubleshooting tips. There should be something about the drum and the yellow light. You can try reseating the drum but it sounds like the drum may need to be replaced. Not sure on this model if it is a customer replaceable unit, but on many of the new printers they are.
Aug 10, 2009 | Brother HL-2040 Laser Printer
I am getting yellowish in prints
I cause by dirty primary charge roller in yellow drum unit, Replace yellow Drum unit
Mar 31, 2009 | Canon imageRUNNER C3200 Copier
HP Laserjet 1300 printer Yellow light flashing
dear friend,
when the printer give you a yellow flash that should be means a fault happen so you have to do the following:
1- check if any messages appears on your computer when you trying to print something that should be help you. if not go to step 2
2- black paper may be come from the (P.C.R.) that is the charger of the drum, so if you can open your cartridge and check the charger at the op of the drum that will be good and if not you may change the cartridge and check again.
3- Also, you can release the cartridge and look inside the printer may be you can find something wrong or something need to fix
4- Other wise go to hp help center
Jan 28, 2009 | HP LaserJet 1300 Printer
Drum Light is flashing yellow
Drum light flashing yellow means the drum is near it's end-of-life. There is some life left in the drum at this point. Do the following to get some more mileage out of your current drum and also when you finally do replace it (this resets the drum counter):
  • Printer on and paper loaded
  • Press and hold blue button until all LEDs light up
  • Release button
Oct 28, 2008 | Brother HL 5140 Laser Printer
Yellow Toner Light Flashes - won't print
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Aug 22, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
205 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
