Question about Bosch HBN 455 Stainless Steel Electric Double Oven
Inner glass door lower double ove
Glass shattered on low heat. 3 years old.
  • dizzygirl Nov 20, 2008
    I have a single microwave oven.Hadn't used the oven just the microwave today it was only on for 30 seconds and the inner glass shattered it also 3 years old
  • Bosch Master
  • 3,463 Answers
Many teasons for this to happen, no one has come up with a definitive solution for this,it just happens..
All you can do is have it replaced.
Posted on Dec 15, 2008
SOURCE:
I have a Frigidaire Caprice double oven, 45 years old, the inner glass panel on the top oven door has shattered. I am not having any luck with finding replacement glass, any ideas?
take a profile of the glass shape (cut out the shape from cardboard) and go to a glass supply shop ( glass windows , doors , shower screens etc)
they should be able to cut and then temper the glass to make it heat proof for the door
if they cannot temper it they should be able to tell you where you can get it done
Nov 12, 2016 | Frigidaire Ovens
KEB5247 Kitchenaid built in electric double oven
Yes the inner door glass is a replaceable part and the door will have to be disasembled but not replaced. I can help with sourcing any parts for you since you used a premium post.
Jan 02, 2008 | KitchenAid KEBC277 Electric Double Oven
My inner door on my new world cooker exploded could it be i put it the wrong way round
Hi, it sounds like you put the door on yourself? The inner glass of my oven door (less than 1 year old) shattered when I put it in cleaning mode. We had to call a serviceman which fortunately was a part of the warranty we purchased and he said it could have been a microscopic fault in the glass, but he replaced it and it's been good to go. I've never heard of installing the door yourself for an oven, but even so, I just thought I would share our experience. It's a dangerous situation since it could shatter outwardly and hurt you or someone else so you might want to ask for a service person to come and look at it. Hope this helps!
Mar 13, 2012 | Ovens
The outer glass of my oven door shattered, can I still use it until it is repaired?
Hello- I would be careful using the oven mostly because the inner glass will be VERY hot to the touch, meaning you will get burned if you touch it. If you have children I would refrain from using the oven, too risky. If it is just you, or just adults then you should be ok to use it until you can repair it. Keep in mind that you will probably lose a lot of heat out the door and it make take longer to bake. Again, be wary of the inner door glass if you use the oven. Do a test run with a low heat and see how it performs. Hope this helps, best regards.
Sep 27, 2010 | Whirlpool Ovens
The main oven inner glass door panel has shattered
Unfortunatey, it happens quite frequently, there is no one reason for it to do so.
The only solution is to replace it.
Over a number of years use, the glass looses it's properties, and this is what can happen.
Jan 24, 2010 | Zanussi Ovens
TKC 8522/2 top oven outer door shattering
It is not a fault with the door, and this sort of event occurs quite often, so is not uncommon.
All sorts of things can cause this, sudden change in temp, getting the glass wet whilst it is still hot, a knock or bang form an earlier time could have weakened the glass.
The list is quite long..
Depending on your household insurance, some policys cover for breakage of glass fittings, would be worth checking.
Plz rate my solution
.Thanks.
Dec 30, 2008 | Tecnik TKC8522 Electric Double Oven
Viking: VEDO205 Blew my inner glass door
If you can take the door apart then you can fix it. Remove all the retaining screws to access the inner glass.
Dec 11, 2007 | Viking DEDO205 Stainless Steel Electric...
Bosch HBN 455 Stainless Steel Electric Double Oven Logo
237 people viewed this question
Top Bosch Ovens Experts
Marvin
Marvin
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
