Question about Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
Water remains in the bottom after cycle. I drained the water and seems there is gunk in the bottom. Running the rinse cycle with some bleach?
  • Bosch Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your problem...
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Apr 27, 2010
There is a terrible smell from my washer
Hi, what happens is that water sits at the bottom of the discharge pipe, as well as a build up of "gunk", which is a great breeding ground for bacteria and such. So during the first rinse out, the smelly water and gunk is discharged into the drain, and the smell comes up from the laundry tub drain. Pour a few cups of bleach into the discharge hose and let it sit for an hour. This will kill all the nasties. Then just run the machine once through to pump out the bleach.
Sep 09, 2010 | KitchenAid KHWS01PMT Front Load Washer
My GE washing machine drains the water after the rinse cycle but does not start spinning. It just sits with the water pump running and does nothing. This doesn't happen with every load but seems to be...
Most likely the tube from the tub to the water level switch is full of "gunk" so the washer still thinks there is water in the machine, and therefore will not spin. Take the front panel off by pushing in the retaining clips at the top seam between the front panel and the washer top. Pull the thin hose off the left side of the tub and clean it out. (or cut off an inch or so, but you can only get away with that once or twice). To help prevent re-occurance, every two or three months you can fill the washer to the lowest level with hot water and several cups of bleach (no clothes) and run it through a cycle. Rinse at the ex-large setting to make sure all traces of bleach are gone before doing another load of laundry.
Nov 12, 2009 | GE WDSR2080D Top Load Washer
Washer not cleaning clothes
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Next run your washer with 2 cups of bleach, hot water. After it starts agitating stop the washer & let it remain for 2 hours. Then continue the wash.
Try using powders for 'front loaders'
Apr 05, 2009 | Kenmore HE2 Plus Front Load Washer
Seems my drain is plugged on my dishwasher it is the magic chef 4500b unit and i now have water all over my kitchen floor. i cant seem to find the product du4500b  so i entered the du2000 , either way...
Ok there are several problems this can be caused from...
1. there is usually a float device (I'm not sure about this model) that floats up and turns the water flow off when an appropriate amount of water is injected into the DW...sometimes these get gummed up with soap and gunk...look in the DW and see if such a device is present (usually front right side) if so you should be able to lift it and inspect it for gunk...if no gunk is present push the float up and down and listen for a "clicking" noise and make sure the float returns to its up position (spring loaded) and after you have evacuated the water turn the DW on and start to fill see if the water shuts off automatically after it has filled (this is most likely your problem).....
2. Another problem is that often if dishes are not rinsed and lots of food has accumulated around the bottom of the DW..it can obstruct water from draining and since the drain cycle is on a timer...all the water will not drain out and during the next cycle...(and usually only if the float is not functioning) it will overflow. So the odds are you are going to have a float problem.
3. Also in my 35 years of appliance repair I have seen maybe 2 DW drain lines clogged and usually it is right where they attach to the washer...due to the aforementioned food accumulation. Turn the washing machine timer through its cycle from wash to rinse or whatever is necessary to get it to drain...you should here a door or valve click open and water running into the garbage disposal side of the sink...if this is the case the drain line is good.
Hope this helps...get back to me if not....The Fang
Mar 25, 2009 | Magic Chef 24 in. DU2000 Built-in...
Water in bottom of dishwasher, can't get it to drain
pull your water drain line out and place in a bucket on the floor. then try to drain it again. alot of time the hose get an air gap or blocked with gunk.
Feb 16, 2009 | General Electric Adora GHDA670N Built-in...
There is gunk in the bottom of my dishwasher by the drain. Really sticky gunk. How do I get it out?
Depending on what that 'gunk' is, will determine your best course of action. If it is food byproducts from the wash process and you've not cleaned out the filter, you should remove as much of that gunk with a dishtowel and warm water, then use white vinegar to break down any other leftover material. Rinse with clean warm water. Check the filter and clean it after each wash process to make sure you aren't restricting drain water from being pumped out. Once you've removed th emajority of that material, you could run a dishless wash cycle on the sanitary setting to clean out anything that remained... Hope this helps...
Sep 09, 2008 | Dishwashers
Not draining
Are you sure your drain system is not clogged or restricting water flow ? When you say youtook off the hose off under the sink and it seemed to be lots of water running on the rise cycle .. that suggests that you may have a restriction after the drain hose in your house drain system. ...
Some other considerations..
To minimize the possibility of electric shock, unplug this appliance from the power supply before attempting any maintenance.
  • Some water, usually one to two cups, remaining in the bottom of the tub is normal. However, if water is covering the bottom of the tub, the dishwasher is not draining properly.
  • Check for paper or large objects covering or blocking the sump area in the rear of the tub.
  • Make sure that the right type and amount of detergent is used: Using the wrong type or too much detergent can cause sudsing that can prevent the dishwasher from draining. Only detergent specifically designed for automatic dishwashers such as Electrasol®, Cascade® or Cascade Complete® should be used
Hope this helps you...
Sep 03, 2008 | Dishwashers
Water will not drain out of the tub all the way and behind the front door bottom in the insulation seems to be wet. and the cycle seems to take a long time to run...thanks
My dishwasher, Bosch Model No. SHU9922UC/U12, Serial No. 10 0202 80447 01 0040 goes through its wash, rinse and dry cycles but sometimes there is some water remaining on the items in the upper tray and one inch or so of water remaining in the bottom of the tub. Once water leaked out onto my kitchen floor. I found some broken glass and some plastic in the circular trap at the bottom and have removed the detritus.
Jul 29, 2008 | Dishwashers
Bosch dishwasher will not drain - causing moldy odor
Hello Mimhoff it depends on how much water is down there. The sump area always has a little water in it to prevent the circulation pump seals from sticking. Usually around 1 to 2 inches. If there is more than that, check the slots at the bottom of the sump on the left side for being clogged and check the end of the drain hose to make sure it is clear. If you are getting a moldy/odor from the dishwasher, try running Dishwasher Magic or Tang thru the dishwasher. This will remove any build up of food or detergent from the dishwasher. If you are running the dishwasher every few days and just scraping your dishes, then either leave the door ajar or run the rinse & hold cycle to help keep the odor down. Bosch doesn't reccommend running bleach thru the dishwasher as this can cause damage to the rubber seals. However 2 tablespoons of bleach once a year won't hurt.
Feb 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bleach is spilling directly on to clothes
I have the same problem and here is the reason and the solution. When you add bleach it sits in the dispenser until the rinse cycle. During the rinse cycle the machine pours a lot of water through the dispenser. The bleach is diluted and washed out with all this water into the tumbler and you clothes are rinsed with bleach. Sometimes when this rinse happens, the water does not completely drain from the bleach dispense. It sits in there. If this happens, the next time you add bleach, there is too much liquid in the dispenser and it leaks out onto your clothes.
Solution: Before you add bleach, take the whole dispenser out and see if there is a lot of water still standing in the bleach dispenser section. If there is a lot of water, spill it out into a sink. Then fill the dispenser with your bleach and it will all work out the way it should. I was having your same problem until I discovered this. I have never had the problem since.
Let's give a toast to Bright Whites!!
Nov 07, 2007 | Washing Machines
Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
148 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
