Question about Brother IntelliFax-2820 Laser Fax
Brother 2820 Says clear scanner jam and press stop
Gentelmen,
I have the problem with my Brother IntelliFax-2820.
Everething looks clean, but I have an
error message:Document jam Clear the scanner jam then ptess the Stop key.
Please, help
Regards,
Alex
  • 5 more comments
  • Anonymous Jan 15, 2009
    I have the same problem. Did you fix yours? If so, how?
  • jovani_alex Jan 19, 2009
    I have the same problem and can`t fix.
  • Anonymous Feb 11, 2009
    THIS PRINTER IS SUCH A PIECE OF JUNK THIS THING JAMS LIKE CRAZY!!
  • Thomas Aug 17, 2012
    Cleaned everything, no jam, no dust, reset to factory settings... Brother you should buy these things back!, and be ran out of town. You have 1300+ looking for a fix, with no good answers ...Tom
  • Maria Jan 24, 2013
    I have the exact same problem, spent about an hour trying to find the paper, there is no paper
  • Anonymous Mar 12, 2014
    brother intellifax 2820 keeps jamming
  • Anonymous Mar 28, 2014
    The number 1 on the Dial Keypad does not work.
    New Friend:
  • 120 Answers
Make sure there is nothing caught where the documents go it. List up the scanner cover and look inside. It may need a separator pad or clean the feed rollers with some alcohol. Lawrence
Posted on Apr 23, 2008
The error message I was receiving was "Clear scanner jam and then press the stop key".
It was resolved when I cleaned off the sensor under the first roller that feeds documents through the scanner.
It seems that the dust on the film of the sensor was being detected as a something jamming the machine since it could not be fed through. Looks like it is also important to clean the roller since that was putting more dust on the sensor.
Posted on Mar 12, 2012
My fax machine brother 2820 shows document jam. How can i solve it. it shows - clear the scanner jam, then press stop. How can i get tht
for this one you need to make sure there's no paper that was cut while you are removing the paper that was jam, try to clean the rollers with a clean paper the one that feeds the paper . when your done .Lift the printer upside down and remove the cartridges try to shake it for 5x .. I believe the upper portion portion of the printer is removable make sure there are no foreign objects such as ballpens , sharpeners etc...
Hope it help
May 22, 2011 | Brother IntelliFax-2820 Laser Fax
I'd like to turn off ECM on my intellifax 2820
There is no option to turn off the ECM on Brother Intellifax 2820 , just set the compatibility to Basic so that the ECM feature will not be available. Just press Menu 201. Press down or up arrow key to select Basic.Press Menu/set and then Stop/exit.
Hope this helps. Rate if it works. Thanks
Apr 13, 2011 | Brother IntelliFax-2820 Laser Fax
REPEATED REAR PAPER JAMS-BROTHER INTELLIFAX 2820
Try making prints or copies with the rear door open. If it does not jam your fixing unit (hot area) is functioning properly. With the rear door closed try again making copies or prints. If it jams it's most likely the exit rollers acting up.
1. I've seen the exit sensor break on these units and sometimes the drive gears wear and do not feed properly.
2. If using after market toner or refills this may also coat the exit roller with a film which prevents the exit rollers from feeding parper out by reducing the friction of theses rollers. Clean with fantastic untill cloth does not turn black.
Sep 01, 2009 | Brother IntelliFax-2820 Laser Fax
Paper jams continue to occur on brother fax 2820
Depends on the location of the jam is. Feed wheels need cleaning, clean with windex. or and most likely you have a bad drum unit,
Jul 28, 2008 | Brother IntelliFax-2820 Laser Fax
INTELLIFAX 2820--PAPER/SCANNER JAM
go to brother & download driver for printer. good luck !
Jul 13, 2008 | Brother IntelliFax-2820 Laser Fax
Paper won't feed from drawer - stuck on "manual feed"
The readout on my intellifax 2820 says, Document Jam, clear the scanner jam, then press the stop key. I can't get it to clear. What should I do?
May 03, 2008 | Brother IntelliFax-2820 Laser Fax
Brother 2820
You have a sensor out of position and needs refitting in the scanner lid
Oct 28, 2006 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
3,139 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
