Question about Kenmore 15073 Stainless Steel Built-in Dishwasher
How do I reset the kenmore ultra wash model #: 665.15812990. It has completely stopped working.
    President:
  • 949 Answers
First make sure you have power to the dishwasher, breaker or fuse is good, outlet (if so equipped) is powered etc.
If you have not lost power to the dishwasher then the most likely failure that causes this would be the thermal fuse that is located in the console.
It is a temperature controlled device that can trip if there is a lot of heat in the control area.
If you want to tackle the repair it is not too difficult and requires a basic understanding of electricity and an ohmmeter.
The part number for the fuse is 675813 and is about $10.00. It is located right behind the buttons on the control panel, here is a picture of the part.
how do I reset the kenmore ultra wash model #: - e6f738a.jpg
Posted on Apr 25, 2010
  • 209 Answers
SOURCE: Kenmore Ultra wash model 665 17779990-Cycle wont finish- Lights blinking
heater element if its not warming up, you didn't say, if it worms up then check the pump
Posted on Oct 15, 2007
SOURCE: Kenmore Ultra Wash Dishwasher - 665 - 13783
dcvxzcxzcxzczxc
Posted on Feb 26, 2008
SOURCE: Kenmore Ultra Wash Quiet Guard
there is a hose right on the back? its not rocket science!
Posted on Jun 05, 2008
SOURCE: My kenmore ultra wash model
my model #665 dishwasher will not pump water into the unit
Posted on Jul 15, 2008
  • 127 Answers
SOURCE: kenmore dishwasher has stopped draining.
remove the kick panel below the door, place a pan, etc under where the drain hose connects to the drain extension tube, and slide the clamp back some so you can slide the hose off of the extension tube (white plastic tube) and drain any excess fluid into the aforementioned pan, etc., then unscrew the extension tube and check for plugs, or restrictions.
the sump may also be pluged beneath the strainer assembly, and that requires removing the lower spray arm, the water tube that runs up the inside back of the unit, and the upper parts of the assembly below them to access the drain/pump sump area.
last but not least the impeller is jamed and might be able to be freed by removing whatever has lodged within there..
ya never know...
best of luck,
ttfn
Posted on Oct 25, 2009
Kenmore Ultra Wash Dishwasher door won't open
It seems most likely door latch stock and you going to need buy new door latch as for stock one most likely you hsve to forceit to open and replace it with new one
Dec 09, 2013 | Kenmore Dishwashers
Water in bottom of kenmore elite ultra wash dishwasher
you must check the filters that are at the bottom under the spray arm
then you must start and then hold down cancel or stop and it should kick in the automatic water discharge mode and activate the water pump if this does not work you need new dishwasher pump installed which can be found online by googleing your model number. gut if this all works then the small flapper thats internal on the pump isnt sealing and allowing water to flow back into the bottom. last but not least you might need a new control board.
Nov 02, 2012 | Kenmore Dishwashers
My Kenmore Ultra Wash model 665 Dishwasher stopped working. It won't turn on and some water in the bottom won't drain although there is no sign of a clog, and it's not unplugged.
It is supposed to be hardwired and not plugged in. In which case it could have thrown a breaker and you would not know it unless you used a test light, or reset all the breakers (often you can't visually tell when a breaker it tripped).
There may also a reset on the motor itself that you need to push.
Aug 14, 2010 | Kenmore 15899 Built-in Dishwasher
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Dishwasher won't start
Drhook65,
Welcome,
I'm Huuum
How old is this dishwasher and the complete model number is?
You said, you have a Kenmore Ultra Wash dishwasher, and you have power running to it, but when you shut the door on it...it still won't start a cycle. Does it have a reset button on it? Any ideas on a solution?
Yes, you may try this to reset the system.
Go to the breaker and switch it off for 5 minutes and the on and try it. It usually resets the systems.
Let me know ho it goes. Huuum
Do not forget to leave a rating.
Sep 24, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher; Model 665.17539
I have a Kenmore 665 about 3 years old
Over the last couple months the touch pads have stopped working and I am now down to one control the water miser!
Do I need a new control pad and is that easy to install ?
Thank you for any sudgetstions
KC
Jan 15, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
The washer stops after it fills with water?
You need a new SWITCH, LID 8318084 the bad lid switch is keeping your washer from sorking.. let me know if you want to repair it yourself.. let me know?
Aug 25, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 15073 Stainless Steel Built-in Dishwasher Logo
474 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
