Question about Brother CS6000i Computerized Sewing Machine
I am unable to thread the needle using the automated system, why?
Automatic threading of needle does not work
I've found that it's easier to thread by eyesight than that darn "hook" that you can't see! But after 12 or so attempts, I found out that you have to LET GO of the thread that you're holding in your right hand once the hooks start to go backward. It still takes too many times to get it right.
Posted on Apr 24, 2010
The automatic threader wont pick up and thread needle. Can do manually but thats not easy?
to make manual threading of a needle easy buy a needle threader
it is a instrument that has a very fine piece of wire in a loop that you push through the eye of the needle , put the thread in that loop and pull the loop back out of the eye and the needle is threaded
available from most any shop that sells material , cotton , thread or sewing machine shops
cost --pack of 2 for $1.00 or there abouts
Oct 05, 2016 | Sewing Machines
Top thread is shredding Automatic needle threader stopped working
If the top thread is shredding it is usually because the needle and thread are not compatible. If thread is too large for the eye and the thread groove, the action of sewing will cause the thread to shred as it pieces the fabric.
Try a different needle and thread. Here's an excellent web site:
All About Needles
Sep 27, 2015 | Sewing Machines
Fix thread cutter on singer quantum xl 100
Is it blunt? Is it angled properly . these and needle threaders are a pain in the neck, I just use scissors and thread my own needles.
Best wishes
Jan 24, 2015 | Singer Sewing Machines
Difficult to use auto needle threading
you thread the machine the normal way, using every thread guide, and if the automatic theader works it will thread the needle,
if the auto threader doesn't work, then it needs to be checked.
also make sure the needle is turned the correct way and inserted correctly into the needle holder.
Mar 06, 2014 | Brother 50-Stitch Limited Edition Project...
After automatic thread cut the needle comes unthreaded
you need long thread tails, of 3 to 6 inches for the top & bobbin thread so the needle doesn't come unthreaded,
also pull the thread behind the needle before you start to sew
Mar 27, 2012 | Brother PQ1500S Computerized Sewing...
Top thread on my Brother Limited Edition 350 Sewing machine keeps breaking. Having used the automatic cutter, the thread pulls up and out of the needle when I want to start sewing again. Also the machine...
rethread the machine
try a top thread tension of 3 or 4
change the needle
always keep a thread tail of 3-5 inches on top & bobbin thread & keep the thread pulled back behind needle before starting to sew
always keep the bobbin area clean of lint & loose thread
& check under the needle plate for lint also
you might consider having the machine serviced, since you said it sounds like a tractor
some needle & thread are not compatable-try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 04, 2010 | Brother Sewing Machines
My needle broke and I replaced it per instructions. Now my automatic threading will not work. I've taken the needle out and put it back in. I;ve made sure the needle is in the highest position. I love...
Make sure the little hook is lined up with the hole in the needle and that your needle is not inserted backwards. Flat side should face the rear of the machine,
Aug 20, 2010 | Singer 8763 Curvy
I own a singer simple sewing machine
By threading part, do you mean the automatic threader? I've never had much luck with them. Yes, you can thread the needle manually.
Happy Sewing!
Feb 04, 2010 | Singer 3116 Simple
Quantum XL-6000 automatic threading system not working
ok it sounds like the theader is bent check to see if the that it is going through the eye of the needle if it is make sure the foot is up so the tenison dics holding the thead this may help .
Nov 24, 2008 | Singer Quantum XL-1000 Computerized Sewing...
How do I thread it
Follow the thread from the spool through the first thread guide at #1 straight down to #2 and up to #3 (make sure that the thread is through the take-up lever (silver hook) at #3 from three you will bring the thread straight down to the thread guide that is to the left of the needle. Thread the needle from front to back.
Mar 11, 2008 | Kenmore 19233 Computerized Sewing Machine
Brother CS6000i Computerized Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
