Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
Was mowing the lawn when all of the sudden i heard a pop and the steering went on the mower. The steering wheel just spins and the rod underneath the engine is just hanging
  • 454 Answers
There is probably a ball joint connection that broke, or something could have just came loose. Not a hard repair, if you are not mechanically inclined, any mower shop can fix it, or if you have a neighbor that works on cars etc can fix it easily.
Posted on Apr 24, 2010
John Deere Riding Mower won't steer after a rollover accident. How do we fix? Or even know what to fix?
not sure but if it is mechanical steering I would look for a bent tie rod on either side and from the steering gear under the hood ..
Oct 16, 2015 | John Starter Deere Sst18 Spin Steer Deere...
Tip
Personal Safety
Be sure to take the right safety precautions before you mow.
  • Never attempt to lift or repair mower with engine running.
  • When mowing with a walk-behind mower, wear heavy-duty shoes with non-slip soles and long pants to protect your legs.
  • Always wear eye protection when operating a mower.
  • Don't mow a wet lawn or late in the day when the light is dim.
  • Never let the starter robe snap back when starting mower.
  • Always mow up and down an incline with a traditional (i.e. unit with steering wheel) riding mower.
  • Always mow across an incline with a residential walk-behind mower.
  • Never adjust mower height, clean grass chute, or remove grass catcher with engine running.
  • Always stay clear of hot engine. Mufflers can reach up to 1,200 F (648 C
on Apr 02, 2011 | Garden
Troy Bilt Lawn Tractor won't turn left - still turns right
hi, mam i want to solve this prolem try contact or text this number 0927642929 / ( 032) 5127262
Sep 11, 2012 | Troy Bilt 175HP Manual 42" Riding Mower
I was mowing and all of a sudden it stopped steering. The front left wheel moves when I move the steering wheel. The front right doesn't. I can move the front right without moving the steering...
Sounds like the tie rod has came loose or broke, look for a rod that connects the working wheel to the steering and then compare it to the non working side and you will be able to see what is missing
Jun 27, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
How do you fix the front wheel alignment on a 48 inch lawn tractor by Craftman. The wheels are turned to the outside. Theres no bent rods or anything. Whenthe wheels go one way in the frony. you mow the...
make sure tie rod between wheels is straight. if bent will cause wheels to turn outward. take tie rod loose at each wheel, straighten rod reinstall wheels should be straight.
Aug 21, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I just bought a Poulan PR550N21RH3 Rotary Lawn Mower. The first time I used it it worked fine. While I was mowing the second time I heard a big "POP" then it began to shimmy. What should I do?
check the blade to make sure its on securely and isnt bent or broken.
If something went wrong other than blade damage I would take it back and ask for a replacement.
Jul 30, 2010 | Poulan "Poulan" Push Mower
Craftsman Lawn tractor - When turning to the left the Left front wheel turns much farther then the right front wheel does on a hard right turn. Almost perpendicular to the tractor. Busings are brand new....
I've noticed this on other Craftsman and MTD mowers. The ones with the one main steering rod from the steering wheel to the left wheel and a connecting rod from the left wheel to the right wheel. I think that since we are advised to mow in a counter-clockwise direction, they design the mowers to turn tighter towards the left. It's in the design just like you suspected.
Apr 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding lawn mower steering shaft fell. Mower will not steer. I just started mowing, and the mower quit steering. Looked underneath, and it appears the shaft came loose that is used to steer. Any...
Look under the seat of your tractor and note the complete Model number.
(usually begins with 917. _ _ _ _ _ _ )
Next, go to THIS PAGE and use the Model Number to find an exploded view of the steering components and how they assemble.
Hope this helps,
Dolf-
Oct 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
May 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
406 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
