Question about Harley Davidson 2007 Harley-Davidson FLHX Street Glide
I have a 2007 harley davidon
I have a 2007 ultra glide-
what would cause the motor to fry
i dont red line.
i had to have the crankshaft,oil pump
well the motor rebuilt
  • 116 Answers
Dont know how many miles or how well you maintain it,but its a possibility of the check valve in the camsupport plate sticking though thats more common in 88 inch motors,how well do you trust your mechanic shop,they should be able to pinpoint what happened,however if your not sure of your shop,I have two retorical questions,how long after your last service did it happen,and did you check to see that there was oil in it after it quit,they wouldnt be the first to 'forget"to put oil in it or maybe the drain plug came loose, thing is only the guy that tears it down will know for sure,but you definatly lost oil pressure, your idiot light should have been glowing
Posted on Apr 26, 2010
I have a Harley Triglide w/103 engine. After warm-up steam or exhaust comes out the injector body. Shortly after oil seeps out as well. Is this a breather gear issue?
Hi, Gary oil leaking from your air cleaner is caused by oil carryover from the engine. For whatever reason, the breather system is not separating enough oil mist and air from the piston downstroke. There are cheap and quick easy fixes and there are more expensive ones. First, make sure your breather hoses are not dry and cracked if they are ok you can start by trying the following:
1. Run your oil level half way between the add and full mark when hot.
2. Run oil breather lines from the head into a TEE fitting below carb/induction module then a single line into a mini filter under the frame.
3. Purchase Arlen Ness Super Sucker.
4. Replace umbrella valves and realign oil pump.
5. Upgrade oil pump and cam plate.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
How to stop oil leak from air filter by Dmitry
Harley Davidson FLHTCUTG Tri Glide Ultra Classic 2010 Manual Download...
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://www.harley-davidson.com/content/h-d/en_US/home/owners/maintain-your-bike/owners-manual.html
Instant Tech Relief A must have !!! Absolutely "FREE"
Feb 03, 2017 | 2010 Harley Davidson FLHTCUTG Tri Glide...
2007 ultra classic replaced the fuel filter and fuel pump bike stiil won't start
Assuming that all the fuel systems are not restricted in any way, maybe you have something wrong with the electrical system that is grounding out causing the malfunction.
Jul 29, 2014 | Harley Davidson Motorcycles
2009 ultra classic oil coming from carberator
Hi Jesse, oil leaking from your air cleaner is caused by oil carryover from the engine. For what ever reason the breather system is not seperating enough oil mist and air from the piston downstroke. There are cheap and quick easy fixes and there are more exspensive ones. Start by trying the following:
2. Run oil breather lines from head into a TEE fitting below carb/induction module then a single line into a mini filter under frame.
Good luck
Apr 20, 2013 | 2009 Harley Davidson FLHTCU Ultra Classic...
Oil coming out of crankcase air breather 1966 electra glide
Hi Anonymous, oil leaking from your air cleaner is caused by oil carryover from the engine. For what ever reason the breather system is not seperating enough oil mist and air from the piston downstroke. There are cheap and quick easy fixes and there are more exspensive ones. Start by trying the following:
Good luck
Aug 31, 2012 | 2000 Harley Davidson FLHTCUI Electra Glide...
2004 ultra classic electra glide oil pressure would drop to 0 and light would come on if you gave it gas it would come back up took it in for a check they changed oil pressure switch and oil pump had oil...
Most likely problem is a badly fitted seal/gasket this can cause the oilways to be blocked, take it back and get the technician to check it.This is an easy thing to do, because of the fine tolerances in the oil pump. A motor rebuild is a real pain and I'm sure the shop would rather not pay for a new motor.
Sep 19, 2011 | 2004 Harley Davidson FLHTCUI Electra Glide...
What kind of oil goes in the transmission of a 2003 flhtcui
Gear oil ,,,,I like spectro platinum or red line oil .. any GOOD gear oil 80/140... not the oil hd sells too thin.. check out more hd stuff at harleytalking.com ................03 is a cool bike.....
Jul 21, 2011 | 2003 Harley Davidson FLHTCUI Electra Glide...
2001 ultra classic fuel injection with screaming eagle heads, when going at a high speed around 70 or above oil shoots out breather tubes that go the air cleaner and runs down side of motor. already...
Hi Berkberks, oil leaking from your air cleaner is caused by oil carryover from the engine. For what ever reason the breather system is not seperating enough oil mist and air from the piston downstroke. There are cheap and quick easy fixes and there are more exspensive ones. Start by trying the following:
Good luck
Sep 22, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
Crankshaft defect
If you have a warrenty and the motor hasn't been altered it's a harley problem.The low pressure is most likely an oil pump defect.There are check balls an springs in there that can go bad,up to an including cracked seats.Some models have a pressure adjusting screw but I don't think newer models do.Flywheels don't directly affect the pump and the crankshaft has an oil hole but if that affects you pressure you'd have bigger problems.There is a breather gear that can break but again bigger problems.I vote oil pump an that would be covered if the motor is stock.
Mar 21, 2010 | 2005 Harley Davidson FLHTC - FLHTCI...
I have a 2007 ultra classic, I took it for a ride last week and was having trouble with the oil pressure , came home, parked it and then it wouldnt restart. I took it in and they are saying that my motor...
I am not sure of these pins or your pressure release springs you are talking about.The only pins that i know off is the piston pins or the pin in the cam plate that retains a spring and plunger.
Mar 19, 2010 | 2005 Harley Davidson FLHTC - FLHTCI...
Harley Davidson 2007 Harley-Davidson FLHX Street Glide Logo
137 people viewed this question
Top Harley Davidson Toys Experts
Tre Elkins
ray gallant
L Pfaff
L Pfaff
Are you a Harley Davidson Toy Expert? Answer questions, earn points and help others
