Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
I need to know what compartments to put the water in, and to put the cleaning solution in.
  • 438 Answers
Hi There,
The Larger compartment is for the clean water, and the secondary tank attached to the larger tank in the back of it is where the shampoo goes. This machine is handy as it will automatically mix the two solution tanks together for you.
Feel free to reply if you have any other questions. Thanks,
Chris Jones
GoVacuum.com
Posted on Apr 24, 2010
As I pulled the cable out of my Henry,water was pouring out of motor compartment, around 1/2 glass. It was stored dry in airing cupboard, no water leak anywhere and I did not vacuum any liquid in.Help
The only way water can come out is if someone or something has put some water in first.
Ensure the motor compartment is thoroughly dry before turning it on, otherwise you will fry your machine.
Apr 04, 2017 | Vacuums
My cousin has a Roomba vacuum like mine and her 50 lb 13 year old dog had an accident otherwise known as **** that her Roomba went over and over repeatedly while she was at her daughters house watchin
If it as my Roomba,.....,with a pair of latex gloves on and outdoors I'd open the bottom compartment and take the two spinning brushes out. Depending on how wet or dry the dog deposit is, with wet I'd put my hose on power spray and hose the two brushes clean, then soak in a bleach solution. If dry, I'd leave them in the sun to further dry and then try getting the dry majority off with a stick or brush. When the majority is off, power spray the brushes and soak them in bleach water solution. Dry brushes ASAP and with a bunch of wet wipes clean out the area around the brushes underneath. If it somehow got into the filter compartment, you've got a lot more difficult a job to clean. You don't want to get water into the motor or fan in the filter compartment. Did you get a spare set of parts, etc. with yours? If so you might just want to toss out and replace with a clean set.
Sep 10, 2014 | iRobot Roomba 560 Robotic Vacuum
Has no suction
1. Remove dust collector compartment/s. Look for any filters, remove and clean. (Make sure you DO NOT clean filters with water.) Take filter/s outside and "slap" them against a flat surface. (Filter will be very messy to clean)
2. Replace all filters and compartments.
3. Also try using a wire hanger and try to reach as far down the hose as possible to remove any obstruction/s.
Note: Clean vacuum filters frequently to ensure proper suction.
Feb 10, 2011 | Bissell 3920 Bagless Upright Vacuum
Do you put water in the big compartment under the solution compartment when wet washing your floor
You put water and Hoover Cleaning Solution into the top tank. Push down on the release button at the top of the tank just below and in front of the handle. The cap is also your measuring cup. Fill it with the Hoover Cleaner Concentrate. Pour that into the tank and fill it to the fill line with warm water.
The dirty water will be extracted into the bottom tank.
May 20, 2010 | Hoover H3030 FloorMate SpinScrub 500...
Have a Bissell Proheat2 will not spray water from the carpet power head but sprays from tools setting Does anyone know how to get water to spray or clean out water
I had this problem. It was small pieces of debris that got into the solution lines and clogged all the nozzles. There is a nozzle for the handheld attachments, one on the front of the machine for spraying spots and two nozzles underneath just behind the rotating brushes.
It was a royal pain disconnecting the clear rubber hoses inside the machine and blowing out the nozzles and the hoses with compressed air. If you are mechanically challenged I'd suggest you take the machine to a vacuum/steam cleaner repair facility.
I'm not sure how the debris got into the solution system, but it may have been when the dirty water tank was emptied some of the dirty water entered the internal, clean water bladder.
A note to Bissell engineers: This issue can be prevented if you simply add an easily accessable solution and/or water filter that the customers can remove, clean and reinstall. Just a suggestion.
Apr 29, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do you clean the water intake compartment?
Hoover makes a nozzle cleanout tool just for this purpose cost is under $5. It can be purchased online at Hoover or from your local dealer.
Apr 22, 2010 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
The plastic nob to hold in the cleaning solution is broken
I am assuming you refer to the solution tank valve. there are 2 basic models, a one compartment that holds the soap and water mixture and the 2 compartment keeping soap and water separate. in either case, the valve can be replaced. The tank will need evaluation before that can be reapired. I would take the tank into a repair shop
Oct 06, 2009 | Hoover Vacuums
Don't know how to use carpet shampooer
You should have the new aquamate, it has a blue top to fill with the water and water/soap solution that pops down into place. You will need to use your power nozzle hose and tube, connect it to your shampooer (make sure to connect the power connection just like the power nozzle). Fill your water up, large compartment is for cold water only and the smaller compartment is for one cap full of soap then the rest filled with cold water. Start with just a splash of water or an empty basin in the rainbow. The trigger will control your water spray and the brush underneath. There are two levers on the back of the shampooer marked with a shower head and a bar of soap. Use the soap with the shower head and the soap on and the water only with just the shower head on. You will want to also go over the area shampooed with both off to **** up the remaining water. Make sure to clean your floor thoroughly before shampooing.
Aug 13, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Where do i put the soap?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=548073
Posted by dopaMEAN on Apr 26, 2008
I have a Bissell Dirt Lifter that has the giant clear store compartment that you supposedly put the water in?
Do i mix the soap in with the water in this compartment or is there another location where i add the soap..
We have looked the machine over and see no other place to really put the soap...
will it ruin the machine if we just add the soap with the water in the detachable compartment?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
According to your description you do mix the water with the Bissell soap in order to dispense the solution onto the spot, it will not ruin the machine if you mix the water and soap together.
You may want to refer to your owner’s manual and check out the trouble shooting guide for no water coming out. You may want to contact the factory or manufacturer to see if they have service tech support or to send out a new owner’s manual for your current model #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Don – The Vac Man
Go Ahead. Use Us.
Apr 26, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water?
There are two tanks on that machine. The lower tank is the recovery for the dirty water and the upper tank is for the clean water solution. You mix the detergent with the clean water and away you go.
Feb 08, 2008 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
49 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
