Question about Hotpoint RGB745 Gas Kitchen Range
I have a Hotpoint gas range (Model RGB745BEH4WH). I ran out of propane a few weeks ago and just attached a tank today. The gas is coming to the range, can light it with a match, etc., but will not light on it's own. Is there a pilot light that went off that I need to relight. ???
    President:
  • 949 Answers
This model does not have a pilot that needs lit.
If you turn the knob on the range to the lite position and you hear sparking then the ignition system is trying to light the burners. The most common reason for them not to light after a tank has run empty is air in the lines. It may take several minutes of burning to clear out the system after filling the tank. Light the burners with a match and if you can turn the oven on also. Let them run for a few minutes until they quiet down. Try to light again and they should be fine.
If you do not hear the clicking sound when trying to light and the oven does not light you may have lost power to the range. Check the plug and outlet.
Let me know if this helps
Posted on Apr 24, 2010
We have a propane tank outside to supply our range stove in the house for some reason the gas is not reaching the stove anymore , can it be the cold weather?
I would suspect the regulator might have iced and maybe if you poured hot water over it it would pass on thru system but be prepared to buy a new one if it doesn't .
Jan 13, 2015 | Cars & Trucks
Electronic ignitor on propane stove wont start
  1. Close all valves, including the one on the supply tank.
  2. Open valves SLOWLY starting with the tank. Safety valves are built in to prevent escape og gas if vales are broken off.
  3. Turn on ONE burner valve and, depening on the ignition type of your stove, light it. (some have an electric spark generated by a power outlet (120v) and make a sort of poping sound, some have a spark generated by a push button type mechanism.
  4. Once one burner lights, the others should light easily. Sometimes air gets in the lines, and this may have to bleed off, but it should only take a few seconds. -PS, make sure the stove is level, since gas tends to flow to the high spot.
Feb 20, 2014 | Frigidaire Stove/Oven/Range White Cooktop...
I bought the compressor about two years ago and used it only a few times. It ran fine a few weeks ago but today it will not start. It is as though it is not plugged in even though the outlet works for...
Is it possible that you didn't drain the air out of it after you used it a couple of weeks ago? If the pressure in the tank is somewhere around 100psi, the compressor won't run until it drops lower. If there is no pressure in the tank you might see if you can wiggle the pressure lever that makes the switch move to turn on the motor - it might be stuck.
Aug 04, 2010 | Air Tools & Compressors
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Flame going low on range cook-top
Check your gas supply is not running too low and then check for leaks, Let me know if this helps.
Jan 02, 2010 | Tappan TGF320 Gas Kitchen Range
I CAN NOT FIND THE NON- SELF CLEAN MODELS FOR MY HOTPOINT GAS RAN
heres the cpnversion kit number for the model that you listed, if you have a different model number then rgb790ssehsa, then please list it , and ill find you the correct part number
Nov 25, 2008 | Hotpoint RGB790SEHSA Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
49 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
