Question about Dell XPS 420 PC Desktop
When i turn on computer it says memory modules are detected, but memory failure has occured
    Sergeant:
    Champion:
  • 305 Answers
Remove your memory sticks and wipe them with a soft dry cloth.
reinsert them and try again. if still say same you will have to reload your computer sorry.
hope this helps.
Posted on Apr 25, 2010
  • 3 Answers
My ancient Dimension E320 barfed this way with indicators 3&4 green and a blank screen, and I could neither find any bad memory stick nor get anything to work. Problem turned out to be dirty DIMM sockets on the MB.
I cleaned the sockets by spraying TV contact cleaner into them (after removing and draining power to remove the DIMMs of course) and inserting/fully-seating/unclipping/removing/rinse&repeat DIMMs 5-10 times. Then when I put everything back together it all worked!
(Every spray can of TV Contact Cleaner I've ever seen somes with a red tube taped to the side. One end of that red tube goes into the spray button on the top of the can, and the other end directs all the solvent right into the DIMM slot rather than spraying it all over the inside of the computer. I tried not to make too much of a mess ...but I didn't worry about the inevitable drips.)
Posted on Jan 09, 2012
Dell xps 9100 constant beeps upon startup
Beep Codes
Your computer might emit a series of beeps
during start-up if the monitor cannot display
errors or problems. The following repetitive
beep codes help you troubleshoot problems
with your computer.
NOTE: To replace parts, see the Service
Manual on the Dell Support website at
support.dell.com.
One beep - BIOS ROM checksum failure;
possible motherboard failure
Contact Dell (see "Contacting Dell" on page 53).
Two beeps - No RAM detected
Remove the memory modules, reinstall
one module and restart the computer. If
the computer starts normally, reinstall anadditional module. Continue until you have
identified a faulty module or reinstalled all
modules without an error.
If available, install memory modules of the
same type in your computer.
Three beeps - Possible motherboard failure
Contact Dell (see "Contacting Dell' on page 53).
Four beeps - RAM read/write failure
Ensure that no special memory module/
memory connector placement requirements
exist (see the Service Manual on the Dell
Support website at support.dell.com).
Verify that the memory modules that you are
installing are compatible with your computer.
Five beeps - Real Time Clock failure
Replace the battery.
Six beeps - Video BIOS test failure
May 22, 2014 | Dell Studio Xps 9100 Desktop Computer
Power light amber with code 3 and 4
Looks like Memory Issue,
Memory modules are detected, but a memory power failure has occurred.
You can try as follows :
  • If two or more memory modules are installed, remove the modules, then reinstall one module and restart the computer. If the computer starts normally, continue to install additional memory modules (one at a time) until you have identified a faulty module or reinstalled all modules without error. If only one memory module is installed, try moving it to a different DIMM connector and restart the computer.
  • If available, install verified working memory of the same type into your computer.
Let me know
Thanks
Feb 18, 2014 | Dell OptiPlex 780 PC Desktop
My pc 520 will not boot up numbers 4 & 5 light up with blank screen and buzing noise, how do i fix this
There are only 4 diagnostic LED lights. If you mean lights 3 and 4, that indicates you have a memory problem. Memory modules are detected, but a memory failure has occurred.
If you have two or more memory modules
installed, remove the modules, reinstall
one module and then restart the computer. If
Apr 08, 2013 | Dell Dimension Computers & Internet
My dell optiplex gx620 does not start and it shows no. 3 and 4 lights illuminated on its front . what could be the problem.?
One of your memory chips is bad.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Diagnostic Lights caution.gif CAUTION: Before you begin any of the procedures in this section, follow the safety instructions located in the Product Information Guide. To help you troubleshoot a problem, your computer has four lights labeled "1," "2," "3," and "4"on the front or back panel. The lights can be off or green. When the computer starts normally, the patterns or codes on the lights change as the boot process completes. When the computer starts normally, the patterns or codes on the lights change as the boot process completes. If the POST portion of system boot completes successfully, all four lights display solid green. If the computer malfunctions during the POST process, the pattern displayed on the LEDs may help identify where in the process the computer halted.
note.gif NOTE: The orientation of the diagnostic lights may vary depending on the system type. The diagnostic lights can appear either vertical or horizontal.
Light Pattern
Problem Description
Suggested Resolution
The computer is in a normal "off" condition, or a possible pre-BIOS failure has occurred.
The diagnostic lights are not lit after the computer successfully boots to the operating system.
Plug the computer into a working electrical outlet and press the power button.
A possible BIOS failure has occurred; the computer is in the recovery mode.
Run the BIOS Recovery utility, wait for recovery completion, and then restart the computer.
A possible processor failure has occurred.
Reinstall the processor and restart the computer.
  • If you have one memory module installed, reinstall it and restart the computer. (see "Memory" for instructions on how to remove and install memory modules.)
