Question about RCA F27442 27" TV
Is this TV digital or analog?, I want to know so I can hook up a Antenna with or without a Converter box.
  • 321 Answers
Yes that is analog/ and you can conect an antenna
or the cable box...
have a nice day
Posted on Apr 24, 2010
How do I hook up Coby 5" black & white TV to my digital converter box ?
You will need a digital to analog converter which you can get at Radio Shack, Best Buy and most big box retail outlets or online. Your Coby is most likely analog and will require the digital signal to be converted to an analog signal from the digital converter box to the TV. UNLESS the digital converter box has analog (round connectors on the back) then you just need an analog RCA cable (which you can also get almost anywhere even your local CVS/Walgreens) to make the connection.
Nov 24, 2014 | Coby Televison & Video
How can I get analog channels to work with DTV without cable
Hello drandald,
Your tv is a digital tv, so you do NOT need a converter box. The tv has a built in digital tuner. But if you have any other older tv's then what you need is a converter box to convert analog signals to digital. I know there is one in Best Buy (not sure if there is one in your location) but they have one called access digital tv converter. They are about $50 (CAN). You would still need your antenna or however you get your analog signals. The antenna needs to be plugged into your converter box and then the box would need to be connected to your tv.
-Joe
Aug 29, 2011 | Zenith Z32LC2D 32 in. LCD Television
All ready used box once. Now going back to antenna. Not receiving display or menu on T.V. screen.
All TV over the air is transmitted as a digital signal now. In order to see it on an older TV (read Analog), you must have a signal that you can receive(antenna hook up) and a digital to analog converter box. That box allows you to see your digital signal on older TVs. The signal is sent from the antenna to the box via a RF connection, and decoded to channel 3 or 4 (your choice). for further information see Consumer Report at:
http://www.consumerreports.org/cro/electronics-computers/tvs-services/non-digital-tvs/digital-converter-boxes/digital-tv-converter-boxes-first-look-3-08/overview/digital-tv-converter-boxes-first-look.htm
Jan 09, 2011 | Insignia Digital-to-Analog Converter for...
Do i need a converter box for my rca true flat 27 in? if not how do i connect a digatal antenna i have lost my manual
Your TV will require a Digital Converter Box to recieve over the air Digital Television Signals. You will need to hook up the antenna to the converter box and then hook your converter box to the TV. Hooking your television directly to a digital antenna will not get you Digital signals...only analog signals.
Jun 25, 2010 | RCA TruFlat 27F520T 27" TV
Toshiba 36" analog TV Tivax converter box RCA Digital Flat Amplified Antenna How do I get signals without cable?
I understand you have;
Toshiba 36" analog tv,
Tivax converter box,
RCA Digital Flat amplified antenna.
You want to get signal over the air;
Connect the antenna to the Tivax converter box.
Connect the Tivax Converter box to the input for the TV.
Turn on the antenna, Converter box and TV. You should get a menu on the tv screen. Follow the instructions and SCAN in the channels in your area by using the converter box remote.
You can see your channels by going to www.tvfool.com and entering your information.
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
Do you need a special antenna to hook up a dtv digital to analog
You need a TV antenna, nothing special about it. Hook the antenna up to the converter box, the box up to the TV.
Jan 10, 2009 | Insignia Digital-to-Analog Converter for...
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Hooking up converter box when i have a dvd player and direct tv
Hook your Insignia box between your antenna and your television. You still need the antenna.
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
HDTV converter box only brings in 3 channels
We have a pretty good signal when we use the antenna but when we hook up the converter box we get no channel weak signal no channels we have a amplipher on it it does not help .
Nov 22, 2008 | Insignia Digital-to-Analog Converter for...
Have a problem
Currently, your switch box likely has several inputs, which as you said are occupied by your DVD Player, XBOX, and your television source. The output of the switch is then fed to your TV.
What you will need to do is insert the DTV converter box BEFORE the switch box. If you have an analog antenna on your TV (rabbit ears) you will need to put the converter box between your antenna and the switch box (the cables, not the box itself) so that your wiring goes like this:
Antenna ---- converter box ---- Switch box
XBOX ---------------------------------switch box
DVD -----------------------------------switch box
And the switch box still goes to the TV. However, you do not NEED to use the converter box until February of 2009.
Jun 11, 2008 | Insignia Digital-to-Analog Converter for...
RCA F27442 27" TV Logo
66 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
