Question about Canon PowerShot A470 Digital Camera
Batteries only lasting a couple of days with minimum usage
Camera keeps telling me to replace batteries even though they are new batteries... I am not using the camera much. Batteries used to last ages but now it is telling me to replace every few days
I have same problem. I think it is because the batteries have to be Alkaline
Posted on Apr 25, 2010
Testimonial: "Thanks..I will try that"
My Samsung WB100 turns off after switch on. Got new batteries and same problem plus 'old' batteries are still good even though camera said they needed replacing after a few days minimal use.
Make sure you are using name brand high quality batteries and not some generic from China. Camera require a great deal of power to boot up.
Jan 25, 2013 | Samsung Wb1000 Digital Camera
Hi I have had this camera for a short while, its been working fine, lately i put new batteries in, and it only last for and it tells me low batteries only after a short while, has there being an issue with...
Digital cameras often use batteries quite quickly especially with heavy usage. If you are using standard all purpose batteries you may consider using batteries which last longer in electronics that draw a lot of power such as Duracell PowerPix or Energizer Lithium. Alternatively you may consider investing in rechargable batteries and keeping a spare set in your camera bag.
Jul 28, 2011 | Cameras
I have a old pride victory 3 scooter working well what is the minimum charging time /how much for a replacement battery/s and how long do they last thanks
It is best to let it charge at least over night, longer if it hasn't been used for a while. It is also good to give them a long workout (Don't completely flatten them though) at least occaisionally. If they get regular and thorough use they will last longer, but extra weight like shopping, or lots of steepish paths will flatten them a lot faster. They are only supposed to last a couple of years, but will go longer if you look after them.
One of the most important things is to find a supplier/repairman you can trust. These are, after all your legs or mode of transport you are talking about.
Jan 15, 2010 | Pride Victory 4 Wheel Mid-Size Electric...
My 2 yr old Ixus 70 keps turning itself off.
How old is your battery? Keep in mind rechargeable Li-Ion batteries aren't meant to last more than a couple years, regardless of whether they've been used or not. If yours is as old as your camera, I think you know the answer. The good news is there are many inexpensive generic alternatives available these days. Some are very good, and vice versa. Research the buyer reviews before considering purchasing.
Nov 10, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
The battery is run down every time I come to use the camera. So it seems to bleed out power even when turned off. I have replaced the original battery and the new battery also runs out while sitting turned...
This is not a common/generic problem for this camera, we need to be a bit more creative into it resolution.
I am assuming that you have already checked for accidental 'power on' of the camera prior to reporting it. By accidental power on, i mean that as this is one of those semi-pro dslr cameras you need to make sure that the power is turned off before you replace the lens cap as otherwise you can mistakingly leave the camera on while the covered lens will show nothing on the lcd/viewfinder display.
Check the time it takes for you to charge your battery. It should take a minimum of 5.5 hours to charge the battery fully. If the charging light on the charger turns off before then, continue charging for the next couple of hours. Try using the batteries again. Also, please note that temperature is very important both during usage and charging. As per Sony, the optimum charging temperature is 25 degrees C or 77 degrees F. In colder areas, battery power runs out extremely fast.
Aug 21, 2009 | Sony Cyber-shot DSC-H50 Digital Camera
The main batter will not hold its charge when left in the camera.
After 12 months use camera batteries will not hold a true charge, but they can still be used for clocks, or remotes. Buy new ones. We all have the same problem.
Mar 08, 2009 | Sony Alpha DSLR-A100 Digital Camera
Battery issues
the mainboard on the phone is faulty and needs to be replaced.
Aug 19, 2008 | Motorola Mobility RAZR V3
What battery to put in the camera
You have a couple options. First you can buy lithium batteries, which are a little pricey, but they last a great deal longer in high tech devices such as digital cameras.
Second, you can buy rechargable batteries, which also last alot longer in cameras, and are worth the price because they can be reused!
Jan 15, 2008 | Canon PowerShot A520 Digital Camera
Canon A95 "Change Batteries" problem!
I have this problem as well. I thought it was a problem with my NiMH batteries. So, I bought a volt meter to make sure the batteries worked. I have 8 AA NiMH batteries. I charged them all up and tested them with the volt meter. They were all good to go. However, no matter what I put in the camera one of two things happens:
1. I get the "change batteries" message.
2. I don't get the message, but the next time I check the camera (a few days later), one of them is totally drained.
Something is very wrong and I plan on contacting Canon.
Nov 30, 2007 | Canon PowerShot A520 Digital Camera
Technical problem
I purchased a *ist DS used a couple of weeks ago, and it turns out to have similar problems. This camera seems very fussy about batteries. I am using rechargeable NiMh AAs. After about 30-40 exposures, the camera shows battery depleted. If I turn the camera off, then back on, it will show a charge - sometimes a full charge and will work for another 20 or so exposures. It can keep this up for a couple of days.
I read an explanation in one of the photo blogs (can't remember which) that suggested this was caused by one or two incompletely charged batteries in set of 4. If one is discharged the current from the others supposedly will flow to it, giving fluctuating power readings to the power management curcuit. This sounded plausible enough that I purchased a new charger yesterday which monitors the charge on each battery. Too early to tell whether this solved the problem or not. The other option is to switch to disposable batteries.
Oct 09, 2006 | Pentax *ist DS Digital Camera
Canon PowerShot A470 Digital Camera Logo
129 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