  • If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  • If available, install properly working memory of the same type into your computer.
  • If the problem persists, contact Dell.
A possible graphics card failure has occurred.
  • If the computer has a graphics card, remove the card, reinstall it, and then restart the computer.
  • If the problem still exists, install a graphics card that you know works and restart the computer.
  • If the problem persists or the computer has integrated graphics, contact Dell.
A possible floppy or hard drive failure has occurred.
Reseat all power and data cables and restart the computer.
A possible USB failure has occurred.
Reinstall all USB devices, check cable connections, and then restart the computer.
No memory modules are detected.
Memory modules are detected, but a memory configuration or compatibility error exists.
An other failure has occurred.
This pattern also displays during System Setup and may not indicate a problem.
  • Ensure that the cables are properly connected to the system board from the hard drive, CD drive, and DVD drive.
  • Check the computer message that appears on your monitor screen.
After POST is complete, all four diagnostic lights turn green briefly before turning off to indicate normal operating condition.
None.
Jun 06, 2012 | Dell OptiPlex GX620 PC Desktop
On button flashes yellow but wont turn on
unplug the power cable for 10secs. press the power button while its unplug to remove all the electricity in the cpu. connect the power cable and then press the button. if you hear a beeping sound when you turn on the cpu, you have a problem with the motherboard. if no beeping sound, check the 4 diagnostics lights at the back of the cpu, advtrbl5.jpgMemory modules are detected, but a memory failure has occurred.
  • If the problem persists, see "Contacting Dell" in your Owner's Manualfor instructions on obtaining technical assistance
advtrbl6.jpgA possible expansion card failure has occurred.
  1. Determine if a conflict exists by removing a card (not the video card) and then restarting the computer.
  2. If the problem persists, reinstall the card that you removed, remove a different card, and then restart the computer.
  3. Repeat this process for each card. If the computer starts normally, troubleshoot the last card removed from the computer for resource conflicts (see "Resolving Software and Hardware Incompatibilities" in the Owner's Manual).
  4. If the problem persists, see "Contacting Dell" in your Owner's Manualfor instructions on obtaining technical assistance.
advtrbl7.jpgA possible video card failure has occurred
  • If the computer has a video card, remove the card and reinstall it, and restart the computer.
  • If the problem still exists, install a video card that you know works and restart the computer.
  • If the problem persists or the computer has integrated video, see "Contacting Dell" in your Owner's Manual.
advtrb16.jpgOther failure has occurred
  • Ensure that the cables are properly connected from the hard drive, CD drive, and DVD drive to the system board.
  • If the problem persists, see "Contacting Dell" in your Owner's Manualfor instructions on obtaining technical assistance.
Feb 05, 2011 | Dell Dimension 4600 PC Desktop
Numbers 3 and 4 are flashing green on the front of the computer
Dell website says that it means that the PC has memory installed, but there is a problem with it. It's possible that you have more than one memory module and one has gone bad. If you know how, you could try removing one, restarting the PC to see if the error is eliminated. If not, put the removed one back in and remove a different one until the error goes away. You may have to buy a new memory module. Additional troubleshoot tips on the Dell website at this link: http://support.dell.com/support/edocs/systems/dimE521/en/SM_EN/adtshoot.htm#wp1056411
Oct 21, 2010 | Dell Dimension E521 PC Desktop
Solid amber light. No power to the system just the fan runs.
Solid amber light means the CPU is not being powered properly, that is USUALLY a bad power supply. Contact Dell and order another power supply. if that doesnt fix it, you have a bum board. (usually, you will see popped capacitors on the board if its bad). I will say, that in about 70% of these, its a bad power supply. power supplys arent cheap (unless you have a warranty of course) but they wont break the bank. a replacement is likely going to be about 40-70 dollars. I havent priced it, but you can ask dell at dell.com/chat. Good luck.
Nov 19, 2009 | Dell DimensionTM XPS 710 PC Desktop
Computer on start up makes noise and the 3 & 4 and battery icon light up and nothing comes up on monitor.
The diagnostics codes that you have got indicate
solution:
  • If the problem persists, contact Dell (see your computer Owner's Manual for information about how to contact Dell).
Owners manual to help you reseat the memory modules
http://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1364711
Thanks for using Fixya
proton
Nov 09, 2009 | Dell Dimension E310 PC Desktop
My Dell Optiplex GX520 will not boot. There is no video output and the 3 and 4 diagnostic lights remain on.
If 1 & 2 are off ... then you have problems.
  • If you have one memory module installed, reinstall it and restart the computer. (see Memory for instructions on how to remove and install memory modules.)
  • If the problem persists, contact Dell (see Contacting Dell).
According to Dell's notes:
Their remedies are:
Jun 17, 2009 | Dell OptiPlex GX520 PC Desktop
Dell XPS 420  PC Desktop Logo
296 people viewed this question
Alun Cox
