Question about Hotpoint Ultima WF865 Front Load Washer
My hotpoint frontloader won't continue with the wash
My machine is beeping and saying 'problem E30'. What does this mean and how do I fix it?
  • 1462 Answers
SOURCE: hotpoint ultima 1200 wm72
code e30 means motor fault. this can be just motor brushes, tacho fault or module fault. can't narrow it down more than this - you will have to dive in and check
Posted on Apr 10, 2007
SOURCE: faulty door which keeps beeping
I had a similar problem which was resolved by replacing the door interlock switch (cost about £10.00).
To get to it you need to disconnect the mains then remove the top lid. You can then see it by looking down the inside to the right. Remove the 2 screws inside the door opening and you can then lift it out after disconnecting the wiring plug.
Replacement is the reverse of the above, a 5 minute job.
Posted on Dec 29, 2007
SOURCE: error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Dec 15, 2008
  • 135 Answers
SOURCE: E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Thanks for using Fixya.
Posted on Dec 16, 2008
  • 3 Answers
SOURCE: All lights flashing on Hotpoint WF541G washing machine
It's probably a loose connection in the wiring in the machine. Seems to be a problem with the WF741 machines and is most likely a similar issue with yours. The probability is that the vibration from the machine is enough to work some connections loose. If you have someone competent to do this, then check that all connectors are pushed firmly onto their circuit boards. (I have posted a separate reply to this issue for the WF741 model on here.) See if this helps.
Posted on Oct 27, 2009
Error E30 flashing on washing machine
What brand. Ih it is a hotpoint. I found this on the net from a washer help site in the uk
Error 30 (on Hotpoint) just means the motor isn't working. Several things, including the power module, can cause this. The most common cause though is worn carbon brushes. There is also a 7.5 amp fuse on or near the power module, which can blow. This fuse is on the motor circuit to protect the circuitry of the power module. If it blows, then the motor won't work and you will get error 30.
If it has blown, it's likely to be caused by the motor. I had one last week where the armature in the motor had shorted to earth which blew the 7.5 Amp fuse.
To check the brushes, with the machine unplugged! Have a look at my Hotpoint and Creda carbon brushes diagnostics You can also Buy Hotpoint & Creda carbon brushes
Jul 18, 2014 | Washing Machines
Why does my my frigidaire front loader washer reads diagnostic code e30
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Dec 19, 2012 | Hotpoint Ultima WF860 Front Load Washer
E30 code coming on, hotpoint ultima 1000. stops washing and starts bleeping
  1. E30 means a motor drive problem has occurred. Motor problem - check motor brushes, drive belt, tachometer or tachometer magnet, motor relay or PCB (TRIAC motor control).
  2. The main control board in these machines has a relay that may fail because of bad solder joints. You will need to unpin the board to see behind where the white wires from the motor connect to this board, you will find the relay near to the edge. Check the solder joints for damage.
Feb 27, 2011 | Hotpoint Washing Machines
Hotpoint Model WM75 Error Code E30 (Motor Drive problem)
what does e30 mean on wm75 hotpoint ultima 1200
Dec 02, 2010 | Hotpoint Washing Machines
My hotpoint ultima extra washing machine says e15 check outgoing pipes i have cleaned the pipe out and is washing to a certain point then e15 shows and starts to beep continuously
hello,
what e15 indicate means an error code that there have been an over flow of water from the drum over to the panel or the wire that suppl power to the screen .
what you will have to do to fix up this problem from the screen is to unscrew the screws with screw driver care then trace the wire ,that is the power supply down to the panel and also to the screen clean up all forms of liquid around the wires and also the panel carefully . then couple it back with care to is position with this the problem is solve.
thank you.
Aug 07, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint washer/dryer keeps coming up with code e30 see user guid and stops washing,what does that mean
Error code E30 indicates motor tachometer failure.
There is a loss of signal during tumble or spin.
Check your user guide.
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error code e30 see user guide .comes on and stops washing do not have user guide
E30 is a motor problem which is most likely brushes need replacing.
Hope this helps & Thanks for using Fixya.
Jan 18, 2009 | Washing Machines
E30 flashing when I try to start wash program on Hotpoint Aquariu
E30 indicates a motor problem, you will need to call an engineer.
Possible worn brushes which you can do if you know what you are doing.
Nov 24, 2008 | Hotpoint Aquarius WD640 Front Load...
Wd71 with e30 code on display when i try to use the dryer
try changing the thermostat located on top of heater in top of machine
Nov 08, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima 1200 wm72
Apr 05, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WF865 Front Load Washer Logo
107 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
