Question about Motorola Mobility StarTAC ST7868W Cellular Phone
PONE WONT POWER UP OR CHARGE - Motorola Mobility StarTAC ST7868W Cellular Phone
Phone will not charge
Hi Jeanette,
The chargers you are using. Are they Motorola Original parts or from another manufacturer? This way we can eliminate if it could be the chargers. Could be something with the charging port on the phone though there is a hole in that theory.
Regards,
Maya
Motorola Support
Jul 08, 2016 | Cell Phones
Tip
How to Unblock Network lock of SAMSUNG SGH-J700
SAMSUNG SGH-J700 UNLOCKING:
1- Power on pone ,, type : *#7465625#
you will identify which code is active , which is inactive
2- Remove battery ,, Put your sim card , not all of it ,, just to prepare it to be full inserted , put your battery back and power on pone ,, you must see " insert sim" not "invalid sim.."
3- type : *2767*3855#
your pone should restart after 1 min ,,
now ,, and before it restart , push your sim card ,,without removing battery
4- your pone should work and accept the sim card ,, but if you check locks you will find that your pone is still Locked
5- now type : *7465685*638*00000000*00000000#
your UNLOCK CODE is 00000000 now ,
6- now , back to Locks table with : *#7465625# ,, and for each active code you can disable it ,,,Here details :
* Disables CP lock : #7465625*27*00000000#
* Disables Network lock : #7465625*638*00000000#
* Disables SIM lock : #7465625*746*00000000#
* Disables SP lock : #7465625*77*00000000#
* Disables Subset lock : #7465625*782*00000000#
on Jan 21, 2010 | Cell Phones
My pone is charging but wont turn on i have taken the battery out several times and it is full charged but still wont turn on what should i do
replace the battery with a new one. Many battery types create a 'memory' when used repeatedly without a full charge. stopping the charging process prior to full charge lowers the level the battery 'expects' a full charge to be. Do this often enough and you will create a battery that expects full charge to occur at zero charge.
Sep 20, 2014 | ZTE AT&T Avail II Z992 Unlocked GSM...
My fake iphone wont charge
Is it a matched brand charger? If it isn't, then its more likely went out. Most phones use a special connection inside the charger to tell the phone to accept charge.
Jan 11, 2013 | Apple iPhone 5
Well most th time my cell pone works...but right now its shuting off on me and it will only turn back on if i plug it into its charger then lik 10 seconds later of turning back on the power shuts off...
I suspect that your battery has seen better days (losing charge, the random shutdown)
If possible, replace the battery- if not, contact your carrier to see if they can replace it/ do some research and see if you can find the spare parts in order to do the repair. By the way, is it getting hot when you charge the battery? If so, IMMEDIATELY STOP USING THE CELL. LiION batteries have had issues in the past with the cell overcharging- if it is getting very hot- as in burning, that is a severe safety hazard that needs to be addressed by your carrier immediately.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Dec 07, 2010 | LG Neon GT365 Cell Phone
Havent used my pearl for a while. trying to
Turned out it just needed time to charge enough to turn on.
Sep 05, 2009 | RIM BlackBerry Pearl 8100
My W810i phone is not turning on
CHARGE THE BATERY WITH THE TWI CHARGE
IF NOT TUNING YOU MUST FLASHING
Dec 03, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Razr V3x
The internal phone software needs to be "reinstalled".
Take it to a service center, they'll know how to do that. The phone will not charge, will not power on and will not accept any input from the keyboard or the USB port except the correct software.
If you try to reload the internal firmware by yourself (there are guides in internet telling how to proceed) be aware that you can render the pone useless beyond any repair.
May 02, 2008 | Motorola Mobility RAZR V3
Motorola Mobility StarTAC ST7868W Cellular Phone Logo
18 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
