Question about Dometic Refrigerators
Dometic fridge thermostat replacement.
How difficult is it to replace the gas/electric thermostat on a Dometic RM2332 refrigerator? Is there any problem getting the capillary line out/in, and are there any hints or tips you can give?
I'm an aircraft mechanic, skilled in working on all types of systems, so I'm not a novice. I have pretty much every hand tool you might want, and know how to use them. I'm familiar with working with electrical systems, pneumatic and hydraulic systems, and just about any type of mechanical system. I mention this in hopes of avoiding the typical "best left to professionals" answer: I *am* a professional: I'm just not familiar with the details of this particular equipment..
    Top Expert:
  • Dometic Master
  • 8,686 Answers
Tie a wire to old one pull out and tie new to it and pull through
Posted on Oct 14, 2017
  • 51 Answers
SOURCE: dometic refrigerator
The system is sealed very difficult to charge. Not to mention expensive. The same price to get a new coil. The boards that control the operations are hard to trouble shoot sometimes. Do you have 12 Volts DC going in to the control board. If yes does the control board inside show green lights that it is working. If so the lower control board on the out side needs to be looked at.
Posted on Sep 07, 2008
  • 19 Answers
SOURCE: Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Posted on Nov 18, 2008
SOURCE: Candy CPCA270FFK Thermostat replacement
if your refrigerator is in warranty than contact your service authority......or if you had purchased it by your own than ...... my friend! the thermostart does'nt have any warranty
Posted on May 14, 2009
VtToolMan
  • 704 Answers
SOURCE: Our Dometic RM2193 cools on gas but does not work on electric
It could be as simple as a blown fuse at the fridge. Also check to make sure you have turned on the electric switch that allows the fridge to run on AC. Note, you can only operate the fridge on EITHER gas OR electric, but not both sources at the same time, thus, you have to turn off the gas switch before you can run on electric.
When this unit is running on electricity, it has to have the thermostat set for it to run.
Here's a link to the Dometic manual for your model.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Just follow the steps for running on electric and you should be OK.
Hope this helps.
Posted on Jul 30, 2009
  • 79 Answers
SOURCE: Dometic refrigerator will not stay lit
sand your thermal cupler off or replace it not centing the flam
Posted on Apr 11, 2010
What do I check to fix my Dometic Americana refrigerator. It won't start using electric or gas.
Fist off before you get crazy replacing things make sure the camper is level when testing this. Gas will not run to it if you are not level. Also make sure the gas is turned on and make sure you have selected automatic or gas only on your fridge. Also give it about an hour before you test the temp. These take a bit longer to start feeling cool. If all of that does not work you will need to check the refrigerant, igniter(for the gas side) and the compressor. Also make sure the fuses are good to go at the main panel and that the breakers are in the "on" position
Sep 11, 2014 | Dometic DM2852 Americana Fridge...
It was working fine it was unplugged to be moved now it wont work on electric or gas its a rm 760 gas or electric domestic
When operating on Electric, if the rear of the cooling coils get warm and the fridge is level, but the refrigerator does not get cold then it is more then likely your cooling unit that has failed. Visit ArctiCold Refrigeration We keep it cold for info on replacement cooling units.... I have also attached a video with tips on diagnosing the RV fridge,
Arcticold New replacement cooling units can be purchased from Ebay Dometic RM760 Brand New Manufactured Cooling Units LIFETIME WARRANTY
Sep 16, 2013 | Dometic Refrigerators
Fridge will not switch from gas to electric when electric is present. Shut of gas and fridge still not switch, it stays on gas. Check light does not come on.
Check the fuses located in your electronic board located on the rear of the fridge. You must remove the board cover to see them. If you replace the fuse and the fuse blows again, then you more then likely have a bad heating element. ArctiCold Refrigeration We keep it cold fb8d9c00-4cdb-47b4-8ed5-b7b384af5c24.jpg
Sep 08, 2013 | Dometic NDR 1292 Refrigerator
Hello, my dometic camper fridge runs great on gas but just clicks when i switch it to electric...??? any advice thanks Stephanie
The mains heater has a different thermostat. Check power to the heater, and the back coil is getting warm
Apr 27, 2012 | Dometic RM2652 Refrigerator
Prroblem with rv gas refrigerator Dometic ndr1062
I assume you've checked baffle distance above flame? Anything changed above fridge, as in clearance, ventilation above etc. Maybe even removed a piece of panel, that was used above fridge for vent deflection etc?
Jun 25, 2010 | Dometic NDR 1062 Refrigerator
RM2852 has never worked on electric.
there a 3 electrical parts
1) the switch
2) the thermostat
3) the heater element
You will need to test for fault , but most likley is the element
Aug 16, 2009 | Dometic RM2193 Compact Refrigerator With...
Hope this helps.
Jul 30, 2009 | Dometic RM2193 Compact Refrigerator With...
Dometic Rv fridge will get cold on a/c power but
does the flame ever got out if not ,the tsat is not the problem. It could be that the flame is not hot enough or the flue has a restriction
May 18, 2009 | Dometic RM2620 Refrigerator
I have a Dometic fridge with cooling issues.
theese wire that goes to the fins are your thermostat probes it possible that your thermostat is defective if you take your thermostat and bypass the two wire connected to it toghether if your fridge works replace the thermostat thanks from gilles
Mar 07, 2009 | Dometic RM2652 Refrigerator
Refrigerators Logo
211 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
