Question about Hitachi Deskstar 7K80 Hard Disk 80GB, 7200RPM, ATA-6, 2MB Cache, Desktop, 20PACK (HDS728080PLAT200A3021020PK) Hard Drive
Hard Disk Drive
My Hard disk drive is working too slowly than others what can I do now?
  • 871 Answers
Defrag your drive to make it faster.
Posted on Mar 24, 2008
I have a Toshiba Desktop Ext Hard Drive HDWC120XK3J1 for many years and worked fine, but now non of my computer recognize it anymore. I hear that is working but doesn.t show up in the My Computer or Disk...
Areas to check
1. Is the light blinking or stationary.( it has to be blinking for it to connect to your pc)
2. Just see if you can get a different cable and plug the hard disk to your PC.
3. Try adjusting the side of the wire close to the hard disk port area slowly. This can happen because the port area has probably worn out over the years and has got some loss in contact.
4. If none of the other steps worked then you hard disk has "probably" become faulty with bad sectors accumulated over the years. ( this happens to all hard disk ). But don't worry you can still recover if you give ur HD to technicians at a cost and it's time to get a new hard disk.
Feb 11, 2015 | Toshiba Computers & Internet
Tip
How to recover data from a bad HDD
<p>If a hard drive clicks and the information starts to move through them very slowly when it opens is stored, you need to store data as soon as possible. It's just a matter of time before the hard disk stops working completely. You can try everything from the freezer to remove the device, because the drives read better in colder temperatures. <br /> <p><br /> <p>1. Place the hard disk in a zip lock bag and freeze the zipper to close. <br /> <p><br /> <p>2. The bag containing the hard drive in the freezer. Cool in the freezer for several hours. <br /> <p><br /> <p>3. Remove the bag from the freezer. Remove the hard disk of the bag. <br /> <p><br /> <p>4. Connect the hard drive of your computer, connect the two pin connectors in the slots of the rear disc. <br /> <p><br /> <p>5. Click on the blue circle in the lower left corner of the screen. Click My Computer. Double-click the hard drive appears. <br /> <p><br /> <p>6. Click and drag the files from your hard disk to another disk or desktop. <br />
on Jun 22, 2011 | Computers & Internet
When I connect it to my laptop (or ANY other computer/laptop) the blue light on the external hardrive turns on and I can feel that it is working, but it simply doesnt get read, the computers dont recognise...
Open the enclosure.
Separate the disk-drive from the USB-to-disk-drive adapter.
Connect the disk-drive as a 'slave' disk-drive in a desktop computer, and see if you can read the files.
If not, search online for a professional 'data recovery service' -- for a FEE, they can repair a disk-drive just long-enough to copy your files onto a new disk-drive.
Oct 26, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
My laptop no longer recognizes my external hard drive. Device Manager gives me an error code 10.
Connect the Maxtor to a different computer, to see if the device works in some other computer.
If the warranty is still valid, exercise the warranty to get a replacement.
If the warranty has expired, disassemble the casing, and disconnect the USB-to-disk-drive interface from the disk-drive.
Connect the disk-drive as a "slave" disk-drive in some other computer, to see if the USB-to-disk-drive interface is the part that failed.
If all else fails, search online for commercial "data recovery services" -- for a large amount of money, they will disassemble the disk-drive, repair it, just long-enough to copy your files.
Aug 09, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
P4pe x cannot detect hhd drive
If the BIOS cannot detect the hard drive then :-
1. The hard drive data cable or power connector may not be inserted properly.
2. The motherboard disk controller is faulty.
3 The hard disk is faulty.
To test the motherboard disk controller, connect another hard disk to the motherboard and go into the BIOS to see if it detects the hard drive.
If it detects the hard drive, then the other hard drive is faulty and need to be replaced.
Another way to test the "faulty" hard drive, connect the hard drive to an USB hard drive adapter and plug it into a working computer's USB port. If this computer sees it as an external hard drive and you can open the folders and files the the hard disk is OK, and the fault is a faulty disk controller on the motherboard.
Jun 14, 2010 | ASUS P4PE-X Motherboard
The computer no longer sees my 320 gb hard drive, do i need to download new drivers? if ao where do i find them. i store all my photo's and music on this hard drive
Possibilities:
1. dead USB port on your computer -- try another port
2. try a different USB cable
3. try your external drive on some other computer, to see if it works at all
4. open the casing, and separate the disk-drive from the USB-to-disk-drive adapter. Connect the disk-drive as a "slave" disk-drive, thus bypassing that adapter, to see if the adapter has failed, or if the disk-drive itself has failed
5. Google-search for a commercial "data recovery service" -- such companies can disassemble your disk-drive, and fix it, just long-enough to copy all your photos/music onto a brand-new disk-drive.
Jan 25, 2010 | SimpleTech 320GB SimpleDrive External by...
I have a LaCie Hard Disk 1TB. But I am afraid, that it is destroyed. I cant get in contact with it, and it makes trouble in my PC. The PC works very slowly until I take the harddisk off line. Whats wrong?...
It does sound like you are having some hardware issues. It may be that the circuit board for the drive is failing and not the drive itself. Turn the drive off and try contacting LaCie customer service and see if they will replace the unit for you.
Jan 09, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Not enough hard drive on processor for backing up
What operating system are you running (Windows XP, Windows Vista, Windows 7, MAC OSX) then i should be able to help. Guy
Dec 30, 2009 | Memorex Computers & Internet
Disk boot failure, insert system disk and press enter
The drive should be set with jumpers or cable select to be primary master. Some pc & drive combinations don't like cable select, others insist on it. Try both, one at a time.
Jul 15, 2008 | Western Digital (WDXB1200BBRNN) 120 GB...
Reformatting
just make sure in bios that your first boot device is cd rom,then install the cd and follow the instruction
May 08, 2008 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
