Question about Logitech MOMO Force Wheel And Pedals Set
The main clamp is broken, can I get a replacement part?
  • yadayada
    yadayada May 11, 2010
    no they don't seel parts for these.
    Novelist:
    Champion:
  • 250 Answers
Hi Bendres,
Your best chance would be to check on ebay, Logitech does not provide such spare parts. Unfortunalty..
Thanks and have a nice day
J -
Posted on Jun 07, 2010
How to replace starter rope in lawn mower
First assemble the following: Pliers, large vice grips, 'c' clamp or a bench mounted vise and new rope. Remove therecoil housing from top of engine. Turn it over, find the end of the broken rope and on pull it until it is fully extended but do not remove yet. While holding the rope extended place clamp device on the rope housing clamping the spool and housing. Be careful not to put too much pressure on the housing, just enough to hold the two pieces. Carefully remove old rope and thread the new rope through the small hole in the housing and into the slot in the pulley. Tie that end of rope into a knot to prevent rope from coming out. While holding other end of rope, carefully remove the clamp from the housing and slowly let the rope rewind into the housing. Replace rope housing onto top of motor. HOW TO Replace Broken Lawnmower Pull Cord
Sep 01, 2014 | Garden
How to fix a broken Needle clamp on viking 936
I don't know of a way to repair the needle clamp. It will more than likely have to be replaced. The local authorized husqvarna viking dealer should be able to service the machine. You can find the nearest dealer from husqvarna viking website - http://www.husqvarnaviking.com/us
Apr 24, 2014 | Husqvarna Huskylock Computerized 936
The leg clamp on my tripod is broken i need to find a replacement
They were not made to be serviced. They were made to be disposable essentially, but you might contact the folks at B&H to see if they may have a solution.
Otherwise depending how it broke, it might be able to be cemented, or reconfigured to accept a different type of clamp. I had a no name type of tripod that required some caredul filing to restore a lip on a clamp so it would lock after the original lip snapped off.
Jul 07, 2012 | Dynex 60" Universal Tripod
Alternator belt is broken
Get a new belt from an autoparts store, to suit your vehicle year and model.
The alternator has to be loosened to fit the new belt. There's usually two locations to loosen
  1. the top adjuster clamp arm; and
  2. the lower pivot bolt. On the 4cyl motors its in behind the oil filter. Uncertain about the v6.
Once loose, the alternator can be swiveled so that the belt will fit over the main pulley.
Make sure that the alternator does actually rotate. If not, get it serviced or replaced.
Swivel the alternator back down and tighten the clamp arm so there's about 8-10mm of movement when you press the belt.
Tighten up the lower pivot bolt.
If you don't have the tools or skills to do this, have the car towed to a garage.
Jan 03, 2011 | Eagle Talon Cars & Trucks
I replaced my battery but as I was tightening the bolt to fasten the clamp to the battery terminal, the bolt snapped in half. What is the name of the bolt/clamp that is used to tighten to the terminal
battery terminal clamp NUT & BOLT any bolt with the same diameter will work. take broken pieces to a hardware or auto store to find a replacement.
Sep 29, 2009 | 1999 Volkswagen Jetta
ELECTRICAL
ck the main fuses under hood the main fuses close to the batterie 80 amps and 100 amp ratings replace them also ck the ground cable from batt to engine bloc
Dec 21, 2008 | 1992 Nissan Pickup
How to replace the door bellows seal ?
this is general for all door seals - all are much the same.
disconnect from mains. take lid off
prise off the clamp holding seal to cabinet - usually a wire circle with a spring - and peel seal off cabinet. fold seal back inside drum
seal is held onto lip of tub with what is really a giant hose clip. undo this and the seal will come away from tub.
on new seal, lubricate the slot in the seal that goes onto the lip of drum with washing up fluid.
starting at top, enter the slot in seal on lip of tub. work your way round in both directions pushing slot onto lip. this is the hard part and it may take more than one attempt.
when seal is on all the way round, replace the clamp.
refix seal to cabinet (easy to do) and refit outer clamp.
test for leaks on rinse as water level is higher
Nov 10, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Leg lock broken
Assuming you still have the female part with the treads in tact, you can do what I did. I used a hose clamp, the kind used on radiators, but larger. First, take off the lock down knob, then put the hose clamp over the broken plastic housing and mark where the knob would screw through. Then remove the hose clamp, placing it on a sturdy surface and use a 5/16 drill bit to make a hole where the lock down know will pass through. Place the hose clamp over the plastic housing, insert the knob, tighten the hose clamp (but not so much that it restricts the tripod leg from moving) and you are done! I can send you pictures of the process and the final result. It saved me from buying a new tripod! I can be e-mailed at boingsplatplop@yahoo.com if you have questions.
-Spencer
Nov 07, 2008 | Photography
Logitech MOMO Force Wheel And Pedals Set Logo
253 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Lyle Siemens
Lyle Siemens
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
